  3. How to enable LVDS data streaming on VOXL m500?
7 Posts 2 Posters 1.3k Views 1 Watching
  • yu zhangY Offline
    yu zhangY Offline
    yu zhang
    Hi team,
    I am wondering how to enable LVDS data streaming on VOXL m500 for a fast data transfer? In my case, I would try to connect a sensor that offers LVDS for data streaming on VOXL.
    I am wondering if I could use the below HDMI connector via the J2, and use an HDMI to LVDS adapter to bridge the sensor?
    https://docs.modalai.com/hdmi-input-accessory-datasheet/
    Please advise if there are any other connection solutions to achieve this. Thanks.
    • yu zhangY yu zhang
      Hi team,
      @yu-zhang Unfortunately, ModalAI's HDMI accessory has been discontinued and is no longer available. We do not support an LVDS input.
      yu zhangY 1 Reply Last reply
        yu zhangY Offline
        yu zhangY Offline
        yu zhang
        @Eric-Katzfey I see, so in this case, only the J8 could be used as a USB3.0 port (connecting with a USB3.0 Female A Plug to Micro-B plug) to enable a standard data input, right?
        The sensor I used has a 60pin Samtec connector (the shape is identical as J13 on VOXL but with a different wiring design) offering LVDS data streaming. It requires a throughput rate at 400Mbps - 1Gbps.
        So, I am wondering whether the J8 could handle it if I find a LVDS-to-USB3.0 adapter?
          @yu-zhang J8 is a USB 3.0 OTG (Meaning it can be either master or slave) port. You could certainly use that for data input, but then you would lose your adb port.
            yu zhangY Offline
            yu zhangY Offline
            yu zhang
            @Eric-Katzfey All right, thanks for that!
            I think I could use the extended USB board to enable the adb by a micro USB port. I will then have a try J8.
              @yu-zhang adb works as a USB "device" and attaches to a USB "host" (e.g. your PC). The only port that can act as a USB device is J8. The other ports are USB host only.
                yu zhangY Offline
                yu zhangY Offline
                yu zhang
                @Eric-Katzfey Thanks for reminding me about this 😉 So, I may have to switch to using the J8 in different scenarios.
