A
antenna-eng
@antenna-eng
  • VOXL-2 Drone M0054-2 Boot Issue After C26 Camera Update
    A antenna-eng
    @tom I connected it to the battery. I made sure the battery was charged.
    Development Drones voxl2 starling2 starling
    A antenna-eng
    @tom Using the dmesg -wH command you provided, I can't see the device enumerating after plugging it in. I also tried different USB cables just to check. Still no change.
    A antenna-eng
    @tom
    The VOXL board isn't appearing when connected. I'm just seeing the system USB bus devices and things like the mouse/keyboard. Below is the output of lsusb
    drone@ubuntu:~$ lsusb
    Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc. USB3.1 Hub
    Bus 001 Device 005: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC
    Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120
    Bus 001 Device 003: ID 046d:c05a Logitech, Inc. M90/M100 Optical Mouse
    Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc. USB2.0 Hub
    A antenna-eng
    @Vinny I was reminded after my post that our team did try the system on Ubuntu. Just to check, one of my team members just tried it on a Ubuntu system we have and it doesn't show up as a USB device. What do you think we should do?
    A antenna-eng
    @Vinny I also have other Linux systems (Ubuntu, Redhat, etc) that I can use. We were using WSL to connect to it and it was working fine. We can try some other systems to rule out that issue.
    A antenna-eng
    @tom I'm using WSL Ubuntu to connect to it. It was working well previously.
    A antenna-eng
    @tom Is the VOXL2 board is malfunctioning? Is there any other way to test the board?
    A antenna-eng
    @tom I ran lsusb before connecting and after to see the change. Only the normal system USB devices are appearing.
    A antenna-eng
    Hi Tom,
    I did try removing all of the cameras. Still had the same result. After removing the cameras, I next removed the Wifi board to see if that was causing an issue. Also had the same result. At that point, the only board connected to the VOXL 2 was the power board.
    A antenna-eng
    Hi everyone,
    I recently upgraded my VOXL2 Starling drone to the C26 camera package. I didn’t have the TOF sensor and needed one to run the VOXL Mapper (and have obstacle avoidance). I disassembled the drone, removed the old camera interface modules. Then installed the new camera interface module (now a larger single board). I then reassembled the drone.
    I’m running into an issue with my VOXL-2 board (M0054-2) after attempting to update the camera to a C26 configuration. Here’s what I’ve done so far:
    1. I 3D printed the mounts and connected everything according to the C26 setup.
    2. After connecting the new camera, the drone powers on, plays the boot chime, and shows the following status lights:
      • D1: Green
      • DS1: Green
    However, the drone doesn’t fully boot and doesn’t show up via USB connection.
    Troubleshooting Steps Taken:
    • I tried putting the drone into fastboot mode, but it still didn’t register any USB connection. (I couldn’t confirm visually if it entered fastboot mode as there don’t seem to be any indicator lights for this.)
    • I followed the Emergency Download Mode guide (https://docs.modalai.com/voxl2-unbricking/) to attempt a recovery. I reached the “Provision” step, where I was supposed to provision the device through the web UI. However, this step failed.
    • I could see Qualcomm’s chip listed in my USB devices, so there seems to be some connectivity at that level.
      At this point, I’m stuck and not sure how to proceed. Has anyone experienced something similar or have any suggestions on how to get the drone up and running again?
    Thanks,
    Daniel
