  3. Calibrate Tracking Cameras Starling 2
13 Posts 2 Posters 1.4k Views 1 Watching
  • G Offline
    G Offline
    greg_s
    I am trying to calibrate the tracking cameras on my Starling 2. After running voxl-configure-mpa it seems that the calibration files for the tracking cameras is missing.
    Here is the current configuration:
    kernel: #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125
    hw platform: M0054
    mach.var: 1.0.0
    SKU: MRB-D0014-4-V1-C27-T8-M22-X0
    voxl-suite: 1.4.5
    It has the three tracking cameras, hi-res camera, and ToF sensor.
    I follow the configuration wizard (voxl-configure-sku --wizard) with these options:
    camera configuration: 27
    transmitter options: 8
    lepton: 2 / no
    modem hardware: 22
    I then ran voxl-configure-mpa after the configuration. I got the following output:
         FAILED TO EXECUTE the following steps:
    voxl-configure-cameras 27
      Encountered Problems Configuring MPA Services :-/
        Some Services may not start up on next reboot
    Calibration File Status:
    Present /data/modalai/voxl-imu-server.cal
    Missing /data/modalai/opencv_tracking_front_intrinsics.yml
    Missing /data/modalai/opencv_tracking_down_intrinsics.yml
    Missing /data/modalai/opencv_tracking_rear_intrinsics.yml
    Present /data/px4/param/parameters_gyro.cal
    Present /data/px4/param/parameters_acc.cal
    Present /data/px4/param/parameters_level.cal
    Present /data/px4/param/parameters_baro_tc.cal
    Present /data/px4/param/parameters_mag.cal
    Detected Missing Calibration Files
    please run the required cals
    https://docs.modalai.com/calibration/
                PLEASE POWER CYCLE YOUR VOXL
    Following the documentation on calibration, I tried to calibrate the cameras. I tried the following commands:
    voxl-calibrate-camera "tracking front" -f
    voxl-calibrate-camera tracking -f
    voxl-calibrate-camera "tracking down" -f
    I opened the VOXL portal and was not able to see the camera feed for the calibration. I included a screen shot of the camera_calibrator_overlay section of the VOXL portal.
    • G greg_s
      hw platform: M0054
      mach.var: 1.0.0
      voxl-suite: 1.4.5
      lepton: 2 / no
      modem hardware: 22
      @greg_s If you can provide the serial number of your drone, I can check our database to see if we have them backed up.
      The serial number should be on a white sticker in the form MXX00000XXX
        @tom Can you also run voxl-configure-cameras and post the output so I can see the available options it gives you?
        G 1 Reply Last reply
          G Offline
          G Offline
          greg_s
          wrote on last edited by greg_s
          @tom
          I don't really get any options when I try the configure camera command:
          voxl2:~$ voxl-calibrate-camera tracking -f
          Waiting for valid pipe...
          It just says waiting for valid pipe.
          I will double check the stickers and provide the serial number once I find it.
          • G greg_s
            @tom
            @greg_s It's a different command, not the calibration command, voxl-configure-cameras
              G Offline
              G Offline
              greg_s
              @tom The output is as follows:
              **voxl2:~$ voxl-configure-cameras
              Available camera config IDs are as follows:
              01 - ov7251 tracking ov7251 stereo
              02 - ov7251 tracking
              03 - ov7251 tracking ov7251 stereo imx214 hires
              04 - ov7251 tracking imx214 hires
              05 - pmd-tof ov7251 tracking
              06 - D0005 Starling pmd-tof imx214 hires ov7251 tracking
              08 - imx214
              09 - pmd-tof
              10 - ov7251 stereo
              11 - D0006 Sentinel
              12 - ov9782 stereo
              13 - ov9782 stereo imx214 hires
              14 - ov9782 stereo pmd-tof ov7251 tracking (copy)
              15 - D0008 dual 9782 tracking
              16 - pmd-tof ov7251 dual tracking imx214 hires
              17 - D0010 pmd-tof imx412 hires ov7251 tracking ov9782 stereo
              18 - D0008 triple ov9782
              19 - D0005 without tof imx214 hires ov7251 tracking
              20 - D0011 imx412 hires ar0144 tracking
              21 - old C6
              23 - D0010 without stereo
              24 - pmd-tof LIOW2 (new TOF)
              25 - dual ar0144
              31 - D0013 Prototype M0135 dual ar0144
              32 - D0008 triple ov9782 rotated
              C - use user-defined custom camera config in
              (/data/modalai/custom_camera_config.txt)
              q - Quit The Wizard**
              I don't see the option that I saw when using the sku wizard:
              **Available camera config IDs are as follows:
                      Welcome to the voxl-configure-sku Wizard!
              VOXL currently thinks it is in the following hardware:
              family code: MRB-D0011 (px4-autonomy-dev-kit)
              compute board: 4 (voxl2)
              hw version: 1
              cam config: 20
              modem config: 0 (none)
              tx config: 7 (elrs_beta_fpv)
              extras config: 0 (none)
              SKU: MRB-D0011-4-V1-C20-T7-M0-X0
              If this is what you want, select 1 (accept and continue) to
              leave it as-is. Otherwise, select the desired product family:
              1. accept and continue 14) voxlcam
              2. starling-2 15) seeker-legacy
              3. starling-2-max 16) rb5-flight
              4. seeker-vision 17) flight-deck
              5. stinger 18) voxl-deck
              6. sparrow 19) voxl2-flight-deck
              7. seeker-max 20) voxl2-test-fixture
              8. starling-1-discontinued 21) voxl2-mini-test-fixture
              9. px4-autonomy-dev-kit 22) voxl2-board-only
              10. sentinel 23) voxl2-mini-board-only
              11. D0010 24) MVX-T0001
              12. D0015 25) MVX-R0001
              13. m500 26) quit
                #? 2
                selected starling-2
              If you would like to select a special camera config that differs
              from the default for your product family, please select an option.
              Simply hit ENTER to use the default
              08 - imx214
              09 - pmd-tof
              10 - ov7251 stereo
              11 - D0006 Sentinel
              12 - ov9782 stereo
              21 - old C6
              25 - dual ar0144
              q - Quit The Wizard
              The default camera configs for Starling 2 are
              26 (imx412 hires, dual ar0144 tracking)
              27 (imx412 hires, triple ar0144 tracking)
              selection: 27
              Selected numerical camera config
              For VOXL 2 and VOXL 2 Mini based drones, there are several transmitter options.
              Please select the appropriate one.
              Select a numeric option:
              0) none
              1. Spektrum
              2. TBS Crossfire
              3. ELRS (Beta FPV Default)
              4. ELRS (ModalAI M0184)
              5. Ghost
              6. ELRS (ModalAI M0193)
                #? 8
              For Starling 2 and Starling 2 Max drones, there is an optional lepton sensor.
              Is a lepton sensor installed on your drone? (-X8).
              1. yes
              2. no
                #? 2
              Select the modem hardware.
              Simply hit ENTER if none
              0 - none
              1 - unknown
              3 - Microhard v2, No Radio (M0048-3)
              4 - LTE v2, 7610 NA (M0030)
              5 - LTE v2, 7607 EMEA EOL (M0030)
              6 - LTE v2, No Modem (M0030)
              7 - VOXL 2 5G Quectel (M0067/M0090-3-01)
              8 - LTE v2, 7611 NA (M0030)
              9 - VOXL 2 5G Telit (M0090-1-03)
              10 - Microhard v2, pMDDL2350 (M0048)
              11 - Microhard v2, pMDDL2450(M0048)
              12 - LTE v2, 7620 EMEA (M0030)
              13 - M0078-2 w/ Alpha WiFi Dongle, AC600
              14 - VOXL 5G Telit (M0090-1-03)
              15 - VOXL 2 5G Quectel (M0090-3-01)
              16 - M0078-2 w/ Alfa Networks WiFi Dongle, AC1200
              17 - M0078-2 w/ Alfa Networks WiFi Dongle, AC600 (modified)
              18 - Doodle RM-2450, 2.4GHz
              19 - Doodle RM-2025, Hex Band
              20 - M0130 RC7611 (Americas)
              21 - M0130 RC7620 (EMEA)
              22 - M0141 w/ Alfa Networks WiFi Dongle AWUS036EACS
              23 - Doodle Mini-OEM, RM-1700-22M3 (915MHz, 2.4GHz)
              24 - M0090-3-2 Sierra EM9291)
              25 - VTX (M0176 + M0175)
              26 - VTX (M0185)
              27 - Microhard, pMDDL1621 (M0059-1)
              28 - M0151 w/ Alfa Networks WiFi Dongle AWUS036EACS
              29 - Microhard v2, pMDDL 1800 (M0048)
              30 - VRX (M0206, Mini Pini)
              31 - VRX (M0206, SparkLAN)
              32 - WaveMux
              2026 - M0130 RC7611 (Americas) + VTX (M0185)
              2126 - M0130 RC7620 (EMEA) + VTX (M0185)
              q - Quit The Wizard
              selection: 22
              Selected numerical modem config
              Your answers would construct the following SKU:
              family code: MRB-D0014 (starling-2)
              hw version: 1
              cam config: 27
              modem config: 22 (M0141 w/ Alfa Networks WiFi Dongle AWUS036EACS)
              tx config: 8 (elrs_m0184)
              This sku will be saved to persistent memory so VOXL
              will remember what it is installed in, even between
              system image flashes.
              Press enter to accept and continue.**
              The SKU wizard did throw an error for configuration 27
              available camera configurations are as follows:
              08 - imx214
              09 - pmd-tof
              10 - ov7251 stereo
              11 - D0006 Sentinel
              12 - ov9782 stereo
              21 - old C6
              25 - dual ar0144
              FAILED TO EXECUTE: voxl-configure-cameras 27
              The serial number is M23000003CZ.
              The drone was originally a PX4 Dev Kit. But, it has been upgraded with the parts for a Starling 2 with 3 tracking sensors. Support helped provide the necessary parts and brackets. The main addition is the:
              MDK-M0187-1-01 Dev Kit, VOXL 2 Lepton Plus TOF V2 Adapter Board & MCBL-00105-2
              The Lepton adapter board isn't connect as there currently isn't a sensor attached. I have attached pictures of the drone fully assembled.
              • G greg_s
                08 - imx214
                09 - pmd-tof
                10 - ov7251 stereo
                11 - D0006 Sentinel
                12 - ov9782 stereo
                21 - old C6
                25 - dual ar0144
                hw version: 1
                cam config: 20
                13. m500 26) quit
                  #? 2
                  selected starling-2
                08 - imx214
                09 - pmd-tof
                10 - ov7251 stereo
                11 - D0006 Sentinel
                12 - ov9782 stereo
                21 - old C6
                25 - dual ar0144
                q - Quit The Wizard
                selection: 27
                0) none
                1. Spektrum
                2. TBS Crossfire
                5. Ghost
                  #? 8
                1. yes
                2. no
                  #? 2
                0 - none
                1 - unknown
                26 - VTX (M0185)
                32 - WaveMux
                q - Quit The Wizard
                selection: 22
                hw version: 1
                cam config: 27
                08 - imx214
                09 - pmd-tof
                10 - ov7251 stereo
                11 - D0006 Sentinel
                12 - ov9782 stereo
                21 - old C6
                25 - dual ar0144
                @greg_s Okay you'll need to load a different kernel on your drone in order to support that camera configuration. (27) That is why it is not showing up in the list of supported configs.
                You can do the following:
                cd voxl2_SDK_1.4.5.tar.gz
                cd system-image
                adb reboot bootloader
                fastboot flash boot_a m0054-1-var00.1-kernel.img
                fastboot flash boot_b m0054-1-var00.1-kernel.img
                fastboot reboot
                Once rebooted, you can now run voxl-configure-cameras 27
                  cd system-image
                  fastboot reboot
                  G Offline
                  G Offline
                  greg_s
                  @tom Thanks for the help. I followed your instructions and rebooted. When I inspect the services, I get the output:
                  voxl2:~$ voxl-inspect-services
                  Scanning services...
                  Service Name | Enabled | Running | CPU Usage
                  docker-autorun | Disabled | Not Running |
                  modallink-relink | Disabled | Not Running |
                  voxl-camera-server | Enabled | Running | 66.7%
                  voxl-cpu-monitor | Enabled | Running | 0.0%
                  voxl-dfs-server | Disabled | Not Running |
                  voxl-elrs-startup | Disabled | Not Running |
                  voxl-feature-tracker | Disabled | Not Running |
                  voxl-flow-server | Disabled | Not Running |
                  voxl-imu-server | Enabled | Running | 3.5%
                  voxl-io-server | Disabled | Not Running |
                  voxl-lepton-server | Disabled | Not Running |
                  voxl-lepton-tracker | Disabled | Not Running |
                  voxl-logger | Disabled | Not Running |
                  voxl-mapper | Enabled | Running | 1.8%
                  voxl-mavcam-manager | Enabled | Running | 0.0%
                  voxl-mavlink-server | Enabled | Running | 3.5%
                  voxl-modem | Disabled | Not Running |
                  voxl-open-vins-server | Enabled | Not Running |
                  voxl-osd | Disabled | Not Running |
                  voxl-portal | Enabled | Running | 0.0%
                  voxl-px4-imu-server | Disabled | Not Running |
                  voxl-px4 | Enabled | Running | 24.6%
                  voxl-qvio-server | Disabled | Not Running |
                  voxl-rangefinder-server | Enabled | Not Running |
                  voxl-remote-id | Disabled | Not Running |
                  voxl-seek-server | Disabled | Not Running |
                  voxl-softap | Disabled | Not Running |
                  voxl-state-estimator | Disabled | Not Running |
                  voxl-static-ip | Disabled | Not Running |
                  voxl-streamer | Enabled | Running | 0.0%
                  voxl-tag-detector | Disabled | Not Running |
                  voxl-tflite-server | Disabled | Not Running |
                  voxl-time-sync | Disabled | Not Running |
                  voxl-uvc-server | Disabled | Not Running |
                  voxl-vision-hub | Enabled | Running | 3.5%
                  voxl-vrx | Disabled | Not Running |
                  voxl-vtx | Disabled | Not Running |
                  voxl-wait-for-fs | Enabled | Completed |
                  Is there anything else I should check/configure before attempting to fly and use the mapper service?
                  • G greg_s
                    @greg_s That looks normal to me. I would start by attempting a manual flight before doing any cv-based flights:
                    https://www.youtube.com/watch?v=Cpbbye3Z6co
                      G Offline
                      G Offline
                      greg_s
                      #10
                      @tom Thanks. I ran the check calibration:
                      voxl-check-calibration
                      I assume I should calibrate the tracking cameras still.
                      • G greg_s
                        @greg_s Was this originally a starling 1 that was upgraded to a starling 2?
                        If so, you will need to re-calibrate the tracking cameras for this new drone.
                        See here: https://docs.modalai.com/calibrate-cameras/
                          G Offline
                          G Offline
                          greg_s
                          #12
                          @tom It was a PX 4 Dev Kit. But, thanks for the help. I was able to get the cameras calibrated. I will testing the manual and hold position fly-modes before trying any cv-based flight/navigation. I'll start a new thread for any future questions.
                          • G greg_s
                            @greg_s Great! Sounds good
