    USB devices not detect before "$ adb devices"
    • Shunichi ShiozawaS
      Shunichi Shiozawa
      I connect VOXL to my Ubuntu20.04 laptop but "05c6:901d" and "18d1:d00d" don't show up but just "0403:6001" when I do "lsusb" command.
      I tried several USB cables and another PC but I always get same output.
      ==P.S.==
      I'm using "VOXL CAM + TOF Dev Kit w/ Flight Controller".
      The green LED turn on and not blinking.
      I checked below links.
      https://forum.modalai.com/topic/748/adb-devices-not-found
      https://forum.modalai.com/topic/41/adb-is-not-working-no-adb-device-detected
      • ModeratorM
        Moderator ModalAI Team
        It looks like you might be inside of the docker, can you try from command line?
        Shunichi ShiozawaS 1 Reply Last reply Reply Quote 0
          Shunichi Shiozawa @Moderator
          @Moderator
          I didn't use docker.
          (certainly, the screenshot folder looks like inside docker)
          This problem was solved in another way
          I made a mistake in the port to insert the micro USB.
          Thank you.
