  3. CANT ACCESS CAMERA
CANT ACCESS CAMERA
fpv
8 Posts 2 Posters 4.0k Views 1 Watching
  • T Offline
    T Offline
    taiwohazeez
    HI, I am trying to calibrate my starling 2 drone cameras, but I realized I cant access my cameras from the voxl-portal. On voxl portal, I can see the list of camera pipes, but if I select any one if them, I dont get a footage. I have attached screenshots to make you understand what I mean better. I dont know mcuh about this, could you please point me in the right direction? How can I get it working
    ![alt text](Screenshot from 2025-12-17 11-24-06.png Screenshot from 2025-12-17 12-15-11.png Screenshot from 2025-12-17 12-16-14.png Screenshot from 2025-12-17 12-32-28.png )
    • T Offline
      T Offline
      taiwohazeez
      Hello Support,
      Can anyone kindly look into this please?
      I tried it accessing the cameras today from the voxl portal, it showed live footage at first, then it crashed. Can you kindly assist.
      • T taiwohazeez
        Hello Support,
        @taiwohazeez ,
        Please try the following after a fresh reboot:
        voxl-inspect-cam tracking_down tracking_front tracking_rear tof_ir hires_small_color
        Running voxl-inspect-cam -a can break the camera server because there are too many output streams to process. This used to be a good option in the past for a quick test, but with 5 cameras and ~25 streams this is becoming too heavy. In normal use cases, only one stream is used from each camera.
        If you are just getting started, I would suggest updating your drone to at least SDK 1.5 or even 1.6, however you should still be able to get camera streams displayed in voxl-portal or using the limited voxl-inspect-cam command.
        If you still cannot get this to work, please do the following to stop the background service for voxl-camera-server and run in in the foreground and past the output:
        #stop the background service (it will restart after reboot)
        systemctl stop voxl-camera-server
        #run camera server in foreground
        voxl-camera-server
        T 1 Reply Last reply
          @taiwohazeez ,
          voxl-camera-server
          T Offline
          T Offline
          taiwohazeez
          @Alex-Kushleyev Thank you for the response. After fresh reboot the camera pipes functions for a little while and stops immediately (I can see it in voxl-portal, then they keep disappearing until i am left with tag_overlay and multi-view
          • T taiwohazeez
            @taiwohazeez ,
            Can you please confirm that you only inspected several pipes using the command:
            Also please use voxl-inspect-cpu to check if the cpu is overheating during your testing.
            Additionally, are you able to provide output of voxl-camera-server (running in the foreground) when the pipes start disappearing?
            If you are able to update to the latest SDK (1.6.x) , it may be easier for us to support, as 1.4.5 is 7 months old.
            T 2 Replies Last reply
              @taiwohazeez ,
              T Offline
              T Offline
              taiwohazeez
              @Alex-Kushleyev I updated to SDK 1.62 already, and yes I only inspected using voxl-inspect-cam tracking_down tracking_front tracking_rear tof_ir hires_small_color.
              After running that, I got this (empty response), and when you Ctrl C, you get waiting for server
              This is the output after I ran voxl-inspect-cpu
              After running voxl-camera-server, i got this:
              voxl2:/$ voxl-camera-server
              Setting MISP AWB to Auto
              MISP channels enabled in defaults : 0
              MISP channels enabled in config file: 0
              detected system image 1.8.6
              using new imx412 defaults
              configuration for 5 cameras:
              cam #0
              type: ar0144
              bayer_type: 0
              enabled: 1
              camera_id: 0
              camera_id_second: -1
              fps: 30
              en_rotate: 1
              en_rotate2: 0
              en_preview:          1
              en_raw_preview:      1
              preview_width:       1280
              preview_height:      800
              en_misp:             0
              misp_width:          1280
              misp_height:         800
              en_small_video:      0
              small_video_width:   -1
              small_video_height:  -1
              en_large_video:      0
              large_video_width:   -1
              large_video_height:  -1
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              exif_focal_length:   0.000000
              exif_focal_len_35mm_format:0
              exif_fnumber:        0.000000
              ae_mode:             lme_msv
              msv_exposure_min_us: 20
              msv_exposure_max_us: 12000
              gain_min           : 54
              gain_max           : 8000
              standby_enabled:     0
              decimator:           1
              independent_exposure:0
              cam #1
              type: imx412
              bayer_type: 2
              enabled: 1
              camera_id: 1
              fps: 30
              en_rotate: 0
              en_rotate2: 0
              en_preview:          0
              en_raw_preview:      0
              preview_width:       640
              preview_height:      480
              en_misp:             0
              misp_width:          -1
              misp_height:         -1
              en_small_video:      1
              small_video_width:   1024
              small_video_height:  768
              en_large_video:      1
              large_video_width:   4056
              large_video_height:  3040
              en_snapshot:         1
              snap_width:          4056
              snap_height:         3040
              exif_focal_length:   3.100000
              exif_focal_len_35mm_format:17
              exif_fnumber:        1.240000
              ae_mode:             isp
              msv_exposure_max_us: 33000
              gain_min           : 54
              gain_max           : 8000
              standby_enabled:     0
              decimator:           1
              cam #2
              type: ar0144
              bayer_type: 0
              enabled: 1
              camera_id: 2
              fps: 30
              en_rotate: 1
              en_rotate2: 0
              en_preview:          1
              en_raw_preview:      1
              preview_width:       1280
              preview_height:      800
              en_misp:             1
              misp_width:          1280
              misp_height:         800
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              gain_min           : 54
              gain_max           : 8000
              standby_enabled:     0
              decimator:           1
              cam #3
              type: pmd-tof-liow2
              bayer_type: 0
              enabled: 1
              camera_id: 3
              fps: 10
              en_rotate: 1
              en_rotate2: 0
              en_preview:          1
              en_raw_preview:      1
              preview_width:       240
              preview_height:      1629
              en_misp:             0
              misp_width:          -1
              misp_height:         -1
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             off
              msv_exposure_min_us: 0
              msv_exposure_max_us: 6000
              gain_min           : 0
              gain_max           : 0
              standby_enabled:     0
              decimator:           5
              cam #4
              type: ar0144
              bayer_type: 0
              enabled: 1
              camera_id: 4
              fps: 30
              en_rotate: 0
              en_rotate2: 0
              en_preview:          1
              en_raw_preview:      1
              preview_width:       1280
              preview_height:      800
              en_misp:             1
              misp_width:          1280
              misp_height:         800
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              gain_min           : 54
              gain_max           : 8000
              standby_enabled:     0
              decimator:           1
              fsync_en: 1
              fsync_gpio: 109
              thread is locked to cores: 4 5 6 7
              connected to mavlink pipe
              Connected to cpu-monitor
              Starting Camera: tracking_front (id #0)
              Starting Camera: hires (id #1)
              Estimated imu dt = 0.000977s
              Starting Camera: tracking_rear (id #2)
              ERROR: Received Fatal error from camera: tracking_front
              ERROR: Sending request 10, ErrorCode: -ENODEV
              ERROR: Received "Result" error from camera: tracking_front, frame number 4
              WARNING: Thread: tracking_front request thread Received ESTOP
              WARNING: Thread: tracking_front result thread Received ESTOP
              WARNING: Thread: hires result thread Received ESTOP
              WARNING: Thread: hires request thread Received ESTOP
              MISP Initializing for camera tracking_rear
              Detected 1 platform(s)
              Detected 1 GPU device(s)
              WARNING: OMX SetTargetBitrate: H265 CBR requires bps >= 3.0Mbit (1200000 bps provided). Using FPS hack. scale = 2.500000
              Starting Camera: tof (id #3)
              Starting Camera: tracking_down (id #4)
              MISP Initializing for camera tracking_down
              ------ voxl-camera-server: Started 5 of 5 cameras
              ------ voxl-camera-server: Camera server is now stopping
              Stats For Camera tracking_front:
              Received Frame Count: 10
              Request Error Count: 0
              Buffer Error Count: 0
              Result Error Count: 1
              ERROR: Received "Result" error from camera: tracking_down, frame number 0
              ERROR: Received "Buffer" error from camera: tracking_down, frame number 0
              ERROR: Received Fatal error from camera: tracking_down
              ERROR: Sending request 6, ErrorCode: -ENODEV
              WARNING: Pushed buffers back to pools for frame: 0
              WARNING: Thread: tracking_down request thread Received ESTOP
              WARNING: Thread: tof result thread Received ESTOP
              WARNING: Thread: tracking_rear result thread Received ESTOP
              WARNING: Thread: tracking_down result thread Received ESTOP
              WARNING: Thread: tracking_rear request thread Received ESTOP
              Stats For Camera hires:
              Received Frame Count: 6
              Result Error Count: 0
              Stats For Camera tracking_rear:
              Received Frame Count: 0
              WARNING: Thread: tof request thread Received ESTOP
              Stats For Camera tof:
              Stats For Camera tracking_down:
              Buffer Error Count: 1
              ------ voxl-camera-server: Camera server exited gracefully, returning 0
              IMU Manager closing and exiting
              voxl2:/$
                @taiwohazeez ,
                T Offline
                T Offline
                taiwohazeez
                @Alex-Kushleyev Also, when you run voxl-inspect-services, voxl-camera-server will be enables but not running, Immediately i start it, it runs and stops almost immediately
                • T taiwohazeez
                  @taiwohazeez ,
                  Once thing i noticed is that you don't have en_misp set to 1 for the tracking_front camera. I don't think this is the reason for the failure, but it should be set to 1.
                  Meanwhile, please try to identify which camera is causing the issue by disabling cameras and testing camera server ( you can set enabled flag to 0, so that this camera is not started.
                  Also, when you installed SDK 1.6.2, did you run voxl-configure-cameras and which option did you select for the camera configuration?
