  3. Flight Core V2 Magnetometer and Barometer Issues
20 Posts 3 Posters 2.9k Views 1 Watching
  • L linmur02
    @Eric-Katzfey I could not get the barometer issues to show while strictly isolating the flight core v2, but I also have another FCv2 unit that I just completed assembling... after several hours of intermittent ESC connection issues (VOXL FPV ESC) the Baro 0 Missing error started displaying on the second flight core unit as well. Please advise.
    @linmur02 So you are saying that the original unit with failures stops failing when run in isolation. And that the second FC v2 is failing but it is assembled into a drone like the first unit when it was failing? If that's the case then you have some interference that is causing errors on the i2c lines to the barometer.
    L 1 Reply Last reply
      L Offline
      L Offline
      linmur02
      @Eric-Katzfey Yes, that is what appears to be happening. However I cannot properly isolate the FCv2 because other errors are present in QGroundControl due to the other missing components when trying to run the board in isolation. (GPS errors, RC Input Errors, etc.)
      • L linmur02
        @linmur02 Even with those other errors you should still be able to check whether barometer has been detected and is providing data.
          L Offline
          L Offline
          linmur02
          @Eric-Katzfey Yes, I would agree. So what is the path I need to take to fix these issues? The entire setup consists of a Modal AI FCv2, a Modal AI FPV 4-in-1 ESC (over UART), a Mateksys SAM-M10Q into the "J10" port, a Spektrum FPV Racing Serial Receiver into the "J12" port, an RF Design 900x US Telemetry radio into the "J1" port, a USB to serial adapter (for connection to QGROUNDCONTROL) into the "J3" port, and I am powering my VTX system from the 5V and Ground out of the "J7" PWM port. There is nothing in my system that should be causing interference with the barometer, especially if the barometer is over I2C, because I am connected to all my other basic components via serial connections.
          • L linmur02
            @linmur02 You need to figure out what is causing the interference. Start adding one thing at a time or if starting with the full drone, removing one item at a time and see if you can figure out what is causing the trouble.
            E 1 Reply Last reply
              E Offline
              E Offline
              emarcphera
              wrote on last edited by emarcphera
              #11
              @Eric-Katzfey Hello I am also getting "barometer 0 missing" occasionally, a reboot or two also usually fixes it for me. I get it occasionally even when I'm powering the flight core V2 only on my drone (nothing else on my drone is powered), using J3 USB connector. I also just tested it with another flight corev2 unit, one that is fresh and not on any drone and also just powered with J3, it also gets this error. It seems that whenever It's initially powered, the barometer won't be detected until I reboot.
              I did some further debugging using the MAVlink Console in QGC, it seems when the "barometer sensor 0 missing" occurs the icp driver doesn't actually start.
              nsh> icp201xx status
              INFO [SPI_I2C] Not running
              nsh> icp201xx start -I
              icp201xx #0 on I2C bus 4 (external) address 0x63
              nsh> listener sensor_baro
              TOPIC: sensor_baro
              sensor_baro
              timestamp: 253700745 (0.020062 seconds ago)
              timestamp_sample: 253698133 (2612 us before timestamp)
              device_id: 12084001 (Type: 0xB8, I2C:4 (0x63))
              pressure: 96713.71094
              temperature: 51.86063
              error_count: 0
              • E emarcphera
                TOPIC: sensor_baro
                sensor_baro
                error_count: 0
                @emarcphera It won't be running because when it was initially started it failed and exited. What version of PX4 are you using?
                  E Offline
                  E Offline
                  emarcphera
                  #13
                  Hello, thank you for responding, the PX4 version is 1.14
                  nsh> ver all
                  HW arch: MODALAI_FC_V2
                  HW type: V2003000
                  HW version: 0x003
                  HW revision: 0x000
                  PX4 git-hash: 5e6a8c257371b6c45e55662daac5fe9fbd08040b
                  PX4 version: 1.14.0 0 (17694720)
                  Vendor version: 2.0.94 0 (33578496)
                  OS: NuttX
                  OS version: Release 11.0.0 (184549631)
                  OS git-hash: 3f77354c0dc88793a47ff3b57595195ab45f7ba9
                  Build datetime: Feb 20 2025 01:58:47
                  Build uri: localhost
                  Build variant: default
                  Toolchain: GNU GCC, 9.3.1 20200408 (release)
                  PX4GUID: 0006000000003333363031315106002b0036
                  MCU: STM32H7[4|5]xxx, rev. V
                  nsh>
                  I noticed that /etc/init.d/rc.board_sensors is where icp201xx -I start is ran:
                  nsh> cat /etc/init.d/rc.board_sensors | grep -nE 'icp201|bmp388'
                  board_adc start
                  voxlpm -X -b 3 -k -T VBATT start
                  voxlpm -X -b 3 -T P5VDC start
                  icm42688p -s -b 1 -R 12 start
                  icm42688p -s -b 2 -R 12 start
                  icp201xx -I start
                  if param greater VOXL_ESC_CONFIG 0
                  then
                  usleep 1500000
                  voxl_esc start
                  fi
                  I didn't want to mess with the file (not sure if I can), so I just installed a microsd card to the flight core and created this file:
                  nsh> cat /fs/microsd/etc/extras.txt
                  usleep 2500000
                  icp201xx stop
                  usleep 300000
                  icp201xx start -I -b 4 -a 0x63 -q
                  nsh>
                  just icp201xx start -I should also work, but I have repowered this flight core and used it on other flight cores multiple times and this issue no longer occurs. My guess is it's just a timing issue, icp201xx start is probably failing in rc.board_sensors because the barometer rail isn't fully up at that moment.
                  Eric KatzfeyE 4 Replies Last reply
                  • E emarcphera
                    nsh> ver all
                    HW type: V2003000
                    HW version: 0x003
                    HW revision: 0x000
                    OS: NuttX
                    nsh>
                    board_adc start
                    icp201xx -I start
                    then
                    usleep 1500000
                    voxl_esc start
                    fi
                    usleep 2500000
                    icp201xx stop
                    usleep 300000
                    nsh>
                    @emarcphera It's quite possible. In older versions the ESC driver was started before the barometer driver. In newer releases it has been moved after the barometer driver so the barometer driver is being started earlier in the timeline. You can see our vendor version is 2.0.94. That is where that change was made. In version 2.0.93 it has the ESC start before the barometer.
                    • E emarcphera
                      nsh> ver all
                      HW type: V2003000
                      HW version: 0x003
                      HW revision: 0x000
                      OS: NuttX
                      nsh>
                      board_adc start
                      icp201xx -I start
                      then
                      usleep 1500000
                      voxl_esc start
                      fi
                      usleep 2500000
                      icp201xx stop
                      usleep 300000
                      nsh>
                      @emarcphera If you want to try an earlier version you can get v1.14.0-2.0.85 here: http://voxl-packages.modalai.com/dists/fc-v2/sdk-1.4/modalai_fc-v2_1.14.0-2.0.85.px4
                      • E emarcphera
                        nsh> ver all
                        HW type: V2003000
                        HW version: 0x003
                        HW revision: 0x000
                        OS: NuttX
                        nsh>
                        board_adc start
                        icp201xx -I start
                        then
                        usleep 1500000
                        voxl_esc start
                        fi
                        usleep 2500000
                        icp201xx stop
                        usleep 300000
                        nsh>
                        @emarcphera I'll try to recreate the issue. If I can reproduce it I can then test a fix. Most likely would just need to add a small delay before the icp201xx start command.
                        • E emarcphera
                          nsh> ver all
                          HW type: V2003000
                          HW version: 0x003
                          HW revision: 0x000
                          OS: NuttX
                          nsh>
                          board_adc start
                          icp201xx -I start
                          then
                          usleep 1500000
                          voxl_esc start
                          fi
                          usleep 2500000
                          icp201xx stop
                          usleep 300000
                          nsh>
                          @emarcphera I cannot reproduce the issue with v1.14.0-2.0.94 nor one of our most recent builds v1.14.0-2.0.105.
                          E 2 Replies Last reply
                            E Offline
                            E Offline
                            emarcphera
                            @Eric-Katzfey That is strange, I just upgraded the firmware to v1.14.0-2.0.98 on one of my flight core units, I got rid of the micro sd and the extras.txt file as well and I don't seem to get the "barometer sensor 0 missing" error anymore. Interestingly /etc/init.d/rc.board_sensors is the exact same so something else may be going on instead.
                            board_adc start
                            icp201xx -I start
                            then
                            usleep 1500000
                            voxl_esc start
                            fi
                            nsh: cat: open failed: No such file or directory
                            nsh>
                              E Offline
                              E Offline
                              emarcphera
                              @Eric-Katzfey One more update, I ended up upgrading the firmware to v1.14.0-2.0.98 for all the flight core units that I have and I'm confident the barometer missing issue is gone now. Thank you for your help and your quick responses.
                              • E emarcphera
                                @emarcphera Huh, interesting. Okay, thanks for posting the update!
