ADB devices not found
Hi, for the same voxl cam I ordered, i tried to use adb to connect to it and doesn't work. I tried via un Ubuntu client and via my mac too.
The answer is always like this:
% ./adb devices
List of devices attachedVia Windows (where i use an ubuntu client) I see the devices connected on the usb port, but on linux the command adb doesn't see it.
Via Mac I don't see at all the devices connected.I use the power module delivered with the voxl package and a 4s battery to power it.
Please advice how to proceed.
I see the device when I run lsusb on the ubuntu client, but not when I run the adb devices command as below:
marian@RM:~$ lsusb
Bus 001 Device 002: ID 05c6:901d Qualcomm, Inc. APQ8096-MTP _SN:4549C070
marian@RM:~$ adb devices
List of devices attachedmarian@RM:~$
@tom Thank you for your reply.
No, it doesn't.I verified the link and it's fine as per below:
On Windows
PS C:\WINDOWS\system32> usbipd wsl list
BUSID DEVICE STATE
3-1 APQ8096-MTP _SN:4549C070, ADB Interface Attached - Ubuntu-20.04On Ubuntu client:
marian@RM:~$ lsusb
Bus 001 Device 004: ID 05c6:901d Qualcomm, Inc. APQ8096-MTP _SN:4549C070
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hubmarian@RM:~$ dmesg | tail
[ 2188.224798] usb 1-1: SetAddress Request (4) to port 0
[ 2188.318613] usb 1-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 3.18
[ 2188.318617] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2188.318621] usb 1-1: Product: APQ8096-MTP _SN:4549C070
[ 2188.318625] usb 1-1: Manufacturer: Android
[ 2188.318629] usb 1-1: SerialNumber: c6f37030cat /etc/udev/rules.d/51-android.rules
SUBSYSTEM=="usb", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="901d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl%n"
SUBSYSTEM=="usb", ATTRS{idVendor}=="18d1", ATTRS{idProduct}=="d00d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl-fastboot%n"marian@RM:~$ adb --version
Android Debug Bridge version 1.0.39
Version 1:8.1.0+r23-5ubuntu2
Installed as /usr/lib/android-sdk/platform-tools/adbmarian@RM:~$ fastboot --version
fastboot version 1:8.1.0+r23-5ubuntu2
Installed as /usr/lib/android-sdk/platform-tools/fastbootAnd the results of the commands:
List of devices attachedmarian@RM:~$ fastboot devices
marian@RM:~$ -
@tom Yes, the ssh and connecting the flight core via jst to usb is working.
When I bought the voxl-cam I understood that came calibrated and ready to use. But, as I used it on a custom frame the sensors like accelerometer, compass and gyroscope are not calibrated.
I used it on the frame on the same way like seekers (of course, I needed it to adapt the /etc/modalai/extrinsics.conf file for my configuration), but
- whenever I use a GPS with compass (as M8N u-blox) I can't calibrate the compass, it will see a different position instead of the position the drone really is, it is finishing the calibration anyway, but after reboot it will ask me again to re-calibrate the compass
- whenever I used it for indoor navigation, so GPS and compass disabled, I calibrate the accelerometer with ROTATION-NONE as per modalai documentation,then once I have the local position on, the QGC tell me that I have a roll failure detected and, of course, can't proceed with arming.
So, basically I can't use at all the voxl-cam
@marian Okay that is good that at least ssh is working so the board should be functional. I wonder if it is some sort of user privileges issue that ADB isn't coming up. What if you do
sudo adb devices? And what if you remove that android rules file:sudo rm /etc/udev/rules.d/51-android.rulesand reboot your PC? I'm not sure that file is necessary.For those other questions, I would open a new forum topic so that the whole team can get eyes on it.
@marian We may have to take a look at your hardware in house, checkout our RMA info here: https://modalai.com/rma
[ +0.150491] usb 1-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 3.18 [ +0.000010] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ +0.000005] usb 1-1: Product: APQ8096-MTP _SN:AF0F8B82 [ +0.000004] usb 1-1: Manufacturer: Android [ +0.000003] usb 1-1: SerialNumber: 4399683d```
