  3. USB devices not detect before "$ adb devices"
3 Posts 2 Posters 698 Views
  • Shunichi ShiozawaS Offline
    Shunichi Shiozawa
    I connect VOXL to my Ubuntu20.04 laptop but "05c6:901d" and "18d1:d00d" don't show up but just "0403:6001" when I do "lsusb" command.
    I tried several USB cables and another PC but I always get same output.
    ==P.S.==
    I'm using "VOXL CAM + TOF Dev Kit w/ Flight Controller".
    The green LED turn on and not blinking.
    I checked below links.
    https://forum.modalai.com/topic/748/adb-devices-not-found
    https://forum.modalai.com/topic/41/adb-is-not-working-no-adb-device-detected
    • ModeratorM Offline
      It looks like you might be inside of the docker, can you try from command line?
      Shunichi ShiozawaS 1 Reply Last reply
      • ModeratorM Moderator
        Shunichi Shiozawa
        wrote on last edited by Shunichi Shiozawa
        @Moderator
        I didn't use docker.
        (certainly, the screenshot folder looks like inside docker)
        This problem was solved in another way
        I made a mistake in the port to insert the micro USB.
        Thank you.
