  2. Software Development
  3. How to import OpenCV in Python3?
11 Posts 4 Posters 3.4k Views 3 Watching
  • A Offline
    Alex123
    I've installed Python3 on the voxl core-board. I've also installed OpenCV-3.4.6 using https://gitlab.com/voxl-public/other/voxl-opencv-3-4-6
    But I'm unable to access OpenCV in Python3.
    I'm getting an error like this.
    / # python3
    Python 3.6.9 (default, Dec 19 2020, 12:09:26)
    [GCC 4.9.3] on linux
    Type "help", "copyright", "credits" or "license" for more information.
    >>>import cv2
    File "<stdin>", line 1, in <module>
    ModuleNotFoundError: No module named 'cv2'
    Any suggestions would be greatly appreciated!
      Hi @Alex123 ,
      The opencv-3-4-6 project above isn't a python3 package installation rather for c++, for example:
      https://gitlab.com/voxl-public/other/voxl-opencv-3-4-6/-/blob/master/examples/april-tag-detect/april-tag-detect.cpp
      Are you requirements Python3.6.9 and OpenCV 3.X? (let me know specifics if possible).
      If so, do you requirements allow you to run your program in a Docker container on VOXL?
      • A Offline
        Alex123
        Yes, I have to run my program using Python3.6.9 and OpenCV 4.X.
        And it wouldn't allow running a program on Docker container on VOXL.
          The easiest path is to use an Ubuntu Docker container on VOXL. https://docs.modalai.com/docker-on-voxl/
          Otherwise you will have to build the python bindings for OpenCV. We have never tried this, but it looks well documented here: https://docs.opencv.org/master/da/d49/tutorial_py_bindings_basics.html
          A 1 Reply Last reply
          • A Offline
            Alex123
            @Chad-Sweet
            If I'll use an Ubuntu Docker container on VOXL, can you provide documentation or steps using which I can build OpenCV4.x on Python 3.6.9?
            Or a pre-build file of OpenCV4.x for Python3.6.9?
            • A Offline
              Alex123
              How can I use OpenCV4.x with Python3.6.9 using Ubuntu Docker container on VOXL?
                You can use apt to install, follow any normal Ubuntu instructions
                • Chad SweetC Chad Sweet
                  Alex123
                  @Chad-Sweet
                  I'm using the Ubuntu Docker container on VOXL.
                  OpenCV4 in Python3 is working.
                  But I'm facing issues while mounting sdcard on it.
                  I'm referring to this link.
                  I'm using the below command to mount sdcard.
                  docker run -v /mnt/sdcard:/root/yoctohome/:rw -w /root/ roskinetic-xenial:opencv
                  How can I mount a sdcard on the Ubuntu Docker container on VOXL?
                  • A Alex123
                    @Chad-Sweet
                    @Alex123 You should be able to mount the sdcard directory using the following param
                    docker run -v /sdcard:/sdcard
                      Alex123
                      @tom
                      I've tried docker run -v /sdcard:/sdcard, but not working. It's not showing sdcard directory.
                      • tomT Offline
                        @Alex123 here is the exact command I tested with on a VOXL.
                        docker run -it --rm --privileged --net=host --name roskinetic -v /home/root:/root/yoctohome/:rw -v /sdcard:/sdcard -w /root/ roskinetic-xenial:v1.0 /bin/bash
                        Can you try this?
