    How to import OpenCV in Python3?
    Software Development
    2056
    • A
      Alex123
      I've installed Python3 on the voxl core-board. I've also installed OpenCV-3.4.6 using https://gitlab.com/voxl-public/other/voxl-opencv-3-4-6
      But I'm unable to access OpenCV in Python3.
      I'm getting an error like this.
      / # python3
      Python 3.6.9 (default, Dec 19 2020, 12:09:26)
      [GCC 4.9.3] on linux
      Type "help", "copyright", "credits" or "license" for more information.
      >>>import cv2
      Traceback (most recent call last):
      File "<stdin>", line 1, in <module>
      ModuleNotFoundError: No module named 'cv2'
      Any suggestions would be greatly appreciated!
      • modaltbM
        modaltb ModalAI Team
        Hi @Alex123 ,
        The opencv-3-4-6 project above isn't a python3 package installation rather for c++, for example:
        https://gitlab.com/voxl-public/other/voxl-opencv-3-4-6/-/blob/master/examples/april-tag-detect/april-tag-detect.cpp
        Are you requirements Python3.6.9 and OpenCV 3.X? (let me know specifics if possible).
        If so, do you requirements allow you to run your program in a Docker container on VOXL?
        • A
          Alex123
          Yes, I have to run my program using Python3.6.9 and OpenCV 4.X.
          And it wouldn't allow running a program on Docker container on VOXL.
          • Chad SweetC
            Chad Sweet ModalAI Team
            The easiest path is to use an Ubuntu Docker container on VOXL. https://docs.modalai.com/docker-on-voxl/
            Otherwise you will have to build the python bindings for OpenCV. We have never tried this, but it looks well documented here: https://docs.opencv.org/master/da/d49/tutorial_py_bindings_basics.html
            • A
              Alex123
              @Chad-Sweet
              If I'll use an Ubuntu Docker container on VOXL, can you provide documentation or steps using which I can build OpenCV4.x on Python 3.6.9?
              Or a pre-build file of OpenCV4.x for Python3.6.9?
              • A
                Alex123
                How can I use OpenCV4.x with Python3.6.9 using Ubuntu Docker container on VOXL?
                • Chad SweetC
                  You can use apt to install, follow any normal Ubuntu instructions
                  • A
                    Alex123 @Chad Sweet
                    @Chad-Sweet
                    I'm using the Ubuntu Docker container on VOXL.
                    OpenCV4 in Python3 is working.
                    But I'm facing issues while mounting sdcard on it.
                    I'm referring to this link.
                    I'm using the below command to mount sdcard.
                    docker run -v /mnt/sdcard:/root/yoctohome/:rw -w /root/ roskinetic-xenial:opencv
                    How can I mount a sdcard on the Ubuntu Docker container on VOXL?
                      tom admin @Alex123
                      @Alex123 You should be able to mount the sdcard directory using the following param
                      docker run -v /sdcard:/sdcard
                      A 1 Reply Last reply Reply Quote 1
                      • A
                        Alex123 @tom
                        I've tried docker run -v /sdcard:/sdcard, but not working. It's not showing sdcard directory.
                          tom admin
                          @Alex123 here is the exact command I tested with on a VOXL.
                          docker run -it --rm --privileged --net=host --name roskinetic -v /home/root:/root/yoctohome/:rw -v /sdcard:/sdcard -w /root/ roskinetic-xenial:v1.0 /bin/bash
                          Can you try this?
