  3. VOXL2 J19 QUP3
VOXL2 J19 QUP3
24 Posts 2 Posters 3.2k Views 1 Watching
  • voxltesterV voxltester
    the versions of px4 are different...
    I am git clone from https://gitlab.com/voxl-public/voxl-sdk/services/voxl-px4
    in which there is only one parameter in https://github.com/modalai/px4-firmware/tree/0a47ec5d8650f4e97f1eb929405df5dcdb91989f/src/drivers/distance_sensor/lightware_laser_i2c
    Anyway, qshell lightware_laser_i2c start is not working with I2C port on VOXL2 J19 - QUP3
    @voxltester Why are you not adding -b 4?
    voxltesterV 2 Replies Last reply
      voxltesterV Offline
      voxltesterV Offline
      voxltester
        voxltesterV Offline
        voxltesterV Offline
        voxltester
        Sorry for the slow response.
        qshell lightware_laser_i2c start -b 4?
        No. Not working.
        Please see
        https://github.com/modalai/px4-firmware/blob/f18864f2e6460e4d2d3d1572d09ee09028c63789/src/drivers/distance_sensor/lightware_laser_i2c/lightware_laser_i2c.cpp
        I do not think the -b option is not implemented in the driver source code.
        Can you confirming that -b 4 is for I2C port on VOXL2 J19 - QUP3? (https://docs.modalai.com/voxl2-connectors/#j19---external-sensors-2x-uart-2x-i2c)
        I am trying to modify the driver code to have the bus information.
          No. Not working.
          Please see
          @voxltester I tried to explain this in one of my previous responses. Let me add more detail. lightware_laser_i2c.cpp is C++ code. The class LightwareLaser has a couple of base classes. One of them is I2CSPIDriver, so it "inherits" the functionality of that class. That class is implemented in i2c_spi_buses.cpp. It uses BusCLIArguments to parse the command line options. That's where the -b option is dealt with.
            No. Not working.
            Please see
            @voxltester Yes, bus 4 corresponds to pins 7 and 8 on J19. I would put an oscilloscope on the data pin and see if you detect any activity when you start the driver to verify.
              No. Not working.
              Please see
              @voxltester And, in general, for all software engineers out there here is a helpful tip. ModalAI is not affiliated with Anthropic in any way but I do want to highlight their Claude Code tool. It can really help you not just write code, but to understand code that is already there. So, for example, in this post there is a question about how the -b option is parsed. It's a bit complicated how all of the pieces fit together but if you were to ask Claude this question: "I'm using the device driver in the file lightware_laser_i2c.cpp. I was told that the LightwareLaser class can take the command line option -b to specify the i2c bus number using the start command. Can you show me where in the code the -b option is parsed?". Claude will then give you this answer:
              The -b option is not parsed directly in this file. Looking at the code:
                At line 450, the custom option parsing only handles -R for rotation:
                while ((ch = cli.getOpt(argc, argv, "R:")) != EOF) {
                    switch (ch) {
                    case 'R':
                        cli.rotation = (Rotation)atoi(cli.optArg());
                        break;
                The -b option (for I2C bus number) is handled automatically by the BusCLIArguments class, which is instantiated at line 445:
                BusCLIArguments cli{true, false};
                This class is included from <px4_platform_common/i2c_spi_buses.h> (line 47). The cli.getOpt() method internally processes standard I2C/SPI options like -b (bus), -a (address), etc., before returning custom options like -R to this driver's switch statement.
                If you want to see where -b is actually parsed, you'd need to look at the BusCLIArguments class implementation in the PX4 platform common library:
                src/lib/drivers/device/posix/i2c_spi_buses.cpp
                or
                platforms/common/i2c_spi_buses.cpp
                The PRINT_MODULE_USAGE_PARAMS_I2C_SPI_DRIVER(true, false) call at line 435 documents that this driver accepts I2C options (including -b), but the actual parsing is abstracted away in the shared bus infrastructure.
                      switch (ch) {
                      case 'R':
                          break;
                  or
                voxltesterV Offline
                voxltesterV Offline
                voxltester
                        switch (ch) {
                        case 'R':
                            break;
                    or
                  voxltesterV Offline
                  voxltesterV Offline
                  voxltester
                  wrote on last edited by voxltester
                  #17
                  Thank you for the info...
                  I figured out the connection cannot be detected on the port at all..
                   $ i2cdetect -y -r 4
                       0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                  00:          -- -- -- -- -- -- -- -- -- -- -- -- --
                  10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  70: -- -- -- -- -- -- -- --
                  FYI,
                  pxh> lightware_laser_i2c start -b 4
                  ERROR [SPI_I2C] need to specify a bus type
                  ### Description
                  I2C bus driver for Lightware SFxx series LIDAR rangefinders: SF10/a, SF10/b, SF10/c, SF11/c, SF/LW20.
                  Setup
                  Usage: lightware_laser_i2c <command> [arguments...]
                   Commands:
                     start
                       [-I]        Internal I2C bus(es)
                       [-X]        External I2C bus(es)
                       [-b <val>]  board-specific bus (default=all) (external SPI: n-th bus (default=1))
                       [-f <val>]  bus frequency in kHz
                       [-q]        quiet startup (no message if no device found)
                       [-a <val>]  I2C address
                                   default: 102
                       [-R <val>]  Sensor rotation - downward facing by default
                                   default: 25
                     stop
                     status        print status info
                  Command 'lightware_laser_i2c' failed, returned -1.
                  pxh> lightware_laser_i2c start -X -b 4
                  WARN  [SPI_I2C] mavlink_shell: no instance started (no device on bus?)
                     $ i2cdetect -y -r 4
                    FYI,
                    ### Description
                    Setup
                     Commands:
                       start
                                     default: 102
                                     default: 25
                       stop
                    @voxltester i2cdetect is looking for i2c ports on the apps processor so it isn't useful for this where we are trying to use DSP i2c ports. It shows an error message. Can you add the -X option to see if that resolves that error condition?
                    voxltesterV 1 Reply Last reply
                      voxltesterV Offline
                      voxltesterV Offline
                      voxltester
                      #19
                      Isn't this I2C (J19 7&8) APP I2C or DPS I2C?
                      7  I2C3 SDA 3P3V   slpi_proc, SSC_QUP3
                      8  I2C3 SCL 3P3V   slpi_proc, SSC_QUP3
                      Is it possible to access DPS I2C from PX4?
                      Please see the outputs of the -X and -I options.
                      WARN  [SPI_I2C] UnknownApp: no instance started (no device on bus?)
                      pxh> lightware_laser_i2c start -I -b 4
                      FYI, the following is an initialization of the VOXL-PX4.
                      voxl2:~$ voxl-px4 -d
                      Found DSP signature file
                      [INFO] Disabling daemon mode
                      AIRFRAME=MULTICOPTER
                      GPS=AUTODETECT
                      RC=GHST
                      ESC=VOXL_ESC
                      POWER MANAGER=NONE
                      AIRSPEED SENSOR=NONE
                      DISTANCE SENSOR=LIGHTWARE_SF000
                      OSD=DISABLE
                      DAEMON_MODE=DISABLE
                      SENSOR_CAL=ACTUAL
                      ARTIFACT_MODE=DISABLE
                      EXTRA STEPS:
                      INFO  [muorb] [modules__muorb__slpi] muorb aggregator thread running
                      INFO  [muorb] [modules__muorb__slpi] muorb keepalive thread running
                      INFO  [muorb] [tasks] Creating pthread test_MUORB
                      INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097656
                      INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097655
                      INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097654
                      INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097653
                      ______  __   __    ___
                      | ___ \ \ \ / /   /   |
                      | |_/ /  \ V /   / /| |
                      |  __/   /   \  / /_| |
                      | |     / /^\ \ \___  |
                      \_|     \/   \/     |_/
                      px4 starting.
                      INFO  [muorb] [uORB] Advertising remote topic log_message
                      AIRFRAME: MULTICOPTER
                      GPS: AUTODETECT
                      RC: GHST
                      ESC: VOXL_ESC
                      POWER MANAGER: NONE
                      AIRSPEED SENSOR: NONE
                      DISTANCE SENSOR: LIGHTWARE_SF000
                      OSD: DISABLE
                      ARTIFACT_MODE: DISABLE
                      EXTRA STEPS:
                      INFO  [muorb] [parameters] Starting param sync THREAD
                      Running on M0054
                      INFO  [muorb] [qshell] before starting the qshell_entry task
                      INFO  [muorb] [tasks] Creating pthread qshell
                      INFO  [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652
                      INFO  [muorb] [qshell] qshell entry.....
                      INFO  [muorb] [qshell] after starting the qshell_entry task
                      INFO  [muorb] [qshell] Init app map initialized
                      INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                      INFO  [muorb] [uORB] Advertising remote topic parameter_update
                      INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t
                      INFO  [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t
                      INFO  [parameters] BSON document size 3307 bytes, decoded 3307 bytes (INT32:44, FLOAT:109)
                      INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                      INFO  [muorb] [qshell] qshell gotten: icm42688p start -s
                      INFO  [muorb] [qshell]   arg0 = 'icm42688p'
                      INFO  [muorb] [qshell]   arg1 = 'start'
                      INFO  [muorb] [qshell]   arg2 = '-s'
                      INFO  [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
                      INFO  [muorb] [icm42688p] ICM42688P::probe successful!
                      INFO  [muorb] [drivers__device] on SPI bus 1
                      INFO  [muorb] icm42688p #0 on SPI bus 1
                      INFO  [muorb]
                      INFO  [muorb] [icm42688p] >>> ICM42688P this: b26024d8
                      INFO  [muorb] [qshell] Ok executing command: icm42688p start -s
                      INFO  [qshell] qshell return value timestamp: 83014023, local time: 83018955
                      Looking for external DPS368 barometer
                      INFO  [muorb] [drivers__device] Register interrupt b214f094 e612a80c b26024d8
                      ERROR [dps310] Product_ID mismatch
                      Looking for external ICP10100 barometer
                      Did not detect an external barometer, starting onboard ICP10100 barometer
                      INFO  [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
                      INFO  [muorb] [qshell]   arg0 = 'icp101xx'
                      INFO  [muorb] [qshell]   arg2 = '-I'
                      INFO  [muorb] [qshell]   arg3 = '-b'
                      INFO  [muorb] [qshell]   arg4 = '5'
                      INFO  [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
                      INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 5
                      INFO  [muorb] icp101xx #0 on I2C bus 5
                      INFO  [muorb]  address 0x63
                      INFO  [muorb]
                      INFO  [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
                      INFO  [qshell] qshell return value timestamp: 83111693, local time: 83114593
                      INFO  [qshell] Send cmd: 'temperature_compensation start'
                      INFO  [muorb] [qshell] qshell gotten: temperature_compensation start
                      INFO  [muorb] [qshell]   arg0 = 'temperature_compensation'
                      INFO  [uORB] Advertising remote topic sensor_correction
                      INFO  [muorb] [qshell] Ok executing command: temperature_compensation start
                      INFO  [qshell] qshell return value timestamp: 83262606, local time: 83264812
                      INFO  [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
                      INFO  [muorb] [qshell]   arg0 = 'qmc5883l'
                      INFO  [muorb] [qshell]   arg2 = '-R'
                      INFO  [muorb] [qshell]   arg3 = '10'
                      INFO  [muorb] [qshell]   arg4 = '-X'
                      INFO  [muorb] [qshell]   arg5 = '-b'
                      INFO  [muorb] [qshell]   arg6 = '1'
                      INFO  [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
                      INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 1
                      ERROR [muorb] [drivers__device] i2c probe failed
                      INFO  [muorb] [SPI_I2C] PX4_qshell: no instance started (no device on bus?)
                      ERROR [muorb] [qshell] Failed to execute command: qmc5883l start -R 10 -X -b 1
                      INFO  [qshell] qshell return value timestamp: 83324177, local time: 83325854
                      ERROR [qshell] Command failed
                      INFO  [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
                      INFO  [muorb] [qshell]   arg0 = 'ist8310'
                      INFO  [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
                      ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R 10 -X -b 1
                      INFO  [qshell] qshell return value timestamp: 83374408, local time: 83377531
                      Looking for ist8308 magnetometer
                      INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
                      INFO  [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
                      INFO  [muorb] [qshell]   arg0 = 'ist8308'
                      INFO  [muorb] [qshell]   arg3 = '12'
                      INFO  [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
                      ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R 12 -X -b 1
                      INFO  [qshell] qshell return value timestamp: 83413213, local time: 83416595
                      INFO  [muorb] [qshell] qshell gotten: gps start
                      INFO  [muorb] [qshell]   arg0 = 'gps'
                      INFO  [muorb] [tasks] Creating pthread gps
                      INFO  [muorb] [tasks] Successfully created px4 task PX4_gps with tid 2097645
                      INFO  [muorb] [qshell] Ok executing command: gps start
                      INFO  [qshell] qshell return value timestamp: 83445422, local time: 83446602
                      Looking for ncp5623c RGB LED
                      INFO  [muorb] [gps] GPS UART baudrate set to 115200
                      INFO  [muorb] [qshell] qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                      INFO  [muorb] [qshell]   arg0 = 'rgbled_ncp5623c'
                      INFO  [muorb] [qshell]   arg2 = '-X'
                      INFO  [muorb] [qshell]   arg4 = '1'
                      INFO  [muorb] [qshell]   arg5 = '-f'
                      INFO  [muorb] [qshell]   arg6 = '400'
                      INFO  [muorb] [qshell]   arg7 = '-a'
                      INFO  [muorb] [qshell]   arg8 = '56'
                      INFO  [muorb] [drivers__device] *** I2C Device ID 0x7b3809 8075273
                      INFO  [muorb] [drivers__device] Set i2c address 0x38, fd 4
                      ERROR [muorb] [qshell] Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                      INFO  [qshell] qshell return value timestamp: 83487606, local time: 83489160
                      Starting VOXL ESC driver
                      INFO  [qshell] Send cmd: 'voxl_esc start'
                      INFO  [muorb] [qshell] qshell gotten: voxl_esc start
                      INFO  [muorb] [qshell]   arg0 = 'voxl_esc'
                      INFO  [muorb] [voxl_esc] Starting VOXL ESC driver
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_CONFIG: 1
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_MODE: 0
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_BAUD: 2000000
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC1: 102
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC2: 103
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC3: 101
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC4: 104
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR1: 0
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR2: 0
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR3: 0
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR4: 0
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_PWR_MIN: 0.050000
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MIN: 2000
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MAX: 12000
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_PERC: 90
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_VLOG: 1
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_WARN: 0
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_OVER: 0
                      INFO  [muorb] [voxl_esc] Params: GPIO_CTL_CH: 0
                      INFO  [muorb] [voxl_esc] Params: VOXL_ESC_CMD: 0
                      INFO  [muorb] [qshell] Ok executing command: voxl_esc start
                      INFO  [muorb] [voxl_esc] Opening UART ESC device 2, baud rate 2000000
                      INFO  [muorb] [voxl_esc] Successfully opened UART ESC device
                      INFO  [muorb] [voxl_esc] Detecting ESCs...
                      INFO  [muorb] [voxl_esc] 	ESC ID     : 0
                      INFO  [muorb] [voxl_esc] 	Board Type : 40: ModalAi 4-in-1 ESC (M0129-3)
                      INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0024
                      INFO  [muorb] [voxl_esc] 	Firmware   : version   39, hash 9c6233d6
                      INFO  [muorb] [voxl_esc] 	Bootloader : version  184, hash 10bf24c8
                      INFO  [muorb] [voxl_esc] 	Reply time : 723us
                      INFO  [muorb] [voxl_esc] VOXL_ESC:
                      INFO  [muorb] [voxl_esc] 	ESC ID     : 1
                      INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0028
                      INFO  [muorb] [voxl_esc] 	Reply time : 728us
                      INFO  [qshell] qshell return value timestamp: 83652589, local time: 83657098
                      INFO  [muorb] [voxl_esc] 	ESC ID     : 2
                      INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0026
                      INFO  [muorb] [voxl_esc] 	Reply time : 718us
                      INFO  [muorb] [voxl_esc] 	ESC ID     : 3
                      INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0022
                      INFO  [muorb] [voxl_esc] 	Reply time : 739us
                      INFO  [muorb] [voxl_esc] Use extended rpm packet : 1
                      INFO  [muorb] [voxl_esc] All ESCs successfully detected
                      Starting GHST RC driver
                      INFO  [qshell] Send cmd: 'ghst_rc start -d 7'
                      INFO  [muorb] [qshell] qshell gotten: ghst_rc start -d 7
                      INFO  [muorb] [qshell]   arg0 = 'ghst_rc'
                      INFO  [uORB] Advertising remote topic actuator_outputs_debug
                      INFO  [uORB] Advertising remote topic esc_status
                      INFO  [muorb] [qshell]   arg2 = '-d'
                      INFO  [muorb] [qshell]   arg3 = '7'
                      INFO  [muorb] [qshell] Ok executing command: ghst_rc start -d 7
                      INFO  [uORB] Advertising remote topic input_rc
                      INFO  [qshell] qshell return value timestamp: 83712270, local time: 83715195
                      INFO  [qshell] Send cmd: 'lightware_laser_i2c start -b 4'
                      INFO  [muorb] [qshell] qshell gotten: lightware_laser_i2c start -b 4
                      ERROR [muorb] [qshell] Command lightware_laser_i2c not found
                      ERROR [muorb] [qshell] Failed to execute command: lightware_laser_i2c start -b 4
                      INFO  [qshell] cmd returned with: 1
                      INFO  [qshell] qshell return value timestamp: 83743015, local time: 83745263
                      INFO  [muorb] [qshell] qshell gotten: sensors start
                      INFO  [muorb] [qshell]   arg0 = 'sensors'
                      INFO  [muorb] [modules__muorb__slpi] Deleting /data/px4/slpi/keepalive_fail
                      INFO  [uORB] Advertising remote topic battery_status
                      INFO  [muorb] [qshell] Ok executing command: sensors start
                      INFO  [qshell] qshell return value timestamp: 83931906, local time: 83935646
                      INFO  [muorb] [qshell] qshell gotten: ekf2 start
                      INFO  [muorb] [qshell]   arg0 = 'ekf2'
                      INFO  [muorb] [qshell] Ok executing command: ekf2 start
                      INFO  [qshell] qshell return value timestamp: 84173695, local time: 84177522
                      INFO  [muorb] [qshell] qshell gotten: mc_pos_control start
                      INFO  [muorb] [qshell]   arg0 = 'mc_pos_control'
                      INFO  [muorb] [qshell] Ok executing command: mc_pos_control start
                      INFO  [qshell] qshell return value timestamp: 84266732, local time: 84268823
                      INFO  [muorb] [qshell] qshell gotten: mc_att_control start
                      INFO  [muorb] [qshell]   arg0 = 'mc_att_control'
                      INFO  [muorb] [qshell] Ok executing command: mc_att_control start
                      INFO  [qshell] qshell return value timestamp: 84320268, local time: 84321796
                      INFO  [muorb] [qshell] qshell gotten: mc_rate_control start
                      INFO  [muorb] [qshell]   arg0 = 'mc_rate_control'
                      INFO  [muorb] [qshell] Ok executing command: mc_rate_control start
                      INFO  [qshell] qshell return value timestamp: 84408066, local time: 84410267
                      INFO  [muorb] [qshell] qshell gotten: mc_hover_thrust_estimator start
                      INFO  [muorb] [qshell]   arg0 = 'mc_hover_thrust_estimator'
                      INFO  [muorb] [qshell] Ok executing command: mc_hover_thrust_estimator start
                      INFO  [qshell] qshell return value timestamp: 84462789, local time: 84464375
                      INFO  [muorb] [qshell] qshell gotten: mc_autotune_attitude_control start
                      INFO  [muorb] [qshell]   arg0 = 'mc_autotune_attitude_control'
                      INFO  [muorb] [qshell] Ok executing command: mc_autotune_attitude_control start
                      INFO  [qshell] qshell return value timestamp: 84514600, local time: 84516557
                      INFO  [muorb] [qshell] qshell gotten: land_detector start multicopter
                      INFO  [muorb] [qshell]   arg0 = 'land_detector'
                      INFO  [muorb] [qshell]   arg2 = 'multicopter'
                      INFO  [muorb] [qshell] Ok executing command: land_detector start multicopter
                      INFO  [qshell] qshell return value timestamp: 84553505, local time: 84556075
                      INFO  [uORB] Advertising remote topic vehicle_land_detected
                      INFO  [qshell] Send cmd: 'manual_control start'
                      INFO  [muorb] [qshell] qshell gotten: manual_control start
                      INFO  [muorb] [qshell]   arg0 = 'manual_control'
                      INFO  [muorb] [qshell] Ok executing command: manual_control start
                      INFO  [qshell] qshell return value timestamp: 84597175, local time: 84598418
                      INFO  [uORB] Advertising remote topic manual_control_setpoint
                      INFO  [qshell] Send cmd: 'control_allocator start'
                      INFO  [muorb] [qshell] qshell gotten: control_allocator start
                      INFO  [muorb] [qshell]   arg0 = 'control_allocator'
                      INFO  [uORB] Advertising remote topic control_allocator_status
                      INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                      INFO  [uORB] Advertising remote topic actuator_motors
                      INFO  [uORB] Advertising remote topic actuator_servos
                      INFO  [uORB] Advertising remote topic actuator_servos_trim
                      INFO  [muorb] [qshell] Ok executing command: control_allocator start
                      INFO  [qshell] qshell return value timestamp: 84809648, local time: 84811022
                      INFO  [qshell] Send cmd: 'load_mon start'
                      INFO  [muorb] [qshell] qshell gotten: load_mon start
                      INFO  [muorb] [qshell]   arg0 = 'load_mon'
                      INFO  [muorb] [qshell] Ok executing command: load_mon start
                      INFO  [uORB] Advertising remote topic cpuload
                      INFO  [qshell] qshell return value timestamp: 84866816, local time: 84868801
                      INFO  [qshell] Send cmd: 'rc_update start'
                      INFO  [muorb] [qshell] qshell gotten: rc_update start
                      INFO  [muorb] [qshell]   arg0 = 'rc_update'
                      INFO  [muorb] [qshell] Ok executing command: rc_update start
                      INFO  [qshell] qshell return value timestamp: 85094704, local time: 85096473
                      INFO  [uORB] Advertising remote topic rc_channels
                      INFO  [qshell] Send cmd: 'commander start'
                      INFO  [muorb] [qshell] qshell gotten: commander start
                      INFO  [muorb] [qshell]   arg0 = 'commander'
                      INFO  [muorb] [tasks] Creating pthread commander
                      INFO  [muorb] [tasks] Successfully created px4 task PX4_commander with tid 2097638
                      INFO  [uORB] Advertising remote topic led_control
                      INFO  [muorb] [commander] LED: open /dev/led0 failed (22)
                      INFO  [uORB] Advertising remote topic tune_control
                      INFO  [muorb] [qshell] Ok executing command: commander start
                      INFO  [qshell] qshell return value timestamp: 85278466, local time: 85282382
                      INFO  [uORB] Advertising remote topic event
                      INFO  [uORB] Advertising remote topic mavlink_log
                      INFO  [muorb] [health_and_arming_checks] Preflight Fail: Compass Sensor 0 missing
                      INFO  [uORB] Advertising remote topic health_report
                      INFO  [uORB] Advertising remote topic failsafe_flags
                      INFO  [uORB] Advertising remote topic actuator_armed
                      INFO  [uORB] Advertising remote topic vehicle_control_mode
                      INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
                      INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
                      INFO  [uORB] Advertising remote topic vehicle_status
                      INFO  [uORB] Advertising remote topic failure_detector_status
                      INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
                      INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
                      INFO  [qshell] Send cmd: 'flight_mode_manager start'
                      INFO  [muorb] [qshell] qshell gotten: flight_mode_manager start
                      INFO  [muorb] [qshell]   arg0 = 'flight_mode_manager'
                      INFO  [uORB] Advertising remote topic vehicle_command
                      INFO  [muorb] [qshell] Ok executing command: flight_mode_manager start
                      INFO  [qshell] qshell return value timestamp: 85385231, local time: 85387168
                      INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                      INFO  [muorb] [uORB] Advertising remote topic transponder_report
                      INFO  [muorb] [uORB] Advertising remote topic rtl_time_estimate
                      INFO  [muorb] [uORB] Advertising remote topic position_setpoint_triplet
                      INFO  [mpa] Successfully loaded library libmodal_pipe.so
                      INFO  [muorb] [uORB] Advertising remote topic telemetry_status
                      INFO  [muorb] [uORB] Advertising remote topic offboard_control_mode
                      INFO  [muorb] [uORB] Advertising remote topic obstacle_distance
                      INFO  [uORB] Advertising remote topic actuator_controls_status_0
                      INFO  [muorb] [uORB] Advertising remote topic timesync_status
                      INFO  [muorb] [uORB] Advertising remote topic vehicle_visual_odometry
                      INFO  [uORB] Advertising remote topic estimator_aid_src_ev_hgt
                      INFO  [uORB] Advertising remote topic estimator_aid_src_ev_pos
                      INFO  [uORB] Advertising remote topic estimator_aid_src_ev_vel
                      INFO  [uORB] Advertising remote topic estimator_aid_src_ev_yaw
                      INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                      INFO  [muorb] [uORB] Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                      INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                      pxh> INFO  [logger] logger started (mode=all)
                      INFO  [muorb] [gps] GPS UART baudrate set to 9600
                        GPS=AUTODETECT
                        RC=GHST
                        ESC=VOXL_ESC
                        POWER MANAGER=NONE
                        OSD=DISABLE
                        DAEMON_MODE=DISABLE
                        SENSOR_CAL=ACTUAL
                        EXTRA STEPS:
                        ______  __   __    ___
                        | ___ \ \ \ / /   /   |
                        | |_/ /  \ V /   / /| |
                        |  __/   /   \  / /_| |
                        | |     / /^\ \ \___  |
                        \_|     \/   \/     |_/
                        px4 starting.
                        GPS: AUTODETECT
                        RC: GHST
                        ESC: VOXL_ESC
                        POWER MANAGER: NONE
                        OSD: DISABLE
                        EXTRA STEPS:
                        Running on M0054
                        INFO  [muorb]
                        INFO  [muorb]
                        @voxltester slpi_proc = SLPI = SSC = DSP. I think the only option at this point is to attach an oscilloscope and verify the signals.
                          GPS=AUTODETECT
                          RC=GHST
                          ESC=VOXL_ESC
                          POWER MANAGER=NONE
                          OSD=DISABLE
                          DAEMON_MODE=DISABLE
                          SENSOR_CAL=ACTUAL
                          EXTRA STEPS:
                          ______  __   __    ___
                          | ___ \ \ \ / /   /   |
                          | |_/ /  \ V /   / /| |
                          |  __/   /   \  / /_| |
                          | |     / /^\ \ \___  |
                          \_|     \/   \/     |_/
                          px4 starting.
                          GPS: AUTODETECT
                          RC: GHST
                          ESC: VOXL_ESC
                          POWER MANAGER: NONE
                          OSD: DISABLE
                          EXTRA STEPS:
                          Running on M0054
                          INFO  [muorb]
                          INFO  [muorb]
                          @voxltester In order to execute on the DSP side you have to have qshell before the command. When you have it you get the error that command is not found. That's probably because the driver has not been built into the DSP image. It only seems to be on the apps side.
                            voxltesterV Offline
                            voxltesterV Offline
                            voxltester
                            #22
                              voxltesterV Offline
                              voxltesterV Offline
                              voxltester
                              #23
                              Never mind. I finally received the DISTANCE_SENSOR data!
                              I added
                              CONFIG_DRIVERS_DISTANCE_SENSOR_LIGHTWARE_LASER_I2C=y
                              to px4-firmware/board/modalai/voxl2-slpi/dafault.px4board.
                              Thank you for your help.
                                I added
                                @voxltester Great! Glad you got it working.
