  3. Voxl2 camera RAW
Voxl2 camera RAW
6 Posts 3 Posters 969 Views 1 Watching
  • R Offline
    R Offline
    robertociuch
    Hi everyone,
    is there a way to take some raw snapshot from the HiRes camera (IMX412 w microcoax wires)?
    I see that the file created by "voxl-send-command hires_large_color snapshot" is pretty small (less then 800KB)
    The preview on the voxl portal seems even better compared to the jpg image
    thank you in advance!
    • Riccardo BenedettiR Offline
      Riccardo Benedetti
      Hi all, I work with Roberto, adding here the voxl-camera-server.conf file we are currently using.
      	"version":	0.1,
      	"fsync_en":	true,
      	"fsync_gpio":	109,
      	"cameras":	[{
      			"type":	"imx412",
      			"name":	"hires",
      			"enabled":	true,
      			"camera_id":	1,
      			"fps":	30,
      			"en_preview":	false,
      			"preview_width":	640,
      			"preview_height":	480,
      			"en_raw_preview":	false,
      			"en_small_video":	true,
      			"small_video_width":	1024,
      			"small_video_height":	768,
      			"small_venc_mode":	"h264",
      			"small_venc_br_ctrl":	"cqp",
      			"small_venc_Qfixed":	30,
      			"small_venc_Qmin":	15,
      			"small_venc_Qmax":	40,
      			"small_venc_nPframes":	9,
      			"small_venc_mbps":	2,
      			"small_venc_osd":	false,
      			"en_large_video":	true,
      			"large_video_width":	4056,
      			"large_video_height":	3040,
      			"large_venc_mode":	"h264",
      			"large_venc_br_ctrl":	"cqp",
      			"large_venc_Qfixed":	40,
      			"large_venc_Qmin":	15,
      			"large_venc_Qmax":	50,
      			"large_venc_nPframes":	29,
      			"large_venc_mbps":	40,
      			"large_venc_osd":	false,
      			"en_snapshot":	true,
      			"en_snapshot_width":	4056,
      			"en_snapshot_height":	3040,
      			"exif_focal_length":	4.5,
      			"exif_focal_length_in_35mm_format":	25,
      			"exif_fnumber":	4.5,
      			"ae_mode":	"off",
      			"gain_min":	54,
      			"gain_max":	8000,
      			"snapshot_jpeg_quality":	100
      We are using the snapshots for one of our projects and we would need to have the most detailed image possible to be processed with an external algo.
      R 1 Reply Last reply
      • Riccardo BenedettiR Riccardo Benedetti
        	"version":	0.1,
        	"fsync_en":	true,
        	"fsync_gpio":	109,
        	"cameras":	[{
        			"type":	"imx412",
        			"name":	"hires",
        			"enabled":	true,
        			"camera_id":	1,
        			"fps":	30,
        			"ae_mode":	"off",
        			"gain_min":	54,
        			"gain_max":	8000,
        R Offline
        R Offline
        robertociuch
        @Alex-Kushleyev
        We updated the voxl-camera-server to the last release, now setting the snapshot quality to 100 we get a bigger file, but it is still compressed.
        I read on a different topic that you already saw something about this
        thank you
        • R robertociuch
          @Alex-Kushleyev
          thank you
          Alex KushleyevA Online
          @robertociuch , jpg quality of 100 will still result in a lossy / compressed output. What is your goal ?
            R Offline
            R Offline
            robertociuch
            @Alex-Kushleyev
            We need to take snapshot with the best possible image quality, without compression if possible.
            It would be nice if we can save the single frames of the hires (few snapshots) in YUV NV12, which is the native format for the software we are using
            thanks
            • R robertociuch
              @Alex-Kushleyev
              thanks
              @robertociuch , you can use a tool voxl-record-raw-image which is a part of voxl-mpa-tools package, should be installed by default in the VOXL2 SDK. (see help for details for the tool)
              This allows you to save any image (whether it is bayer or yuv) at any time from command line. Would that work for you?
