    ADB devices not found
    VOXL-CAM
    11729
    • M
      marian
      Hi, for the same voxl cam I ordered, i tried to use adb to connect to it and doesn't work. I tried via un Ubuntu client and via my mac too.
      The answer is always like this:
      % ./adb devices
      List of devices attached
      Via Windows (where i use an ubuntu client) I see the devices connected on the usb port, but on linux the command adb doesn't see it.
      Via Mac I don't see at all the devices connected.
      I use the power module delivered with the voxl package and a 4s battery to power it.
      Please advice how to proceed.
      • M
        marian
        I see the device when I run lsusb on the ubuntu client, but not when I run the adb devices command as below:
        marian@RM:~$ lsusb
        Bus 001 Device 002: ID 05c6:901d Qualcomm, Inc. APQ8096-MTP _SN:4549C070
        marian@RM:~$ adb devices
        marian@RM:~$
          tom admin
          @marian Does it show up with fastboot devices perhaps?
          • M
            marian
            @tom Thank you for your reply.
            No, it doesn't.
            I verified the link and it's fine as per below:
            On Windows
            PS C:\WINDOWS\system32> usbipd wsl list
            BUSID DEVICE STATE
            3-1 APQ8096-MTP _SN:4549C070, ADB Interface Attached - Ubuntu-20.04
            On Ubuntu client:
            marian@RM:~$ lsusb
            Bus 001 Device 004: ID 05c6:901d Qualcomm, Inc. APQ8096-MTP _SN:4549C070
            marian@RM:~$ dmesg | tail
            [ 2188.224798] usb 1-1: SetAddress Request (4) to port 0
            [ 2188.318613] usb 1-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 3.18
            [ 2188.318617] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
            [ 2188.318621] usb 1-1: Product: APQ8096-MTP _SN:4549C070
            [ 2188.318625] usb 1-1: Manufacturer: Android
            [ 2188.318629] usb 1-1: SerialNumber: c6f37030
            cat /etc/udev/rules.d/51-android.rules
            SUBSYSTEM=="usb", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="901d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl%n"
            SUBSYSTEM=="usb", ATTRS{idVendor}=="18d1", ATTRS{idProduct}=="d00d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl-fastboot%n"
            marian@RM:~$ adb --version
            Android Debug Bridge version 1.0.39
            Version 1:8.1.0+r23-5ubuntu2
            Installed as /usr/lib/android-sdk/platform-tools/adb
            marian@RM:~$ fastboot --version
            fastboot version 1:8.1.0+r23-5ubuntu2
            Installed as /usr/lib/android-sdk/platform-tools/fastboot
            And the results of the commands:
            marian@RM:~$ fastboot devices
            marian@RM:~$
              tom admin
              @marian Were you able to connect to the VOXL-Cam via ADB in the past? Or have you been having these issues out of the box?
              • M
                marian
                @tom I have being issue out of the box, it never connect via adb
                  tom admin
                  @marian And using this same PC, are you able to ADB onto a different VOXL-Cam?
                  • M
                    marian
                    @tom I have only one voxl-cam
                      tom admin
                      @marian So is SSH working then? I see that you've done some work with this VOXL Cam already based on your post history?
                      Or were you connecting directly to the Flight Core via JST to USB?
                      • M
                        marian
                        @tom Yes, the ssh and connecting the flight core via jst to usb is working.
                        When I bought the voxl-cam I understood that came calibrated and ready to use. But, as I used it on a custom frame the sensors like accelerometer, compass and gyroscope are not calibrated.
                        I used it on the frame on the same way like seekers (of course, I needed it to adapt the /etc/modalai/extrinsics.conf file for my configuration), but
                        • whenever I use a GPS with compass (as M8N u-blox) I can't calibrate the compass, it will see a different position instead of the position the drone really is, it is finishing the calibration anyway, but after reboot it will ask me again to re-calibrate the compass
                        • whenever I used it for indoor navigation, so GPS and compass disabled, I calibrate the accelerometer with ROTATION-NONE as per modalai documentation,then once I have the local position on, the QGC tell me that I have a roll failure detected and, of course, can't proceed with arming.
                        So, basically I can't use at all the voxl-cam 😞
                          tom admin
                          @marian Okay that is good that at least ssh is working so the board should be functional. I wonder if it is some sort of user privileges issue that ADB isn't coming up. What if you do sudo adb devices? And what if you remove that android rules file: sudo rm /etc/udev/rules.d/51-android.rules and reboot your PC? I'm not sure that file is necessary.
                          For those other questions, I would open a new forum topic so that the whole team can get eyes on it.
                          Hyunsoo Kim 0H 1 Reply Last reply Reply Quote 0
                          • M
                            marian
                            @tom The results are the same even if I use sudo or I remove the 51-android.rules
                              tom admin @marian
                              @marian Did you reboot after removing the android-rules file?
                                tom admin
                                @marian We may have to take a look at your hardware in house, checkout our RMA info here: https://modalai.com/rma
                                • M
                                  marian @tom
                                  @tom yes, I rebooted the pc
                                  • M
                                    marian @tom
                                    @tom In terms of RMA, can we try to have a remote diagnostic? I'm far a way from US ...
                                      tom admin
                                      @marian Have you been able to ADB in to any other VOXL devices on this PC in the past? From what I see in your lsusb output everything looks correct. I'm wondering if there's an issue with your ADB install
                                        tom admin
                                        @marian Here is what a working VOXL looks like on my machine running Ubuntu 18: Bus 001 Device 068: ID 05c6:901d Qualcomm, Inc. We have others at the company who use 20 so that shouldn't be an issue
                                          tom admin
                                          @marian
                                          [  +0.150491] usb 1-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 3.18
                                          [  +0.000010] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                          [  +0.000005] usb 1-1: Product: APQ8096-MTP _SN:AF0F8B82
                                          [  +0.000004] usb 1-1: Manufacturer: Android
                                          [  +0.000003] usb 1-1: SerialNumber: 4399683d```
                                          • M
                                            marian
                                            @tom I see the same things, but stiill the adb or fastboot commands don't see my device. I tried with two different laptops, and the problem is the same as per images below:
