    VOXL2 J19 QUP3
    1136
    • voxltesterV
      voxltester
      I connected Lightware LW20/C on one of the I2C port on VOXL2 J19.
      It is QUP3, and the pins I used are
      7	I2C3 SDA 3P3V	slpi_proc, SSC_QUP3
      8	I2C3 SCL 3P3V	slpi_proc, SSC_QUP3
      and power & ground.
      I also installed a customized voxl-px4 which will start lightware_laser_i2c with the I2C address 0x66.
      On VOXL2, I edited voxl-px4.conf file by adding DISTANCE_SENSOR=LIGHTWARE_SF000.
      However, I cannot see any parameter regarding rangefinder... like SENS_EN_SF1XX.
      I have done using LW20/C with UART connection successfully, but I2C does not work..
      Can anyone give me any advise to use it via I2C?
        Eric Katzfey ModalAI Team @voxltester
        @voxltester That is not a normal option to choose via voxl-px4.conf. You will need to hand modify the startup script /usr/bin/voxl-px4-start to properly start the driver in i2c mode. Use option -b 4 to select that i2c bus.
        voxltesterV 1 Reply Last reply Reply Quote 0
        • voxltesterV
          voxltester @Eric Katzfey
          Hi, Eric.
          I tried
          qshell lightware_laser_i2c start -a 0x66 # I2C address 102
          it did not work..
          So are you meaning
          qshell lightware_laser_serial start -b 4
          or
          qshell lightware_laser_i2c start -b 4
            @voxltester I would try qshell lightware_laser_i2c start -b 4
            • voxltesterV
              Eric, this is not working...
              Please refer to the driver for i2c....
              https://github.com/modalai/px4-firmware/blob/main/src/drivers/distance_sensor/lightware_laser_i2c/lightware_laser_i2c.cpp
              Default i2c address is defined 0x66 (102) in this code.
              I am wondering what is the i2c address of the VOXL2 J19 - QUP3 port.
              I am not familiar with the above cpp driver code... could you please have a look the code and teach me how to enable the i2c connection for the lightware rangefinder?
              Thank you in advance....
                @voxltester We have never used the device that you are connecting so I am only offering suggestions to help out. When speaking of i2c addresses it is related to the device being attached to the bus, not the bus itself. You can attach multiple i2c devices to the same i2c bus if they have different addresses. But, there are multiple i2c buses to choose from. So, address 0x66 (which is default for that device and doesn't need to be specified on the command line) is for the device and port 4 specifies which i2c bus it is connected to. Also, please look at this file: https://github.com/modalai/px4-firmware/blob/main/src/drivers/distance_sensor/lightware_laser_i2c/parameters.c. There are 2 parameters that need to be set properly for the driver to work. If the default values are not correct then you will need to set them accordingly. For SENS_EN_SF1XX it should be set to 6 for LW20/c.
                • voxltesterV
                  Understood. I just figured out address and bus. I am sorry for disturbing you for the basic concept.
                  Now, I am trying to run it with SENS_EN_SF1XX=6, the command in px4-start is just qshell lightware_laser_i2c start.
                  By the way, I am wondering where the bus info is described in the driver cpp file. Should I change the code? Because lightware_laser_i2c accepts only R as an option..
                    @voxltester It's all done in the base class. See: https://github.com/modalai/px4-firmware/blob/main/platforms/common/i2c_spi_buses.cpp
                    • voxltesterV
                      the versions of px4 are different...
                      I am git clone from https://gitlab.com/voxl-public/voxl-sdk/services/voxl-px4
                      in which there is only one parameter in https://github.com/modalai/px4-firmware/tree/0a47ec5d8650f4e97f1eb929405df5dcdb91989f/src/drivers/distance_sensor/lightware_laser_i2c
                      Anyway, qshell lightware_laser_i2c start is not working with I2C port on VOXL2 J19 - QUP3
                        @voxltester Why are you not adding -b 4?
                        voxltesterV 2 Replies Last reply Reply Quote 0
                        • voxltesterV
                          • voxltesterV
                            Sorry for the slow response.
                            qshell lightware_laser_i2c start -b 4?
                            No. Not working.
                            Please see
                            https://github.com/modalai/px4-firmware/blob/f18864f2e6460e4d2d3d1572d09ee09028c63789/src/drivers/distance_sensor/lightware_laser_i2c/lightware_laser_i2c.cpp
                            I do not think the -b option is not implemented in the driver source code.
                            Can you confirming that -b 4 is for I2C port on VOXL2 J19 - QUP3? (https://docs.modalai.com/voxl2-connectors/#j19---external-sensors-2x-uart-2x-i2c)
                            I am trying to modify the driver code to have the bus information.
                            Eric KatzfeyE 3 Replies Last reply Reply Quote 0
                              @voxltester I tried to explain this in one of my previous responses. Let me add more detail. lightware_laser_i2c.cpp is C++ code. The class LightwareLaser has a couple of base classes. One of them is I2CSPIDriver, so it "inherits" the functionality of that class. That class is implemented in i2c_spi_buses.cpp. It uses BusCLIArguments to parse the command line options. That's where the -b option is dealt with.
                                @voxltester Yes, bus 4 corresponds to pins 7 and 8 on J19. I would put an oscilloscope on the data pin and see if you detect any activity when you start the driver to verify.
                                  @voxltester And, in general, for all software engineers out there here is a helpful tip. ModalAI is not affiliated with Anthropic in any way but I do want to highlight their Claude Code tool. It can really help you not just write code, but to understand code that is already there. So, for example, in this post there is a question about how the -b option is parsed. It's a bit complicated how all of the pieces fit together but if you were to ask Claude this question: "I'm using the device driver in the file lightware_laser_i2c.cpp. I was told that the LightwareLaser class can take the command line option -b to specify the i2c bus number using the start command. Can you show me where in the code the -b option is parsed?". Claude will then give you this answer:
                                  The -b option is not parsed directly in this file. Looking at the code:
                                    At line 450, the custom option parsing only handles -R for rotation:
                                    while ((ch = cli.getOpt(argc, argv, "R:")) != EOF) {
                                        switch (ch) {
                                        case 'R':
                                            cli.rotation = (Rotation)atoi(cli.optArg());
                                            break;
                                    The -b option (for I2C bus number) is handled automatically by the BusCLIArguments class, which is instantiated at line 445:
                                    BusCLIArguments cli{true, false};
                                    This class is included from <px4_platform_common/i2c_spi_buses.h> (line 47). The cli.getOpt() method internally processes standard I2C/SPI options like -b (bus), -a (address), etc., before returning custom options like -R to this driver's switch statement.
                                    If you want to see where -b is actually parsed, you'd need to look at the BusCLIArguments class implementation in the PX4 platform common library:
                                    src/lib/drivers/device/posix/i2c_spi_buses.cpp
                                    or
                                    The PRINT_MODULE_USAGE_PARAMS_I2C_SPI_DRIVER(true, false) call at line 435 documents that this driver accepts I2C options (including -b), but the actual parsing is abstracted away in the shared bus infrastructure.
                                  • voxltesterV
                                    • voxltesterV
                                      Thank you for the info...
                                      I figured out the connection cannot be detected on the port at all..
                                       $ i2cdetect -y -r 4
                                           0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                                      00:          -- -- -- -- -- -- -- -- -- -- -- -- --
                                      10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                      20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                      30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                      40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                      50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                      60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                                      70: -- -- -- -- -- -- -- --
                                      FYI,
                                      pxh> lightware_laser_i2c start -b 4
                                      ERROR [SPI_I2C] need to specify a bus type
                                      ### Description
                                      I2C bus driver for Lightware SFxx series LIDAR rangefinders: SF10/a, SF10/b, SF10/c, SF11/c, SF/LW20.
                                      Setup
                                      Usage: lightware_laser_i2c <command> [arguments...]
                                       Commands:
                                         start
                                           [-I]        Internal I2C bus(es)
                                           [-X]        External I2C bus(es)
                                           [-b <val>]  board-specific bus (default=all) (external SPI: n-th bus (default=1))
                                           [-f <val>]  bus frequency in kHz
                                           [-q]        quiet startup (no message if no device found)
                                           [-a <val>]  I2C address
                                                       default: 102
                                           [-R <val>]  Sensor rotation - downward facing by default
                                                       default: 25
                                         stop
                                         status        print status info
                                      Command 'lightware_laser_i2c' failed, returned -1.
                                      pxh> lightware_laser_i2c start -X -b 4
                                      WARN  [SPI_I2C] mavlink_shell: no instance started (no device on bus?)
                                        @voxltester i2cdetect is looking for i2c ports on the apps processor so it isn't useful for this where we are trying to use DSP i2c ports. It shows an error message. Can you add the -X option to see if that resolves that error condition?
                                        • voxltesterV
                                          Isn't this I2C (J19 7&8) APP I2C or DPS I2C?
                                          Is it possible to access DPS I2C from PX4?
                                          Please see the outputs of the -X and -I options.
                                          WARN  [SPI_I2C] UnknownApp: no instance started (no device on bus?)
                                          pxh> lightware_laser_i2c start -I -b 4
                                          FYI, the following is an initialization of the VOXL-PX4.
                                          voxl2:~$ voxl-px4 -d
                                          Found DSP signature file
                                          [INFO] Disabling daemon mode
                                          AIRFRAME=MULTICOPTER
                                          GPS=AUTODETECT
                                          RC=GHST
                                          ESC=VOXL_ESC
                                          POWER MANAGER=NONE
                                          AIRSPEED SENSOR=NONE
                                          DISTANCE SENSOR=LIGHTWARE_SF000
                                          OSD=DISABLE
                                          DAEMON_MODE=DISABLE
                                          SENSOR_CAL=ACTUAL
                                          ARTIFACT_MODE=DISABLE
                                          EXTRA STEPS:
                                          INFO  [muorb] [modules__muorb__slpi] muorb aggregator thread running
                                          INFO  [muorb] [modules__muorb__slpi] muorb keepalive thread running
                                          INFO  [muorb] [tasks] Creating pthread test_MUORB
                                          INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097656
                                          INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097655
                                          INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097654
                                          INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097653
                                          ______  __   __    ___
                                          | ___ \ \ \ / /   /   |
                                          | |_/ /  \ V /   / /| |
                                          |  __/   /   \  / /_| |
                                          | |     / /^\ \ \___  |
                                          \_|     \/   \/     |_/
                                          px4 starting.
                                          INFO  [muorb] [uORB] Advertising remote topic log_message
                                          AIRFRAME: MULTICOPTER
                                          GPS: AUTODETECT
                                          RC: GHST
                                          ESC: VOXL_ESC
                                          POWER MANAGER: NONE
                                          AIRSPEED SENSOR: NONE
                                          DISTANCE SENSOR: LIGHTWARE_SF000
                                          OSD: DISABLE
                                          ARTIFACT_MODE: DISABLE
                                          EXTRA STEPS:
                                          INFO  [muorb] [parameters] Starting param sync THREAD
                                          Running on M0054
                                          INFO  [muorb] [qshell] before starting the qshell_entry task
                                          INFO  [muorb] [tasks] Creating pthread qshell
                                          INFO  [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652
                                          INFO  [muorb] [qshell] qshell entry.....
                                          INFO  [muorb] [qshell] after starting the qshell_entry task
                                          INFO  [muorb] [qshell] Init app map initialized
                                          INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                                          INFO  [muorb] [uORB] Advertising remote topic parameter_update
                                          INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t
                                          INFO  [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t
                                          INFO  [parameters] BSON document size 3307 bytes, decoded 3307 bytes (INT32:44, FLOAT:109)
                                          INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                                          INFO  [muorb] [qshell] qshell gotten: icm42688p start -s
                                          INFO  [muorb] [qshell]   arg0 = 'icm42688p'
                                          INFO  [muorb] [qshell]   arg1 = 'start'
                                          INFO  [muorb] [qshell]   arg2 = '-s'
                                          INFO  [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
                                          INFO  [muorb] [icm42688p] ICM42688P::probe successful!
                                          INFO  [muorb] [drivers__device] on SPI bus 1
                                          INFO  [muorb] icm42688p #0 on SPI bus 1
                                          INFO  [muorb]
                                          INFO  [muorb] [icm42688p] >>> ICM42688P this: b26024d8
                                          INFO  [muorb] [qshell] Ok executing command: icm42688p start -s
                                          INFO  [qshell] qshell return value timestamp: 83014023, local time: 83018955
                                          Looking for external DPS368 barometer
                                          INFO  [muorb] [drivers__device] Register interrupt b214f094 e612a80c b26024d8
                                          ERROR [dps310] Product_ID mismatch
                                          Looking for external ICP10100 barometer
                                          Did not detect an external barometer, starting onboard ICP10100 barometer
                                          INFO  [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
                                          INFO  [muorb] [qshell]   arg0 = 'icp101xx'
                                          INFO  [muorb] [qshell]   arg2 = '-I'
                                          INFO  [muorb] [qshell]   arg3 = '-b'
                                          INFO  [muorb] [qshell]   arg4 = '5'
                                          INFO  [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
                                          INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 5
                                          INFO  [muorb] icp101xx #0 on I2C bus 5
                                          INFO  [muorb]  address 0x63
                                          INFO  [muorb]
                                          INFO  [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
                                          INFO  [qshell] qshell return value timestamp: 83111693, local time: 83114593
                                          INFO  [qshell] Send cmd: 'temperature_compensation start'
                                          INFO  [muorb] [qshell] qshell gotten: temperature_compensation start
                                          INFO  [muorb] [qshell]   arg0 = 'temperature_compensation'
                                          INFO  [uORB] Advertising remote topic sensor_correction
                                          INFO  [muorb] [qshell] Ok executing command: temperature_compensation start
                                          INFO  [qshell] qshell return value timestamp: 83262606, local time: 83264812
                                          INFO  [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
                                          INFO  [muorb] [qshell]   arg0 = 'qmc5883l'
                                          INFO  [muorb] [qshell]   arg2 = '-R'
                                          INFO  [muorb] [qshell]   arg3 = '10'
                                          INFO  [muorb] [qshell]   arg4 = '-X'
                                          INFO  [muorb] [qshell]   arg5 = '-b'
                                          INFO  [muorb] [qshell]   arg6 = '1'
                                          INFO  [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
                                          INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 1
                                          ERROR [muorb] [drivers__device] i2c probe failed
                                          INFO  [muorb] [SPI_I2C] PX4_qshell: no instance started (no device on bus?)
                                          ERROR [muorb] [qshell] Failed to execute command: qmc5883l start -R 10 -X -b 1
                                          INFO  [qshell] qshell return value timestamp: 83324177, local time: 83325854
                                          ERROR [qshell] Command failed
                                          INFO  [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
                                          INFO  [muorb] [qshell]   arg0 = 'ist8310'
                                          INFO  [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
                                          ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R 10 -X -b 1
                                          INFO  [qshell] qshell return value timestamp: 83374408, local time: 83377531
                                          Looking for ist8308 magnetometer
                                          INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
                                          INFO  [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
                                          INFO  [muorb] [qshell]   arg0 = 'ist8308'
                                          INFO  [muorb] [qshell]   arg3 = '12'
                                          INFO  [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
                                          ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R 12 -X -b 1
                                          INFO  [qshell] qshell return value timestamp: 83413213, local time: 83416595
                                          INFO  [muorb] [qshell] qshell gotten: gps start
                                          INFO  [muorb] [qshell]   arg0 = 'gps'
                                          INFO  [muorb] [tasks] Creating pthread gps
                                          INFO  [muorb] [tasks] Successfully created px4 task PX4_gps with tid 2097645
                                          INFO  [muorb] [qshell] Ok executing command: gps start
                                          INFO  [qshell] qshell return value timestamp: 83445422, local time: 83446602
                                          Looking for ncp5623c RGB LED
                                          INFO  [muorb] [gps] GPS UART baudrate set to 115200
                                          INFO  [muorb] [qshell] qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                                          INFO  [muorb] [qshell]   arg0 = 'rgbled_ncp5623c'
                                          INFO  [muorb] [qshell]   arg2 = '-X'
                                          INFO  [muorb] [qshell]   arg4 = '1'
                                          INFO  [muorb] [qshell]   arg5 = '-f'
                                          INFO  [muorb] [qshell]   arg6 = '400'
                                          INFO  [muorb] [qshell]   arg7 = '-a'
                                          INFO  [muorb] [qshell]   arg8 = '56'
                                          INFO  [muorb] [drivers__device] *** I2C Device ID 0x7b3809 8075273
                                          INFO  [muorb] [drivers__device] Set i2c address 0x38, fd 4
                                          ERROR [muorb] [qshell] Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                                          INFO  [qshell] qshell return value timestamp: 83487606, local time: 83489160
                                          Starting VOXL ESC driver
                                          INFO  [qshell] Send cmd: 'voxl_esc start'
                                          INFO  [muorb] [qshell] qshell gotten: voxl_esc start
                                          INFO  [muorb] [qshell]   arg0 = 'voxl_esc'
                                          INFO  [muorb] [voxl_esc] Starting VOXL ESC driver
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_CONFIG: 1
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_MODE: 0
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_BAUD: 2000000
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC1: 102
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC2: 103
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC3: 101
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC4: 104
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR1: 0
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR2: 0
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR3: 0
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR4: 0
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_PWR_MIN: 0.050000
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MIN: 2000
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MAX: 12000
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_PERC: 90
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_VLOG: 1
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_WARN: 0
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_OVER: 0
                                          INFO  [muorb] [voxl_esc] Params: GPIO_CTL_CH: 0
                                          INFO  [muorb] [voxl_esc] Params: VOXL_ESC_CMD: 0
                                          INFO  [muorb] [qshell] Ok executing command: voxl_esc start
                                          INFO  [muorb] [voxl_esc] Opening UART ESC device 2, baud rate 2000000
                                          INFO  [muorb] [voxl_esc] Successfully opened UART ESC device
                                          INFO  [muorb] [voxl_esc] Detecting ESCs...
                                          INFO  [muorb] [voxl_esc] 	ESC ID     : 0
                                          INFO  [muorb] [voxl_esc] 	Board Type : 40: ModalAi 4-in-1 ESC (M0129-3)
                                          INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0024
                                          INFO  [muorb] [voxl_esc] 	Firmware   : version   39, hash 9c6233d6
                                          INFO  [muorb] [voxl_esc] 	Bootloader : version  184, hash 10bf24c8
                                          INFO  [muorb] [voxl_esc] 	Reply time : 723us
                                          INFO  [muorb] [voxl_esc] VOXL_ESC:
                                          INFO  [muorb] [voxl_esc] 	ESC ID     : 1
                                          INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0028
                                          INFO  [muorb] [voxl_esc] 	Reply time : 728us
                                          INFO  [qshell] qshell return value timestamp: 83652589, local time: 83657098
                                          INFO  [muorb] [voxl_esc] 	ESC ID     : 2
                                          INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0026
                                          INFO  [muorb] [voxl_esc] 	Reply time : 718us
                                          INFO  [muorb] [voxl_esc] 	ESC ID     : 3
                                          INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0022
                                          INFO  [muorb] [voxl_esc] 	Reply time : 739us
                                          INFO  [muorb] [voxl_esc] Use extended rpm packet : 1
                                          INFO  [muorb] [voxl_esc] All ESCs successfully detected
                                          Starting GHST RC driver
                                          INFO  [qshell] Send cmd: 'ghst_rc start -d 7'
                                          INFO  [muorb] [qshell] qshell gotten: ghst_rc start -d 7
                                          INFO  [muorb] [qshell]   arg0 = 'ghst_rc'
                                          INFO  [uORB] Advertising remote topic actuator_outputs_debug
                                          INFO  [uORB] Advertising remote topic esc_status
                                          INFO  [muorb] [qshell]   arg2 = '-d'
                                          INFO  [muorb] [qshell]   arg3 = '7'
                                          INFO  [muorb] [qshell] Ok executing command: ghst_rc start -d 7
                                          INFO  [uORB] Advertising remote topic input_rc
                                          INFO  [qshell] qshell return value timestamp: 83712270, local time: 83715195
                                          INFO  [qshell] Send cmd: 'lightware_laser_i2c start -b 4'
                                          INFO  [muorb] [qshell] qshell gotten: lightware_laser_i2c start -b 4
                                          ERROR [muorb] [qshell] Command lightware_laser_i2c not found
                                          ERROR [muorb] [qshell] Failed to execute command: lightware_laser_i2c start -b 4
                                          INFO  [qshell] cmd returned with: 1
                                          INFO  [qshell] qshell return value timestamp: 83743015, local time: 83745263
                                          INFO  [muorb] [qshell] qshell gotten: sensors start
                                          INFO  [muorb] [qshell]   arg0 = 'sensors'
                                          INFO  [muorb] [modules__muorb__slpi] Deleting /data/px4/slpi/keepalive_fail
                                          INFO  [uORB] Advertising remote topic battery_status
                                          INFO  [muorb] [qshell] Ok executing command: sensors start
                                          INFO  [qshell] qshell return value timestamp: 83931906, local time: 83935646
                                          INFO  [muorb] [qshell] qshell gotten: ekf2 start
                                          INFO  [muorb] [qshell]   arg0 = 'ekf2'
                                          INFO  [muorb] [qshell] Ok executing command: ekf2 start
                                          INFO  [qshell] qshell return value timestamp: 84173695, local time: 84177522
                                          INFO  [muorb] [qshell] qshell gotten: mc_pos_control start
                                          INFO  [muorb] [qshell]   arg0 = 'mc_pos_control'
                                          INFO  [muorb] [qshell] Ok executing command: mc_pos_control start
                                          INFO  [qshell] qshell return value timestamp: 84266732, local time: 84268823
                                          INFO  [muorb] [qshell] qshell gotten: mc_att_control start
                                          INFO  [muorb] [qshell]   arg0 = 'mc_att_control'
                                          INFO  [muorb] [qshell] Ok executing command: mc_att_control start
                                          INFO  [qshell] qshell return value timestamp: 84320268, local time: 84321796
                                          INFO  [muorb] [qshell] qshell gotten: mc_rate_control start
                                          INFO  [muorb] [qshell]   arg0 = 'mc_rate_control'
                                          INFO  [muorb] [qshell] Ok executing command: mc_rate_control start
                                          INFO  [qshell] qshell return value timestamp: 84408066, local time: 84410267
                                          INFO  [muorb] [qshell] qshell gotten: mc_hover_thrust_estimator start
                                          INFO  [muorb] [qshell]   arg0 = 'mc_hover_thrust_estimator'
                                          INFO  [muorb] [qshell] Ok executing command: mc_hover_thrust_estimator start
                                          INFO  [qshell] qshell return value timestamp: 84462789, local time: 84464375
                                          INFO  [muorb] [qshell] qshell gotten: mc_autotune_attitude_control start
                                          INFO  [muorb] [qshell]   arg0 = 'mc_autotune_attitude_control'
                                          INFO  [muorb] [qshell] Ok executing command: mc_autotune_attitude_control start
                                          INFO  [qshell] qshell return value timestamp: 84514600, local time: 84516557
                                          INFO  [muorb] [qshell] qshell gotten: land_detector start multicopter
                                          INFO  [muorb] [qshell]   arg0 = 'land_detector'
                                          INFO  [muorb] [qshell]   arg2 = 'multicopter'
                                          INFO  [muorb] [qshell] Ok executing command: land_detector start multicopter
                                          INFO  [qshell] qshell return value timestamp: 84553505, local time: 84556075
                                          INFO  [uORB] Advertising remote topic vehicle_land_detected
                                          INFO  [qshell] Send cmd: 'manual_control start'
                                          INFO  [muorb] [qshell] qshell gotten: manual_control start
                                          INFO  [muorb] [qshell]   arg0 = 'manual_control'
                                          INFO  [muorb] [qshell] Ok executing command: manual_control start
                                          INFO  [qshell] qshell return value timestamp: 84597175, local time: 84598418
                                          INFO  [uORB] Advertising remote topic manual_control_setpoint
                                          INFO  [qshell] Send cmd: 'control_allocator start'
                                          INFO  [muorb] [qshell] qshell gotten: control_allocator start
                                          INFO  [muorb] [qshell]   arg0 = 'control_allocator'
                                          INFO  [uORB] Advertising remote topic control_allocator_status
                                          INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                                          INFO  [uORB] Advertising remote topic actuator_motors
                                          INFO  [uORB] Advertising remote topic actuator_servos
                                          INFO  [uORB] Advertising remote topic actuator_servos_trim
                                          INFO  [muorb] [qshell] Ok executing command: control_allocator start
                                          INFO  [qshell] qshell return value timestamp: 84809648, local time: 84811022
                                          INFO  [qshell] Send cmd: 'load_mon start'
                                          INFO  [muorb] [qshell] qshell gotten: load_mon start
                                          INFO  [muorb] [qshell]   arg0 = 'load_mon'
                                          INFO  [muorb] [qshell] Ok executing command: load_mon start
                                          INFO  [uORB] Advertising remote topic cpuload
                                          INFO  [qshell] qshell return value timestamp: 84866816, local time: 84868801
                                          INFO  [qshell] Send cmd: 'rc_update start'
                                          INFO  [muorb] [qshell] qshell gotten: rc_update start
                                          INFO  [muorb] [qshell]   arg0 = 'rc_update'
                                          INFO  [muorb] [qshell] Ok executing command: rc_update start
                                          INFO  [qshell] qshell return value timestamp: 85094704, local time: 85096473
                                          INFO  [uORB] Advertising remote topic rc_channels
                                          INFO  [qshell] Send cmd: 'commander start'
                                          INFO  [muorb] [qshell] qshell gotten: commander start
                                          INFO  [muorb] [qshell]   arg0 = 'commander'
                                          INFO  [muorb] [tasks] Creating pthread commander
                                          INFO  [muorb] [tasks] Successfully created px4 task PX4_commander with tid 2097638
                                          INFO  [uORB] Advertising remote topic led_control
                                          INFO  [muorb] [commander] LED: open /dev/led0 failed (22)
                                          INFO  [uORB] Advertising remote topic tune_control
                                          INFO  [muorb] [qshell] Ok executing command: commander start
                                          INFO  [qshell] qshell return value timestamp: 85278466, local time: 85282382
                                          INFO  [uORB] Advertising remote topic event
                                          INFO  [uORB] Advertising remote topic mavlink_log
                                          INFO  [muorb] [health_and_arming_checks] Preflight Fail: Compass Sensor 0 missing
                                          INFO  [uORB] Advertising remote topic health_report
                                          INFO  [uORB] Advertising remote topic failsafe_flags
                                          INFO  [uORB] Advertising remote topic actuator_armed
                                          INFO  [uORB] Advertising remote topic vehicle_control_mode
                                          INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
                                          INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
                                          INFO  [uORB] Advertising remote topic vehicle_status
                                          INFO  [uORB] Advertising remote topic failure_detector_status
                                          INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
                                          INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
                                          INFO  [qshell] Send cmd: 'flight_mode_manager start'
                                          INFO  [muorb] [qshell] qshell gotten: flight_mode_manager start
                                          INFO  [muorb] [qshell]   arg0 = 'flight_mode_manager'
                                          INFO  [uORB] Advertising remote topic vehicle_command
                                          INFO  [muorb] [qshell] Ok executing command: flight_mode_manager start
                                          INFO  [qshell] qshell return value timestamp: 85385231, local time: 85387168
                                          INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                                          INFO  [muorb] [uORB] Advertising remote topic transponder_report
                                          INFO  [muorb] [uORB] Advertising remote topic rtl_time_estimate
                                          INFO  [muorb] [uORB] Advertising remote topic position_setpoint_triplet
                                          INFO  [mpa] Successfully loaded library libmodal_pipe.so
                                          INFO  [muorb] [uORB] Advertising remote topic telemetry_status
                                          INFO  [muorb] [uORB] Advertising remote topic offboard_control_mode
                                          INFO  [muorb] [uORB] Advertising remote topic obstacle_distance
                                          INFO  [uORB] Advertising remote topic actuator_controls_status_0
                                          INFO  [muorb] [uORB] Advertising remote topic timesync_status
                                          INFO  [muorb] [uORB] Advertising remote topic vehicle_visual_odometry
                                          INFO  [uORB] Advertising remote topic estimator_aid_src_ev_hgt
                                          INFO  [uORB] Advertising remote topic estimator_aid_src_ev_pos
                                          INFO  [uORB] Advertising remote topic estimator_aid_src_ev_vel
                                          INFO  [uORB] Advertising remote topic estimator_aid_src_ev_yaw
                                          INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                                          INFO  [muorb] [uORB] Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                                          INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                                          pxh> INFO  [logger] logger started (mode=all)
                                          INFO  [muorb] [gps] GPS UART baudrate set to 9600
                                            @voxltester slpi_proc = SLPI = SSC = DSP. I think the only option at this point is to attach an oscilloscope and verify the signals.
