  3. Flight Core V2 Magnetometer and Barometer Issues
20 Posts 3 Posters 2.9k Views 1 Watching
  • L Offline
    L Offline
    linmur02
    I am getting errors while trying to set up my drone.
    System:
    Flight Core V2 Flight Controller running PX4 (Latest)
    VOXL FPV 4-in-1 ESC
    Mateksys SAM-M10Q GPS
    Issues:
    I am getting a persistent "Magnetometer sensor #0 failure: Timeout" on QGroundControl. Does the FC V2 have it's own magnetometer? Is the issue related to the onboard mag or the M10Q GPS I am trying to use? Upon rebooting, I will usually get the same error, but sometimes I get a "found 0 compass (required 1)" error.
    I am also getting a "Barometer 0 Missing" error, but not consistently, sometimes a reboot will clear that error, sometimes it will not.
    Any help in getting the barometer and gps properly set up would be greatly appreciated.
    • L linmur02
      System:
      VOXL FPV 4-in-1 ESC
      Issues:
      Eric KatzfeyE Online
      @linmur02 When you say "latest", which version, specifically, are you using? Yes, the FC V2 does have an internal magnetometer, but in both the ModalAI fork and on mainline the internal magnetometer is not enabled so any mag issues should be related to the mag on the GPS unit. Is the GPS being seen reliably? The barometer is on the board and shouldn't have any issues. If you disconnect that GPS unit do you still see occasional barometer missing errors? Also, can you start swapping out hardware to see if the issues are related to a hardware problem?
      L 1 Reply Last reply
        L Offline
        L Offline
        linmur02
        @Eric-Katzfey Hi Eric, I believe I solved the Magnetometer sensor failure issues. Extreme interference from my radio transmitter was causing issues. I swapped it out to a different radio and that issue is no longer happening. I am still getting barometer issues though. It seems as if every other time I boot the drone on the barometer says its missing. Usually a reboot will solve this, but even when it isn't missing, the barometer seems to be having issues. I am getting close to 5ft in elevation variance when in Altitude and Position flight modes. Even when the gps is disconnected I am still getting these errors. Could it be a faulty or damaged flight controller?
        • L linmur02
          @linmur02 The barometer should come up every time. Can you test your FCv2 separately from the drone? Do you have any other FCv2 units, or just that single one? It would be good to isolate it as much as possible and then verify that you see it very single time. Do a complete power cycle between each attempt.
            L Offline
            L Offline
            linmur02
            @Eric-Katzfey I could not get the barometer issues to show while strictly isolating the flight core v2, but I also have another FCv2 unit that I just completed assembling... after several hours of intermittent ESC connection issues (VOXL FPV ESC) the Baro 0 Missing error started displaying on the second flight core unit as well. Please advise.
            • L linmur02
              @linmur02 So you are saying that the original unit with failures stops failing when run in isolation. And that the second FC v2 is failing but it is assembled into a drone like the first unit when it was failing? If that's the case then you have some interference that is causing errors on the i2c lines to the barometer.
                L Offline
                L Offline
                linmur02
                @Eric-Katzfey Yes, that is what appears to be happening. However I cannot properly isolate the FCv2 because other errors are present in QGroundControl due to the other missing components when trying to run the board in isolation. (GPS errors, RC Input Errors, etc.)
                • L linmur02
                  @linmur02 Even with those other errors you should still be able to check whether barometer has been detected and is providing data.
                    L Offline
                    L Offline
                    linmur02
                    @Eric-Katzfey Yes, I would agree. So what is the path I need to take to fix these issues? The entire setup consists of a Modal AI FCv2, a Modal AI FPV 4-in-1 ESC (over UART), a Mateksys SAM-M10Q into the "J10" port, a Spektrum FPV Racing Serial Receiver into the "J12" port, an RF Design 900x US Telemetry radio into the "J1" port, a USB to serial adapter (for connection to QGROUNDCONTROL) into the "J3" port, and I am powering my VTX system from the 5V and Ground out of the "J7" PWM port. There is nothing in my system that should be causing interference with the barometer, especially if the barometer is over I2C, because I am connected to all my other basic components via serial connections.
                    • L linmur02
                      @linmur02 You need to figure out what is causing the interference. Start adding one thing at a time or if starting with the full drone, removing one item at a time and see if you can figure out what is causing the trouble.
                      E 1 Reply Last reply
                        E Offline
                        E Offline
                        emarcphera
                        wrote on last edited by emarcphera
                        #11
                        @Eric-Katzfey Hello I am also getting "barometer 0 missing" occasionally, a reboot or two also usually fixes it for me. I get it occasionally even when I'm powering the flight core V2 only on my drone (nothing else on my drone is powered), using J3 USB connector. I also just tested it with another flight corev2 unit, one that is fresh and not on any drone and also just powered with J3, it also gets this error. It seems that whenever It's initially powered, the barometer won't be detected until I reboot.
                        I did some further debugging using the MAVlink Console in QGC, it seems when the "barometer sensor 0 missing" occurs the icp driver doesn't actually start.
                        nsh> icp201xx status
                        INFO [SPI_I2C] Not running
                        nsh> icp201xx start -I
                        icp201xx #0 on I2C bus 4 (external) address 0x63
                        nsh> listener sensor_baro
                        TOPIC: sensor_baro
                        sensor_baro
                        timestamp: 253700745 (0.020062 seconds ago)
                        timestamp_sample: 253698133 (2612 us before timestamp)
                        device_id: 12084001 (Type: 0xB8, I2C:4 (0x63))
                        pressure: 96713.71094
                        temperature: 51.86063
                        error_count: 0
                        • E emarcphera
                          TOPIC: sensor_baro
                          sensor_baro
                          error_count: 0
                          @emarcphera It won't be running because when it was initially started it failed and exited. What version of PX4 are you using?
                            E Offline
                            E Offline
                            emarcphera
                            #13
                            @Eric-Katzfey
                            Hello, thank you for responding, the PX4 version is 1.14
                            nsh> ver all
                            HW arch: MODALAI_FC_V2
                            HW type: V2003000
                            HW version: 0x003
                            HW revision: 0x000
                            PX4 git-hash: 5e6a8c257371b6c45e55662daac5fe9fbd08040b
                            PX4 version: 1.14.0 0 (17694720)
                            Vendor version: 2.0.94 0 (33578496)
                            OS: NuttX
                            OS version: Release 11.0.0 (184549631)
                            OS git-hash: 3f77354c0dc88793a47ff3b57595195ab45f7ba9
                            Build datetime: Feb 20 2025 01:58:47
                            Build uri: localhost
                            Build variant: default
                            Toolchain: GNU GCC, 9.3.1 20200408 (release)
                            PX4GUID: 0006000000003333363031315106002b0036
                            MCU: STM32H7[4|5]xxx, rev. V
                            nsh>
                            I noticed that /etc/init.d/rc.board_sensors is where icp201xx -I start is ran:
                            nsh> cat /etc/init.d/rc.board_sensors | grep -nE 'icp201|bmp388'
                            board_adc start
                            voxlpm -X -b 3 -k -T VBATT start
                            voxlpm -X -b 3 -T P5VDC start
                            icm42688p -s -b 1 -R 12 start
                            icm42688p -s -b 2 -R 12 start
                            icp201xx -I start
                            if param greater VOXL_ESC_CONFIG 0
                            then
                            usleep 1500000
                            voxl_esc start
                            fi
                            I didn't want to mess with the file (not sure if I can), so I just installed a microsd card to the flight core and created this file:
                            nsh> cat /fs/microsd/etc/extras.txt
                            usleep 2500000
                            icp201xx stop
                            usleep 300000
                            icp201xx start -I -b 4 -a 0x63 -q
                            nsh>
                            just icp201xx start -I should also work, but I have repowered this flight core and used it on other flight cores multiple times and this issue no longer occurs. My guess is it's just a timing issue, icp201xx start is probably failing in rc.board_sensors because the barometer rail isn't fully up at that moment.
                            Eric KatzfeyE 4 Replies Last reply
                            • E emarcphera
                              @Eric-Katzfey
                              nsh> ver all
                              HW type: V2003000
                              HW version: 0x003
                              HW revision: 0x000
                              OS: NuttX
                              nsh>
                              board_adc start
                              icp201xx -I start
                              then
                              usleep 1500000
                              voxl_esc start
                              fi
                              usleep 2500000
                              icp201xx stop
                              usleep 300000
                              nsh>
                              @emarcphera It's quite possible. In older versions the ESC driver was started before the barometer driver. In newer releases it has been moved after the barometer driver so the barometer driver is being started earlier in the timeline. You can see our vendor version is 2.0.94. That is where that change was made. In version 2.0.93 it has the ESC start before the barometer.
                              • E emarcphera
                                @Eric-Katzfey
                                nsh> ver all
                                HW type: V2003000
                                HW version: 0x003
                                HW revision: 0x000
                                OS: NuttX
                                nsh>
                                board_adc start
                                icp201xx -I start
                                then
                                usleep 1500000
                                voxl_esc start
                                fi
                                usleep 2500000
                                icp201xx stop
                                usleep 300000
                                nsh>
                                @emarcphera If you want to try an earlier version you can get v1.14.0-2.0.85 here: http://voxl-packages.modalai.com/dists/fc-v2/sdk-1.4/modalai_fc-v2_1.14.0-2.0.85.px4
                                • E emarcphera
                                  @Eric-Katzfey
                                  nsh> ver all
                                  HW type: V2003000
                                  HW version: 0x003
                                  HW revision: 0x000
                                  OS: NuttX
                                  nsh>
                                  board_adc start
                                  icp201xx -I start
                                  then
                                  usleep 1500000
                                  voxl_esc start
                                  fi
                                  usleep 2500000
                                  icp201xx stop
                                  usleep 300000
                                  nsh>
                                  @emarcphera I'll try to recreate the issue. If I can reproduce it I can then test a fix. Most likely would just need to add a small delay before the icp201xx start command.
                                  • E emarcphera
                                    @Eric-Katzfey
                                    nsh> ver all
                                    HW type: V2003000
                                    HW version: 0x003
                                    HW revision: 0x000
                                    OS: NuttX
                                    nsh>
                                    board_adc start
                                    icp201xx -I start
                                    then
                                    usleep 1500000
                                    voxl_esc start
                                    fi
                                    usleep 2500000
                                    icp201xx stop
                                    usleep 300000
                                    nsh>
                                    @emarcphera I cannot reproduce the issue with v1.14.0-2.0.94 nor one of our most recent builds v1.14.0-2.0.105.
                                    E 2 Replies Last reply
                                      E Offline
                                      E Offline
                                      emarcphera
                                      @Eric-Katzfey That is strange, I just upgraded the firmware to v1.14.0-2.0.98 on one of my flight core units, I got rid of the micro sd and the extras.txt file as well and I don't seem to get the "barometer sensor 0 missing" error anymore. Interestingly /etc/init.d/rc.board_sensors is the exact same so something else may be going on instead.
                                      board_adc start
                                      icp201xx -I start
                                      then
                                      usleep 1500000
                                      voxl_esc start
                                      fi
                                      nsh: cat: open failed: No such file or directory
                                      nsh>
                                        E Offline
                                        E Offline
                                        emarcphera
                                        @Eric-Katzfey One more update, I ended up upgrading the firmware to v1.14.0-2.0.98 for all the flight core units that I have and I'm confident the barometer missing issue is gone now. Thank you for your help and your quick responses.
                                        • E emarcphera
                                          @emarcphera Huh, interesting. Okay, thanks for posting the update!
