  3. ADB devices not found
voxl-cam
31 Posts 4 Posters 17.0k Views 2 Watching
    @marian Were you able to connect to the VOXL-Cam via ADB in the past? Or have you been having these issues out of the box?
    • M Offline
      M Offline
      marian
      @tom I have being issue out of the box, it never connect via adb
        @marian And using this same PC, are you able to ADB onto a different VOXL-Cam?
        • M Offline
          M Offline
          marian
          @tom I have only one voxl-cam
            wrote on last edited by tom
            #9
            @marian So is SSH working then? I see that you've done some work with this VOXL Cam already based on your post history?
            Or were you connecting directly to the Flight Core via JST to USB?
            • M Offline
              M Offline
              marian
              @tom Yes, the ssh and connecting the flight core via jst to usb is working.
              When I bought the voxl-cam I understood that came calibrated and ready to use. But, as I used it on a custom frame the sensors like accelerometer, compass and gyroscope are not calibrated.
              I used it on the frame on the same way like seekers (of course, I needed it to adapt the /etc/modalai/extrinsics.conf file for my configuration), but
              • whenever I use a GPS with compass (as M8N u-blox) I can't calibrate the compass, it will see a different position instead of the position the drone really is, it is finishing the calibration anyway, but after reboot it will ask me again to re-calibrate the compass
              • whenever I used it for indoor navigation, so GPS and compass disabled, I calibrate the accelerometer with ROTATION-NONE as per modalai documentation,then once I have the local position on, the QGC tell me that I have a roll failure detected and, of course, can't proceed with arming.
              So, basically I can't use at all the voxl-cam 😞
                @marian Okay that is good that at least ssh is working so the board should be functional. I wonder if it is some sort of user privileges issue that ADB isn't coming up. What if you do sudo adb devices? And what if you remove that android rules file: sudo rm /etc/udev/rules.d/51-android.rules and reboot your PC? I'm not sure that file is necessary.
                For those other questions, I would open a new forum topic so that the whole team can get eyes on it.
                Hyunsoo Kim 0H 1 Reply Last reply
                • M Offline
                  M Offline
                  marian
                  @tom The results are the same even if I use sudo or I remove the 51-android.rules
                  • M marian
                    @marian Did you reboot after removing the android-rules file?
                    M 1 Reply Last reply
                      @marian We may have to take a look at your hardware in house, checkout our RMA info here: https://modalai.com/rma
                        M Offline
                        M Offline
                        marian
                        @tom yes, I rebooted the pc
                          M Offline
                          M Offline
                          marian
                          wrote on last edited by marian
                          #16
                          @tom In terms of RMA, can we try to have a remote diagnostic? I'm far a way from US ...
                            @marian Have you been able to ADB in to any other VOXL devices on this PC in the past? From what I see in your lsusb output everything looks correct. I'm wondering if there's an issue with your ADB install
                              @marian Here is what a working VOXL looks like on my machine running Ubuntu 18: Bus 001 Device 068: ID 05c6:901d Qualcomm, Inc. We have others at the company who use 20 so that shouldn't be an issue
                                #19
                                @marian
                                [  +0.150491] usb 1-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 3.18
                                [  +0.000010] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                [  +0.000005] usb 1-1: Product: APQ8096-MTP _SN:AF0F8B82
                                [  +0.000004] usb 1-1: Manufacturer: Android
                                [  +0.000003] usb 1-1: SerialNumber: 4399683d```
                                • M Offline
                                  M Offline
                                  marian
                                  @tom I see the same things, but stiill the adb or fastboot commands don't see my device. I tried with two different laptops, and the problem is the same as per images below:
                                  • M Offline
                                    M Offline
                                    marian
                                    @tom I tried the adb for windows and it is working fine, I'm able to connect onto the voxl-cam via adb shell command.
                                    Still have a problem via wsl to see the devices from ubuntu client, but if is working from windows client for adb I suppose that the device is fine.
                                      @marian Okay that's some good news! Since you're able to ADB from windows that means the VOXL Cam itself is functional. It must be some permission issue. We recommend using Ubuntu 18 directly and none of our engineers here use Windows for software development so I'm not too familiar with WSL. Do USB devices need to be added manually? Not sure they're shared from windows to WSL automatically. You may also need to stop the ADB server from running on the Windows client in order for it to work in WSL. (adb kill-server)
                                      • M Offline
                                        M Offline
                                        marian
                                        @tom It's working just fine 🙂
                                        There were a few issues:
                                        1. when using WSL we need to start the server on windows via powershell and the first time will ask to set up the security access, just give access on both networks, this is used by wsl to give access to ubuntu client.
                                        2. On linux, if we install the adb via apt install, the adb version will be older and the connection with the server will not work. Should install it via platform-tools provided by Android studio.
                                        3. The cable. Using a micro-usb cable to connect the voxl-cam doesn't work every time, is recommended to use a usb 3 data cable to connect via this usb port.
                                        Once we follow all these, is working fine in all the environments : windows, wsl / ubuntu 20, and mac os 🙂
                                        Thanks for your help!
                                          @marian This is some really good information, thank you so much for your findings!
