  3. VOXL2 J19 QUP3
VOXL2 J19 QUP3
24 Posts 2 Posters 2.8k Views 1 Watching
  • voxltesterV Offline
    voxltesterV Offline
    voxltester
    I connected Lightware LW20/C on one of the I2C port on VOXL2 J19.
    It is QUP3, and the pins I used are
    7	I2C3 SDA 3P3V	slpi_proc, SSC_QUP3
    8	I2C3 SCL 3P3V	slpi_proc, SSC_QUP3
    and power & ground.
    I also installed a customized voxl-px4 which will start lightware_laser_i2c with the I2C address 0x66.
    On VOXL2, I edited voxl-px4.conf file by adding DISTANCE_SENSOR=LIGHTWARE_SF000.
    However, I cannot see any parameter regarding rangefinder... like SENS_EN_SF1XX.
    I have done using LW20/C with UART connection successfully, but I2C does not work..
    Can anyone give me any advise to use it via I2C?
    • voxltesterV voxltester
      and power & ground.
      @voxltester That is not a normal option to choose via voxl-px4.conf. You will need to hand modify the startup script /usr/bin/voxl-px4-start to properly start the driver in i2c mode. Use option -b 4 to select that i2c bus.
      voxltesterV 1 Reply Last reply
        voxltesterV Offline
        voxltesterV Offline
        voxltester
        wrote on last edited by voxltester
        @Eric-Katzfey
        Hi, Eric.
        I tried
        qshell lightware_laser_i2c start -a 0x66 # I2C address 102
        it did not work..
        So are you meaning
        qshell lightware_laser_serial start -b 4
        or
        qshell lightware_laser_i2c start -b 4
          @Eric-Katzfey
          Hi, Eric.
          I tried
          it did not work..
          So are you meaning
          or
          @voxltester I would try qshell lightware_laser_i2c start -b 4
            voxltesterV Offline
            voxltesterV Offline
            voxltester
            @Eric-Katzfey
            Eric, this is not working...
            Please refer to the driver for i2c....
            https://github.com/modalai/px4-firmware/blob/main/src/drivers/distance_sensor/lightware_laser_i2c/lightware_laser_i2c.cpp
            Default i2c address is defined 0x66 (102) in this code.
            I am wondering what is the i2c address of the VOXL2 J19 - QUP3 port.
            I am not familiar with the above cpp driver code... could you please have a look the code and teach me how to enable the i2c connection for the lightware rangefinder?
            Thank you in advance....
              @Eric-Katzfey
              @voxltester We have never used the device that you are connecting so I am only offering suggestions to help out. When speaking of i2c addresses it is related to the device being attached to the bus, not the bus itself. You can attach multiple i2c devices to the same i2c bus if they have different addresses. But, there are multiple i2c buses to choose from. So, address 0x66 (which is default for that device and doesn't need to be specified on the command line) is for the device and port 4 specifies which i2c bus it is connected to. Also, please look at this file: https://github.com/modalai/px4-firmware/blob/main/src/drivers/distance_sensor/lightware_laser_i2c/parameters.c. There are 2 parameters that need to be set properly for the driver to work. If the default values are not correct then you will need to set them accordingly. For SENS_EN_SF1XX it should be set to 6 for LW20/c.
                voxltesterV Offline
                voxltesterV Offline
                voxltester
                @Eric-Katzfey
                Understood. I just figured out address and bus. I am sorry for disturbing you for the basic concept.
                Now, I am trying to run it with SENS_EN_SF1XX=6, the command in px4-start is just qshell lightware_laser_i2c start.
                By the way, I am wondering where the bus info is described in the driver cpp file. Should I change the code? Because lightware_laser_i2c accepts only R as an option..
                  @Eric-Katzfey
                  @voxltester It's all done in the base class. See: https://github.com/modalai/px4-firmware/blob/main/platforms/common/i2c_spi_buses.cpp
                    voxltesterV Offline
                    voxltesterV Offline
                    voxltester
                    @Eric-Katzfey
                    the versions of px4 are different...
                    I am git clone from https://gitlab.com/voxl-public/voxl-sdk/services/voxl-px4
                    in which there is only one parameter in https://github.com/modalai/px4-firmware/tree/0a47ec5d8650f4e97f1eb929405df5dcdb91989f/src/drivers/distance_sensor/lightware_laser_i2c
                    Anyway, qshell lightware_laser_i2c start is not working with I2C port on VOXL2 J19 - QUP3
                      @Eric-Katzfey
                      @voxltester Why are you not adding -b 4?
                      voxltesterV 2 Replies Last reply
                        voxltesterV Offline
                        voxltesterV Offline
                        voxltester
                          voxltesterV Offline
                          voxltesterV Offline
                          voxltester
                          @Eric-Katzfey
                          Sorry for the slow response.
                          qshell lightware_laser_i2c start -b 4?
                          No. Not working.
                          Please see
                          https://github.com/modalai/px4-firmware/blob/f18864f2e6460e4d2d3d1572d09ee09028c63789/src/drivers/distance_sensor/lightware_laser_i2c/lightware_laser_i2c.cpp
                          I do not think the -b option is not implemented in the driver source code.
                          Can you confirming that -b 4 is for I2C port on VOXL2 J19 - QUP3? (https://docs.modalai.com/voxl2-connectors/#j19---external-sensors-2x-uart-2x-i2c)
                          I am trying to modify the driver code to have the bus information.
                            @Eric-Katzfey
                            No. Not working.
                            Please see
                            @voxltester I tried to explain this in one of my previous responses. Let me add more detail. lightware_laser_i2c.cpp is C++ code. The class LightwareLaser has a couple of base classes. One of them is I2CSPIDriver, so it "inherits" the functionality of that class. That class is implemented in i2c_spi_buses.cpp. It uses BusCLIArguments to parse the command line options. That's where the -b option is dealt with.
                              @Eric-Katzfey
                              No. Not working.
                              Please see
                              @voxltester Yes, bus 4 corresponds to pins 7 and 8 on J19. I would put an oscilloscope on the data pin and see if you detect any activity when you start the driver to verify.
                                @Eric-Katzfey
                                No. Not working.
                                Please see
                                @voxltester And, in general, for all software engineers out there here is a helpful tip. ModalAI is not affiliated with Anthropic in any way but I do want to highlight their Claude Code tool. It can really help you not just write code, but to understand code that is already there. So, for example, in this post there is a question about how the -b option is parsed. It's a bit complicated how all of the pieces fit together but if you were to ask Claude this question: "I'm using the device driver in the file lightware_laser_i2c.cpp. I was told that the LightwareLaser class can take the command line option -b to specify the i2c bus number using the start command. Can you show me where in the code the -b option is parsed?". Claude will then give you this answer:
                                The -b option is not parsed directly in this file. Looking at the code:
                                  At line 450, the custom option parsing only handles -R for rotation:
                                  while ((ch = cli.getOpt(argc, argv, "R:")) != EOF) {
                                      switch (ch) {
                                      case 'R':
                                          cli.rotation = (Rotation)atoi(cli.optArg());
                                          break;
                                  The -b option (for I2C bus number) is handled automatically by the BusCLIArguments class, which is instantiated at line 445:
                                  BusCLIArguments cli{true, false};
                                  This class is included from <px4_platform_common/i2c_spi_buses.h> (line 47). The cli.getOpt() method internally processes standard I2C/SPI options like -b (bus), -a (address), etc., before returning custom options like -R to this driver's switch statement.
                                  If you want to see where -b is actually parsed, you'd need to look at the BusCLIArguments class implementation in the PX4 platform common library:
                                  src/lib/drivers/device/posix/i2c_spi_buses.cpp
                                  or
                                  The PRINT_MODULE_USAGE_PARAMS_I2C_SPI_DRIVER(true, false) call at line 435 documents that this driver accepts I2C options (including -b), but the actual parsing is abstracted away in the shared bus infrastructure.
                                        switch (ch) {
                                        case 'R':
                                            break;
                                    or
                                  voxltesterV Offline
                                  voxltesterV Offline
                                  voxltester
                                          switch (ch) {
                                          case 'R':
                                              break;
                                      or
                                    voxltesterV Offline
                                    voxltesterV Offline
                                    voxltester
                                    #17
                                    @Eric-Katzfey
                                    Thank you for the info...
                                    I figured out the connection cannot be detected on the port at all..
                                     $ i2cdetect -y -r 4
                                         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                                    00:          -- -- -- -- -- -- -- -- -- -- -- -- --
                                    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                    70: -- -- -- -- -- -- -- --
                                    FYI,
                                    pxh> lightware_laser_i2c start -b 4
                                    ERROR [SPI_I2C] need to specify a bus type
                                    ### Description
                                    I2C bus driver for Lightware SFxx series LIDAR rangefinders: SF10/a, SF10/b, SF10/c, SF11/c, SF/LW20.
                                    Setup
                                    Usage: lightware_laser_i2c <command> [arguments...]
                                     Commands:
                                       start
                                         [-I]        Internal I2C bus(es)
                                         [-X]        External I2C bus(es)
                                         [-b <val>]  board-specific bus (default=all) (external SPI: n-th bus (default=1))
                                         [-f <val>]  bus frequency in kHz
                                         [-q]        quiet startup (no message if no device found)
                                         [-a <val>]  I2C address
                                                     default: 102
                                         [-R <val>]  Sensor rotation - downward facing by default
                                                     default: 25
                                       stop
                                       status        print status info
                                    Command 'lightware_laser_i2c' failed, returned -1.
                                    pxh> lightware_laser_i2c start -X -b 4
                                    WARN  [SPI_I2C] mavlink_shell: no instance started (no device on bus?)
                                      @Eric-Katzfey
                                       $ i2cdetect -y -r 4
                                      FYI,
                                      ### Description
                                      Setup
                                       Commands:
                                         start
                                                       default: 102
                                                       default: 25
                                         stop
                                      @voxltester i2cdetect is looking for i2c ports on the apps processor so it isn't useful for this where we are trying to use DSP i2c ports. It shows an error message. Can you add the -X option to see if that resolves that error condition?
                                        voxltesterV Offline
                                        voxltesterV Offline
                                        voxltester
                                        #19
                                        @Eric-Katzfey
                                        Isn't this I2C (J19 7&8) APP I2C or DPS I2C?
                                        Is it possible to access DPS I2C from PX4?
                                        Please see the outputs of the -X and -I options.
                                        WARN  [SPI_I2C] UnknownApp: no instance started (no device on bus?)
                                        pxh> lightware_laser_i2c start -I -b 4
                                        FYI, the following is an initialization of the VOXL-PX4.
                                        voxl2:~$ voxl-px4 -d
                                        Found DSP signature file
                                        [INFO] Disabling daemon mode
                                        AIRFRAME=MULTICOPTER
                                        GPS=AUTODETECT
                                        RC=GHST
                                        ESC=VOXL_ESC
                                        POWER MANAGER=NONE
                                        AIRSPEED SENSOR=NONE
                                        DISTANCE SENSOR=LIGHTWARE_SF000
                                        OSD=DISABLE
                                        DAEMON_MODE=DISABLE
                                        SENSOR_CAL=ACTUAL
                                        ARTIFACT_MODE=DISABLE
                                        EXTRA STEPS:
                                        INFO  [muorb] [modules__muorb__slpi] muorb aggregator thread running
                                        INFO  [muorb] [modules__muorb__slpi] muorb keepalive thread running
                                        INFO  [muorb] [tasks] Creating pthread test_MUORB
                                        INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097656
                                        INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097655
                                        INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097654
                                        INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097653
                                        ______  __   __    ___
                                        | ___ \ \ \ / /   /   |
                                        | |_/ /  \ V /   / /| |
                                        |  __/   /   \  / /_| |
                                        | |     / /^\ \ \___  |
                                        \_|     \/   \/     |_/
                                        px4 starting.
                                        INFO  [muorb] [uORB] Advertising remote topic log_message
                                        AIRFRAME: MULTICOPTER
                                        GPS: AUTODETECT
                                        RC: GHST
                                        ESC: VOXL_ESC
                                        POWER MANAGER: NONE
                                        AIRSPEED SENSOR: NONE
                                        DISTANCE SENSOR: LIGHTWARE_SF000
                                        OSD: DISABLE
                                        ARTIFACT_MODE: DISABLE
                                        EXTRA STEPS:
                                        INFO  [muorb] [parameters] Starting param sync THREAD
                                        Running on M0054
                                        INFO  [muorb] [qshell] before starting the qshell_entry task
                                        INFO  [muorb] [tasks] Creating pthread qshell
                                        INFO  [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652
                                        INFO  [muorb] [qshell] qshell entry.....
                                        INFO  [muorb] [qshell] after starting the qshell_entry task
                                        INFO  [muorb] [qshell] Init app map initialized
                                        INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                                        INFO  [muorb] [uORB] Advertising remote topic parameter_update
                                        INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t
                                        INFO  [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t
                                        INFO  [parameters] BSON document size 3307 bytes, decoded 3307 bytes (INT32:44, FLOAT:109)
                                        INFO  [qshell] Send cmd: 'icm42688p start -s'
                                        INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                                        INFO  [muorb] [qshell] qshell gotten: icm42688p start -s
                                        INFO  [muorb] [qshell]   arg0 = 'icm42688p'
                                        INFO  [muorb] [qshell]   arg1 = 'start'
                                        INFO  [muorb] [qshell]   arg2 = '-s'
                                        INFO  [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
                                        INFO  [muorb] [icm42688p] ICM42688P::probe successful!
                                        INFO  [muorb] [drivers__device] on SPI bus 1
                                        INFO  [muorb] icm42688p #0 on SPI bus 1
                                        INFO  [muorb]
                                        INFO  [muorb] [icm42688p] >>> ICM42688P this: b26024d8
                                        INFO  [muorb] [qshell] Ok executing command: icm42688p start -s
                                        INFO  [qshell] qshell return value timestamp: 83014023, local time: 83018955
                                        Looking for external DPS368 barometer
                                        INFO  [muorb] [drivers__device] Register interrupt b214f094 e612a80c b26024d8
                                        INFO  [uORB] Advertising remote topic sensor_gyro_fifo
                                        INFO  [uORB] Advertising remote topic sensor_accel_fifo
                                        ERROR [dps310] Product_ID mismatch
                                        Looking for external ICP10100 barometer
                                        Did not detect an external barometer, starting onboard ICP10100 barometer
                                        INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
                                        INFO  [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
                                        INFO  [muorb] [qshell]   arg0 = 'icp101xx'
                                        INFO  [muorb] [qshell]   arg2 = '-I'
                                        INFO  [muorb] [qshell]   arg3 = '-b'
                                        INFO  [muorb] [qshell]   arg4 = '5'
                                        INFO  [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
                                        INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 5
                                        INFO  [muorb] icp101xx #0 on I2C bus 5
                                        INFO  [muorb]  address 0x63
                                        INFO  [muorb]
                                        INFO  [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
                                        INFO  [qshell] qshell return value timestamp: 83111693, local time: 83114593
                                        INFO  [qshell] Send cmd: 'temperature_compensation start'
                                        INFO  [muorb] [qshell] qshell gotten: temperature_compensation start
                                        INFO  [muorb] [qshell]   arg0 = 'temperature_compensation'
                                        INFO  [uORB] Advertising remote topic sensor_correction
                                        INFO  [muorb] [qshell] Ok executing command: temperature_compensation start
                                        INFO  [qshell] qshell return value timestamp: 83262606, local time: 83264812
                                        INFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
                                        INFO  [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
                                        INFO  [muorb] [qshell]   arg0 = 'qmc5883l'
                                        INFO  [muorb] [qshell]   arg2 = '-R'
                                        INFO  [muorb] [qshell]   arg3 = '10'
                                        INFO  [muorb] [qshell]   arg4 = '-X'
                                        INFO  [muorb] [qshell]   arg5 = '-b'
                                        INFO  [muorb] [qshell]   arg6 = '1'
                                        INFO  [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
                                        INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 1
                                        ERROR [muorb] [drivers__device] i2c probe failed
                                        INFO  [muorb] [SPI_I2C] PX4_qshell: no instance started (no device on bus?)
                                        ERROR [muorb] [qshell] Failed to execute command: qmc5883l start -R 10 -X -b 1
                                        INFO  [qshell] cmd returned with: -1
                                        INFO  [qshell] qshell return value timestamp: 83324177, local time: 83325854
                                        ERROR [qshell] Command failed
                                        INFO  [uORB] Advertising remote topic sensor_baro
                                        INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
                                        INFO  [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
                                        INFO  [muorb] [qshell]   arg0 = 'ist8310'
                                        INFO  [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
                                        ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R 10 -X -b 1
                                        INFO  [qshell] qshell return value timestamp: 83374408, local time: 83377531
                                        Looking for ist8308 magnetometer
                                        INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
                                        INFO  [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
                                        INFO  [muorb] [qshell]   arg0 = 'ist8308'
                                        INFO  [muorb] [qshell]   arg3 = '12'
                                        INFO  [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
                                        ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R 12 -X -b 1
                                        INFO  [qshell] qshell return value timestamp: 83413213, local time: 83416595
                                        INFO  [muorb] [qshell] qshell gotten: gps start
                                        INFO  [muorb] [qshell]   arg0 = 'gps'
                                        INFO  [muorb] [tasks] Creating pthread gps
                                        INFO  [muorb] [tasks] Successfully created px4 task PX4_gps with tid 2097645
                                        INFO  [muorb] [qshell] Ok executing command: gps start
                                        INFO  [qshell] qshell return value timestamp: 83445422, local time: 83446602
                                        Looking for ncp5623c RGB LED
                                        INFO  [muorb] [gps] GPS UART baudrate set to 115200
                                        INFO  [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                                        INFO  [muorb] [qshell] qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                                        INFO  [muorb] [qshell]   arg0 = 'rgbled_ncp5623c'
                                        INFO  [muorb] [qshell]   arg2 = '-X'
                                        INFO  [muorb] [qshell]   arg4 = '1'
                                        INFO  [muorb] [qshell]   arg5 = '-f'
                                        INFO  [muorb] [qshell]   arg6 = '400'
                                        INFO  [muorb] [qshell]   arg7 = '-a'
                                        INFO  [muorb] [qshell]   arg8 = '56'
                                        INFO  [muorb] [drivers__device] *** I2C Device ID 0x7b3809 8075273
                                        INFO  [muorb] [drivers__device] Set i2c address 0x38, fd 4
                                        ERROR [muorb] [qshell] Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                                        INFO  [qshell] qshell return value timestamp: 83487606, local time: 83489160
                                        Starting VOXL ESC driver
                                        INFO  [qshell] Send cmd: 'voxl_esc start'
                                        INFO  [muorb] [qshell] qshell gotten: voxl_esc start
                                        INFO  [muorb] [qshell]   arg0 = 'voxl_esc'
                                        INFO  [uORB] Advertising remote topic actuator_outputs
                                        INFO  [muorb] [voxl_esc] Starting VOXL ESC driver
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_CONFIG: 1
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_MODE: 0
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_BAUD: 2000000
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC1: 102
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC2: 103
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC3: 101
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC4: 104
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR1: 0
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR2: 0
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR3: 0
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR4: 0
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_PWR_MIN: 0.050000
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MIN: 2000
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MAX: 12000
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_PERC: 90
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_VLOG: 1
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_WARN: 0
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_OVER: 0
                                        INFO  [muorb] [voxl_esc] Params: GPIO_CTL_CH: 0
                                        INFO  [muorb] [voxl_esc] Params: VOXL_ESC_CMD: 0
                                        INFO  [muorb] [qshell] Ok executing command: voxl_esc start
                                        INFO  [muorb] [voxl_esc] Opening UART ESC device 2, baud rate 2000000
                                        INFO  [muorb] [voxl_esc] Successfully opened UART ESC device
                                        INFO  [muorb] [voxl_esc] Detecting ESCs...
                                        INFO  [muorb] [voxl_esc] 	ESC ID     : 0
                                        INFO  [muorb] [voxl_esc] 	Board Type : 40: ModalAi 4-in-1 ESC (M0129-3)
                                        INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0024
                                        INFO  [muorb] [voxl_esc] 	Firmware   : version   39, hash 9c6233d6
                                        INFO  [muorb] [voxl_esc] 	Bootloader : version  184, hash 10bf24c8
                                        INFO  [muorb] [voxl_esc] 	Reply time : 723us
                                        INFO  [muorb] [voxl_esc] VOXL_ESC:
                                        INFO  [muorb] [voxl_esc] 	ESC ID     : 1
                                        INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0028
                                        INFO  [muorb] [voxl_esc] 	Reply time : 728us
                                        INFO  [qshell] qshell return value timestamp: 83652589, local time: 83657098
                                        INFO  [muorb] [voxl_esc] 	ESC ID     : 2
                                        INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0026
                                        INFO  [muorb] [voxl_esc] 	Reply time : 718us
                                        INFO  [muorb] [voxl_esc] 	ESC ID     : 3
                                        INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0022
                                        INFO  [muorb] [voxl_esc] 	Reply time : 739us
                                        INFO  [muorb] [voxl_esc] Use extended rpm packet : 1
                                        INFO  [muorb] [voxl_esc] All ESCs successfully detected
                                        Starting GHST RC driver
                                        INFO  [qshell] Send cmd: 'ghst_rc start -d 7'
                                        INFO  [muorb] [qshell] qshell gotten: ghst_rc start -d 7
                                        INFO  [muorb] [qshell]   arg0 = 'ghst_rc'
                                        INFO  [uORB] Advertising remote topic actuator_outputs_debug
                                        INFO  [uORB] Advertising remote topic esc_status
                                        INFO  [muorb] [qshell]   arg2 = '-d'
                                        INFO  [muorb] [qshell]   arg3 = '7'
                                        INFO  [muorb] [qshell] Ok executing command: ghst_rc start -d 7
                                        INFO  [uORB] Advertising remote topic input_rc
                                        INFO  [qshell] qshell return value timestamp: 83712270, local time: 83715195
                                        INFO  [qshell] Send cmd: 'lightware_laser_i2c start -b 4'
                                        INFO  [muorb] [qshell] qshell gotten: lightware_laser_i2c start -b 4
                                        ERROR [muorb] [qshell] Command lightware_laser_i2c not found
                                        ERROR [muorb] [qshell] Failed to execute command: lightware_laser_i2c start -b 4
                                        INFO  [qshell] cmd returned with: 1
                                        INFO  [qshell] qshell return value timestamp: 83743015, local time: 83745263
                                        INFO  [qshell] Send cmd: 'sensors start'
                                        INFO  [muorb] [qshell] qshell gotten: sensors start
                                        INFO  [muorb] [qshell]   arg0 = 'sensors'
                                        INFO  [uORB] Advertising remote topic sensor_selection
                                        INFO  [uORB] Advertising remote topic sensors_status_imu
                                        INFO  [muorb] [modules__muorb__slpi] Deleting /data/px4/slpi/keepalive_fail
                                        INFO  [uORB] Advertising remote topic vehicle_acceleration
                                        INFO  [uORB] Advertising remote topic vehicle_angular_velocity
                                        INFO  [uORB] Advertising remote topic sensor_combined
                                        INFO  [uORB] Advertising remote topic battery_status
                                        INFO  [uORB] Advertising remote topic vehicle_air_data
                                        INFO  [uORB] Advertising remote topic vehicle_gps_position
                                        INFO  [uORB] Advertising remote topic vehicle_magnetometer
                                        INFO  [uORB] Advertising remote topic sensor_preflight_mag
                                        INFO  [uORB] Advertising remote topic vehicle_imu
                                        INFO  [uORB] Advertising remote topic vehicle_imu_status
                                        INFO  [muorb] [qshell] Ok executing command: sensors start
                                        INFO  [qshell] qshell return value timestamp: 83931906, local time: 83935646
                                        INFO  [uORB] Advertising remote topic sensors_status_baro
                                        INFO  [qshell] Send cmd: 'ekf2 start'
                                        INFO  [muorb] [qshell] qshell gotten: ekf2 start
                                        INFO  [muorb] [qshell]   arg0 = 'ekf2'
                                        INFO  [uORB] Advertising remote topic vehicle_attitude
                                        INFO  [uORB] Advertising remote topic vehicle_local_position
                                        INFO  [uORB] Advertising remote topic estimator_event_flags
                                        INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
                                        INFO  [uORB] Advertising remote topic estimator_innovation_variances
                                        INFO  [uORB] Advertising remote topic estimator_innovations
                                        INFO  [uORB] Advertising remote topic estimator_sensor_bias
                                        INFO  [uORB] Advertising remote topic estimator_states
                                        INFO  [uORB] Advertising remote topic estimator_status_flags
                                        INFO  [muorb] [qshell] Ok executing command: ekf2 start
                                        INFO  [qshell] qshell return value timestamp: 84173695, local time: 84177522
                                        INFO  [uORB] Advertising remote topic ekf2_timestamps
                                        INFO  [uORB] Advertising remote topic vehicle_odometry
                                        INFO  [uORB] Advertising remote topic estimator_aid_src_baro_hgt
                                        INFO  [uORB] Advertising remote topic estimator_aid_src_fake_pos
                                        INFO  [uORB] Advertising remote topic estimator_aid_src_fake_hgt
                                        INFO  [uORB] Advertising remote topic estimator_aid_src_gravity
                                        INFO  [qshell] Send cmd: 'mc_pos_control start'
                                        INFO  [muorb] [qshell] qshell gotten: mc_pos_control start
                                        INFO  [muorb] [qshell]   arg0 = 'mc_pos_control'
                                        INFO  [uORB] Advertising remote topic takeoff_status
                                        INFO  [muorb] [qshell] Ok executing command: mc_pos_control start
                                        INFO  [qshell] qshell return value timestamp: 84266732, local time: 84268823
                                        INFO  [qshell] Send cmd: 'mc_att_control start'
                                        INFO  [muorb] [qshell] qshell gotten: mc_att_control start
                                        INFO  [muorb] [qshell]   arg0 = 'mc_att_control'
                                        INFO  [muorb] [qshell] Ok executing command: mc_att_control start
                                        INFO  [qshell] qshell return value timestamp: 84320268, local time: 84321796
                                        INFO  [qshell] Send cmd: 'mc_rate_control start'
                                        INFO  [muorb] [qshell] qshell gotten: mc_rate_control start
                                        INFO  [muorb] [qshell]   arg0 = 'mc_rate_control'
                                        INFO  [uORB] Advertising remote topic rate_ctrl_status
                                        INFO  [muorb] [qshell] Ok executing command: mc_rate_control start
                                        INFO  [qshell] qshell return value timestamp: 84408066, local time: 84410267
                                        INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                                        INFO  [muorb] [qshell] qshell gotten: mc_hover_thrust_estimator start
                                        INFO  [muorb] [qshell]   arg0 = 'mc_hover_thrust_estimator'
                                        INFO  [muorb] [qshell] Ok executing command: mc_hover_thrust_estimator start
                                        INFO  [qshell] qshell return value timestamp: 84462789, local time: 84464375
                                        INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
                                        INFO  [muorb] [qshell] qshell gotten: mc_autotune_attitude_control start
                                        INFO  [muorb] [qshell]   arg0 = 'mc_autotune_attitude_control'
                                        INFO  [uORB] Advertising remote topic autotune_attitude_control_status
                                        INFO  [muorb] [qshell] Ok executing command: mc_autotune_attitude_control start
                                        INFO  [qshell] qshell return value timestamp: 84514600, local time: 84516557
                                        INFO  [qshell] Send cmd: 'land_detector start multicopter'
                                        INFO  [muorb] [qshell] qshell gotten: land_detector start multicopter
                                        INFO  [muorb] [qshell]   arg0 = 'land_detector'
                                        INFO  [muorb] [qshell]   arg2 = 'multicopter'
                                        INFO  [muorb] [qshell] Ok executing command: land_detector start multicopter
                                        INFO  [qshell] qshell return value timestamp: 84553505, local time: 84556075
                                        INFO  [uORB] Advertising remote topic vehicle_land_detected
                                        INFO  [qshell] Send cmd: 'manual_control start'
                                        INFO  [muorb] [qshell] qshell gotten: manual_control start
                                        INFO  [muorb] [qshell]   arg0 = 'manual_control'
                                        INFO  [muorb] [qshell] Ok executing command: manual_control start
                                        INFO  [qshell] qshell return value timestamp: 84597175, local time: 84598418
                                        INFO  [uORB] Advertising remote topic manual_control_setpoint
                                        INFO  [qshell] Send cmd: 'control_allocator start'
                                        INFO  [muorb] [qshell] qshell gotten: control_allocator start
                                        INFO  [muorb] [qshell]   arg0 = 'control_allocator'
                                        INFO  [uORB] Advertising remote topic control_allocator_status
                                        INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                                        INFO  [uORB] Advertising remote topic actuator_motors
                                        INFO  [uORB] Advertising remote topic actuator_servos
                                        INFO  [uORB] Advertising remote topic actuator_servos_trim
                                        INFO  [muorb] [qshell] Ok executing command: control_allocator start
                                        INFO  [qshell] qshell return value timestamp: 84809648, local time: 84811022
                                        INFO  [qshell] Send cmd: 'load_mon start'
                                        INFO  [muorb] [qshell] qshell gotten: load_mon start
                                        INFO  [muorb] [qshell]   arg0 = 'load_mon'
                                        INFO  [muorb] [qshell] Ok executing command: load_mon start
                                        INFO  [uORB] Advertising remote topic cpuload
                                        INFO  [qshell] qshell return value timestamp: 84866816, local time: 84868801
                                        INFO  [qshell] Send cmd: 'rc_update start'
                                        INFO  [muorb] [qshell] qshell gotten: rc_update start
                                        INFO  [muorb] [qshell]   arg0 = 'rc_update'
                                        INFO  [muorb] [qshell] Ok executing command: rc_update start
                                        INFO  [qshell] qshell return value timestamp: 85094704, local time: 85096473
                                        INFO  [uORB] Advertising remote topic rc_channels
                                        INFO  [qshell] Send cmd: 'commander start'
                                        INFO  [muorb] [qshell] qshell gotten: commander start
                                        INFO  [muorb] [qshell]   arg0 = 'commander'
                                        INFO  [muorb] [tasks] Creating pthread commander
                                        INFO  [muorb] [tasks] Successfully created px4 task PX4_commander with tid 2097638
                                        INFO  [uORB] Advertising remote topic led_control
                                        INFO  [muorb] [commander] LED: open /dev/led0 failed (22)
                                        INFO  [uORB] Advertising remote topic tune_control
                                        INFO  [muorb] [qshell] Ok executing command: commander start
                                        INFO  [qshell] qshell return value timestamp: 85278466, local time: 85282382
                                        INFO  [uORB] Advertising remote topic event
                                        INFO  [uORB] Advertising remote topic mavlink_log
                                        INFO  [muorb] [health_and_arming_checks] Preflight Fail: Compass Sensor 0 missing
                                        INFO  [uORB] Advertising remote topic health_report
                                        INFO  [uORB] Advertising remote topic failsafe_flags
                                        INFO  [uORB] Advertising remote topic actuator_armed
                                        INFO  [uORB] Advertising remote topic vehicle_control_mode
                                        INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
                                        INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
                                        INFO  [uORB] Advertising remote topic vehicle_status
                                        INFO  [uORB] Advertising remote topic failure_detector_status
                                        INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
                                        INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
                                        INFO  [qshell] Send cmd: 'flight_mode_manager start'
                                        INFO  [muorb] [qshell] qshell gotten: flight_mode_manager start
                                        INFO  [muorb] [qshell]   arg0 = 'flight_mode_manager'
                                        INFO  [uORB] Advertising remote topic vehicle_command
                                        INFO  [muorb] [qshell] Ok executing command: flight_mode_manager start
                                        INFO  [qshell] qshell return value timestamp: 85385231, local time: 85387168
                                        INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                                        INFO  [muorb] [uORB] Advertising remote topic transponder_report
                                        INFO  [muorb] [uORB] Advertising remote topic rtl_time_estimate
                                        INFO  [muorb] [uORB] Advertising remote topic position_setpoint_triplet
                                        INFO  [mpa] Successfully loaded library libmodal_pipe.so
                                        INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
                                        INFO  [muorb] [uORB] Advertising remote topic telemetry_status
                                        INFO  [mavlink] partner IP: 127.0.0.1
                                        INFO  [muorb] [uORB] Advertising remote topic offboard_control_mode
                                        INFO  [muorb] [uORB] Advertising remote topic obstacle_distance
                                        INFO  [uORB] Advertising remote topic actuator_controls_status_0
                                        INFO  [muorb] [uORB] Advertising remote topic timesync_status
                                        INFO  [muorb] [uORB] Advertising remote topic vehicle_visual_odometry
                                        INFO  [uORB] Advertising remote topic estimator_aid_src_ev_hgt
                                        INFO  [uORB] Advertising remote topic estimator_aid_src_ev_pos
                                        INFO  [uORB] Advertising remote topic estimator_aid_src_ev_vel
                                        INFO  [uORB] Advertising remote topic estimator_aid_src_ev_yaw
                                        INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                                        INFO  [muorb] [uORB] Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                                        INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                                        pxh> INFO  [logger] logger started (mode=all)
                                        INFO  [muorb] [gps] GPS UART baudrate set to 9600
                                          @Eric-Katzfey
                                          GPS=AUTODETECT
                                          RC=GHST
                                          ESC=VOXL_ESC
                                          POWER MANAGER=NONE
                                          OSD=DISABLE
                                          DAEMON_MODE=DISABLE
                                          SENSOR_CAL=ACTUAL
                                          EXTRA STEPS:
                                          ______  __   __    ___
                                          | ___ \ \ \ / /   /   |
                                          | |_/ /  \ V /   / /| |
                                          |  __/   /   \  / /_| |
                                          | |     / /^\ \ \___  |
                                          \_|     \/   \/     |_/
                                          px4 starting.
                                          GPS: AUTODETECT
                                          RC: GHST
                                          ESC: VOXL_ESC
                                          POWER MANAGER: NONE
                                          OSD: DISABLE
                                          EXTRA STEPS:
                                          Running on M0054
                                          INFO  [muorb]
                                          INFO  [muorb]
                                          @voxltester slpi_proc = SLPI = SSC = DSP. I think the only option at this point is to attach an oscilloscope and verify the signals.
