  3. starling 2 max qvio vs open-vins performance issues
10 Posts 4 Posters 1.3k Views 2 Watching
  • Muqing CaoM Offline
    Muqing CaoM Offline
    Muqing Cao
    HI,
    we are using starling 2 max and are testing the vio performance. Both vio methods performs well in handhold moving tests. We fly the drone manually in a feature-rich indoor environment. Qvio performs ok during takeoff but drifts away after some yawing motions of the drone. Open-vins drifts ~1m downwards during takeoff but maintains well after takeoff.
    We need a good vio performance for indoor test, what is your recommendation? The performance is certainly affected by the imu noise, are there any setups or parameters that we can tune?
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      I would recommend doing a barometer calibration as well via voxl-calibrate-barometer that tends to solve a good chunk of the altitude issues.
      Muqing CaoM 1 Reply Last reply
        Muqing CaoM Offline
        Muqing CaoM Offline
        Muqing Cao
        @Zachary-Lowell-0 Thanks! Indeed we also had the problem of height estimate unstable in px4, we will try barometer calibration.
        But VIO doesnt use barometer and we still need good VIO position. Any suggestion on improving the VIO odometry output?
        zauberflote1Z 1 Reply Last reply
        • Muqing CaoM Muqing Cao
          zauberflote1Z Offline
          zauberflote1
          @Muqing-Cao
          Can you confirm your SDK version?
          • zauberflote1Z zauberflote1
            @Muqing-Cao
            Muqing CaoM Offline
            Muqing CaoM Offline
            Muqing Cao
            @zauberflote1 1.5.1
              @zauberflote1 1.5.1
              zauberflote1
              wrote on last edited by zauberflote1
              @Muqing-Cao
              Please update it to the latest version, 1.6.3.
              PS: 1.6.3 is still in Beta phase, but it should be released soon
                @Muqing-Cao
                Muqing CaoM Offline
                Muqing CaoM Offline
                Muqing Cao
                @zauberflote1 thanks for your info. When will 1.6.3 be released? I see in the instruction that updating sdk will reset all config files, since we use starling 2 max, do we have to change the configs file to the startling-specific configs after update?
                  zauberflote1
                  @Muqing-Cao
                  You should be able to download it and install it, as our betas are now public.
                  @Muqing-Cao said in starling 2 max qvio vs open-vins performance issues:
                  Not necessarily, unless you changed the default values. The new SDK installation will prompt you to identify your platform.
                    @Muqing-Cao
                    Muqing CaoM Offline
                    Muqing CaoM Offline
                    Muqing Cao
                    @zauberflote1 where is beta firmware? I cant find it in the download page.
                      tomT Online
                      tomT Online
                      @Muqing-Cao Here is the latest beta release: https://storage.googleapis.com/platform-beta-releases/voxl2/voxl2_SDK_1.6.3-beta1.tar.gz
