  3. ADB devices not found
voxl-cam
31 Posts 4 Posters 16.8k Views 2 Watching
  • M Offline
    M Offline
    marian
    Hi, for the same voxl cam I ordered, i tried to use adb to connect to it and doesn't work. I tried via un Ubuntu client and via my mac too.
    The answer is always like this:
    % ./adb devices
    List of devices attached
    Via Windows (where i use an ubuntu client) I see the devices connected on the usb port, but on linux the command adb doesn't see it.
    Via Mac I don't see at all the devices connected.
    I use the power module delivered with the voxl package and a 4s battery to power it.
    Please advice how to proceed.
    • M Offline
      M Offline
      marian
      I see the device when I run lsusb on the ubuntu client, but not when I run the adb devices command as below:
      marian@RM:~$ lsusb
      Bus 001 Device 002: ID 05c6:901d Qualcomm, Inc. APQ8096-MTP _SN:4549C070
      marian@RM:~$ adb devices
      marian@RM:~$
      • tomT Offline
        @marian Does it show up with fastboot devices perhaps?
        • M Offline
          M Offline
          marian
          wrote on last edited by marian
          @tom Thank you for your reply.
          No, it doesn't.
          I verified the link and it's fine as per below:
          On Windows
          PS C:\WINDOWS\system32> usbipd wsl list
          BUSID DEVICE STATE
          3-1 APQ8096-MTP _SN:4549C070, ADB Interface Attached - Ubuntu-20.04
          On Ubuntu client:
          marian@RM:~$ lsusb
          Bus 001 Device 004: ID 05c6:901d Qualcomm, Inc. APQ8096-MTP _SN:4549C070
          marian@RM:~$ dmesg | tail
          [ 2188.224798] usb 1-1: SetAddress Request (4) to port 0
          [ 2188.318613] usb 1-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 3.18
          [ 2188.318617] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [ 2188.318621] usb 1-1: Product: APQ8096-MTP _SN:4549C070
          [ 2188.318625] usb 1-1: Manufacturer: Android
          [ 2188.318629] usb 1-1: SerialNumber: c6f37030
          cat /etc/udev/rules.d/51-android.rules
          SUBSYSTEM=="usb", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="901d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl%n"
          SUBSYSTEM=="usb", ATTRS{idVendor}=="18d1", ATTRS{idProduct}=="d00d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl-fastboot%n"
          marian@RM:~$ adb --version
          Android Debug Bridge version 1.0.39
          Version 1:8.1.0+r23-5ubuntu2
          Installed as /usr/lib/android-sdk/platform-tools/adb
          marian@RM:~$ fastboot --version
          fastboot version 1:8.1.0+r23-5ubuntu2
          Installed as /usr/lib/android-sdk/platform-tools/fastboot
          And the results of the commands:
          marian@RM:~$ fastboot devices
          marian@RM:~$
          • tomT Offline
            @marian Were you able to connect to the VOXL-Cam via ADB in the past? Or have you been having these issues out of the box?
            • M Offline
              M Offline
              marian
              @tom I have being issue out of the box, it never connect via adb
              • tomT Offline
                @marian And using this same PC, are you able to ADB onto a different VOXL-Cam?
                • M Offline
                  M Offline
                  marian
                  @tom I have only one voxl-cam
                  • tomT Offline
                    wrote on last edited by tom
                    #9
                    @marian So is SSH working then? I see that you've done some work with this VOXL Cam already based on your post history?
                    Or were you connecting directly to the Flight Core via JST to USB?
                    • M Offline
                      M Offline
                      marian
                      @tom Yes, the ssh and connecting the flight core via jst to usb is working.
                      When I bought the voxl-cam I understood that came calibrated and ready to use. But, as I used it on a custom frame the sensors like accelerometer, compass and gyroscope are not calibrated.
                      I used it on the frame on the same way like seekers (of course, I needed it to adapt the /etc/modalai/extrinsics.conf file for my configuration), but
                      • whenever I use a GPS with compass (as M8N u-blox) I can't calibrate the compass, it will see a different position instead of the position the drone really is, it is finishing the calibration anyway, but after reboot it will ask me again to re-calibrate the compass
                      • whenever I used it for indoor navigation, so GPS and compass disabled, I calibrate the accelerometer with ROTATION-NONE as per modalai documentation,then once I have the local position on, the QGC tell me that I have a roll failure detected and, of course, can't proceed with arming.
                      So, basically I can't use at all the voxl-cam 😞
                      • tomT Offline
                        @marian Okay that is good that at least ssh is working so the board should be functional. I wonder if it is some sort of user privileges issue that ADB isn't coming up. What if you do sudo adb devices? And what if you remove that android rules file: sudo rm /etc/udev/rules.d/51-android.rules and reboot your PC? I'm not sure that file is necessary.
                        For those other questions, I would open a new forum topic so that the whole team can get eyes on it.
                        Hyunsoo Kim 0H 1 Reply Last reply
                        • M Offline
                          M Offline
                          marian
                          @tom The results are the same even if I use sudo or I remove the 51-android.rules
                          • M marian
                            @marian Did you reboot after removing the android-rules file?
                            M 1 Reply Last reply
                            • tomT Offline
                              @marian We may have to take a look at your hardware in house, checkout our RMA info here: https://modalai.com/rma
                                M Offline
                                M Offline
                                marian
                                @tom yes, I rebooted the pc
                                  M Offline
                                  M Offline
                                  marian
                                  #16
                                  @tom In terms of RMA, can we try to have a remote diagnostic? I'm far a way from US ...
                                  • tomT Offline
                                    @marian Have you been able to ADB in to any other VOXL devices on this PC in the past? From what I see in your lsusb output everything looks correct. I'm wondering if there's an issue with your ADB install
                                    • tomT Offline
                                      @marian Here is what a working VOXL looks like on my machine running Ubuntu 18: Bus 001 Device 068: ID 05c6:901d Qualcomm, Inc. We have others at the company who use 20 so that shouldn't be an issue
                                      • tomT Offline
                                        #19
                                        @marian
                                        [  +0.150491] usb 1-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 3.18
                                        [  +0.000010] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                        [  +0.000005] usb 1-1: Product: APQ8096-MTP _SN:AF0F8B82
                                        [  +0.000004] usb 1-1: Manufacturer: Android
                                        [  +0.000003] usb 1-1: SerialNumber: 4399683d```
                                        • M Offline
                                          M Offline
                                          marian
                                          @tom I see the same things, but stiill the adb or fastboot commands don't see my device. I tried with two different laptops, and the problem is the same as per images below:
