  3. Camera config for M00015 stereo camera only
5 Posts 2 Posters 702 Views 2 Watching
  • KnightHawk06K Offline
    KnightHawk06
    Hello, how can I configure for just the M00015 stereo camera? I don't see that as an option and I tried creating a custom config but I get an error on that too.
    https://docs.modalai.com/voxl2-camera-configs/#c-10-front-stereo-only-ov7251
    voxl2:~$ voxl-configure-cameras
    Available camera config IDs are as follows:
    26 - M0173 Starling 2 IMX412 + dual AR0144
    27 - M0173 Starling 2 PMD IMX412 triple AR0144
    28 - M0173 Starling 2 Max dual IMX412 + dual AR0144
    29 - M0173 Starling 2 Max PMD + dual IMX412 + dual AR0144
    30 - M0173 Starling 2 Prototype dual PMD + dual IMX412 + dual AR0144
    36 - M0173 Stalker V5+ IMX412 + dual AR0144
    37 - M0173 Stalker V5+ IMX412 + dual AR0144 + Boson
    46 - M0173 Stalker V5+ IMX664 + dual AR0144
    47 - M0173 Stalker V5+ IMX664 + dual AR0144 + Boson
    C - use user-defined custom camera config in
    (/data/modalai/custom_camera_config.txt)
    q - Quit The Wizard
    selection: C
    Selecting custom camera config
    Camera Configuration: custom
    /data/modalai/custom_camera_config.txt: line 54: syntax error: unexpected end of file
    voxl2:~$ voxl-version
    kernel: #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
    hw platform: M0054
    mach.var: 1.0.1
    voxl-suite: 1.4.3
    Packages:
    Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
    Last Updated: 2025-04-17 20:21:35
    List:
    kernel-module-voxl-fsync-mod-4.19.125 1.0-r0
    kernel-module-voxl-gpio-mod-4.19.125 1.0-r0
    kernel-module-voxl-platform-mod-4.19.125 1.0-r0
    libfc-sensor 1.0.7
    libmodal-cv 0.5.16
    libmodal-exposure 0.1.3
    libmodal-journal 0.2.3
    libmodal-json 0.4.3
    libmodal-pipe 2.10.6
    libqrb5165-io 0.4.9
    libvoxl-cci-direct 0.2.5
    libvoxl-cutils 0.1.1
    modalai-slpi 1.1.19
    mv-voxl 0.1-r0
    qrb5165-bind 0.1-r0
    qrb5165-dfs-server 0.2.0
    qrb5165-imu-server 1.1.3
    qrb5165-rangefinder-server 0.1.5
    qrb5165-slpi-test-sig 01-r0
    qrb5165-system-tweaks 0.3.5
    qrb5165-tflite 2.8.0-2
    voxl-bind-spektrum 0.1.1
    voxl-camera-calibration 0.5.9
    voxl-camera-server 2.1.2
    voxl-ceres-solver 2:1.14.0-10
    voxl-configurator 1.0.0
    voxl-cpu-monitor 0.5.3
    voxl-cross-template 0.0.1
    voxl-docker-support 1.3.1
    voxl-elrs 0.4.2
    voxl-esc 1.5.1
    voxl-feature-tracker 0.5.2
    voxl-flow-server 0.3.6
    voxl-fsync-mod 1.0-r0
    voxl-gphoto2-server 0.0.10
    voxl-gpio-mod 1.0-r0
    voxl-io-server 0.0.5
    voxl-jpeg-turbo 2.1.3-5
    voxl-lepton-server 1.3.3
    voxl-lepton-tracker 0.0.4
    voxl-libgphoto2 0.0.4
    voxl-libuvc 1.0.7
    voxl-logger 0.5.0
    voxl-mavcam-manager 0.5.8
    voxl-mavlink 0.1.4
    voxl-mavlink-server 1.4.5
    voxl-modem 1.1.5
    voxl-mongoose 7.7.0-1
    voxl-mpa-to-ros 0.3.9
    voxl-mpa-tools 1.3.7
    voxl-open-vins 0.4.17
    voxl-open-vins-server 0.3.0
    voxl-opencv 4.5.5-2
    voxl-osd 0.1.3
    voxl-platform-mod 1.0-r0
    voxl-portal 0.7.9
    voxl-px4 1.14.0-2.0.98
    voxl-px4-imu-server 0.1.2
    voxl-px4-params 0.6.7
    voxl-qvio-server 1.1.1
    voxl-remote-id 0.0.9
    voxl-reset-slpi 0.0.1
    voxl-state-estimator 0.0.4
    voxl-streamer 0.7.5
    voxl-suite 1.4.3
    voxl-tag-detector 0.0.4
    voxl-tflite-server 0.3.9
    voxl-utils 1.4.6
    voxl-uvc-server 0.1.7
    voxl-vision-hub 1.8.20
    voxl-vtx 1.2.2
    voxl2-io 0.0.3
    voxl2-system-image 1.8.02-r0
    voxl2-wlan 1.0-r0
    "version": 1.0,
    "cameras": [
    "name": "stereo_left",
    "enabled": true,
    "type": "ov7251",
    "camera_id": 1,
    "format": "RAW8",
    "width": 640,
    "height": 480,
    "frame_rate": 30,
    "preview_width": 320,
    "preview_height": 240,
    "preview_frame_rate": 30,
    "preview_format": "RAW8",
    "is_stereo": true,
    "independent_exposure": false,
    "ae_desired_msv": 35,
    "ae_filter_alpha": 0.8,
    "ae_ignore_fraction": 0.2,
    "ae_slope": 0.05,
    "ae_exposure_period": 4,
    "ae_gain_period": 4
    "name": "stereo_right",
    "enabled": true,
    "type": "ov7251",
    "camera_id": 2,
    "format": "RAW8",
    "width": 640,
    "height": 480,
    "frame_rate": 30,
    "is_stereo": true,
    "ae_slope": 0.05,
    "ae_gain_period": 4
    "hal3_buffer_manager_size": 16,
    "max_hal3_request_inflight": 8,
    "smarter_buffer_allocation": false,
    "mipi_clock_speed_khz": 384000
    • KnightHawk06K KnightHawk06
      q - Quit The Wizard
      selection: C
      hw platform: M0054
      mach.var: 1.0.1
      voxl-suite: 1.4.3
      Packages:
      List:
      libfc-sensor 1.0.7
      libmodal-cv 0.5.16
      libmodal-json 0.4.3
      libqrb5165-io 0.4.9
      modalai-slpi 1.1.19
      mv-voxl 0.1-r0
      qrb5165-bind 0.1-r0
      voxl-elrs 0.4.2
      voxl-esc 1.5.1
      voxl-libuvc 1.0.7
      voxl-logger 0.5.0
      voxl-mavlink 0.1.4
      voxl-modem 1.1.5
      voxl-opencv 4.5.5-2
      voxl-osd 0.1.3
      voxl-portal 0.7.9
      voxl-streamer 0.7.5
      voxl-suite 1.4.3
      voxl-utils 1.4.6
      voxl-vtx 1.2.2
      voxl2-io 0.0.3
      voxl2-wlan 1.0-r0
      "version": 1.0,
      "cameras": [
      "enabled": true,
      "type": "ov7251",
      "camera_id": 1,
      "format": "RAW8",
      "width": 640,
      "height": 480,
      "frame_rate": 30,
      "is_stereo": true,
      "ae_slope": 0.05,
      "ae_gain_period": 4
      "enabled": true,
      "type": "ov7251",
      "camera_id": 2,
      "format": "RAW8",
      "width": 640,
      "height": 480,
      "frame_rate": 30,
      "is_stereo": true,
      "ae_slope": 0.05,
      "ae_gain_period": 4
      @KnightHawk06 With VOXL 2 different kernels enable different camera configurations. You'll want to flash the kernel that supports camera configs 1-25,
      I recommend downloading the latest SDK from downloads.modalai.com, running ./install.sh and when asked the following:
      Detected OS: Linux
      Detected: M0054-1 (QRB5165M)
      Detected: Config 1 w/ M0173 Breakout Board (Starling 2 Max, Starling 2, FPV V5)
      In order to support all of VOXL's camera configurations, specific drones require differing kernel images.
      Please select your drone hardware to proceed with flashing the appropriate kernel image.
      PLEASE SELECT WHICH KERNEL TO FLASH
      1. M0054-1 -> QRB5165M, Starling (D0005), Sentinel (D0006), FPV V4 (D0008), D0010, PX4 Dev Kit (D0011)
      2. M0054-1 -> QRB5165M w/ M0173 Camera Breakout Board, Starling 2 Max (D0012), Starling 2 (D0014), FPV V5 (D0008)
      Select your choice from the options above
      or press [Enter] to continue with current config:
      Choose option 1 for M0054-1 -> QRB5165M, Starling (D0005), Sentinel (D0006), FPV V4 (D0008), D0010, PX4 Dev Kit (D0011)
      KnightHawk06K 2 Replies Last reply
        Detected OS: Linux
        KnightHawk06
        wrote on last edited by KnightHawk06
        @tom I'm trying to flash the same version of firmware that is on the board now but with the different camera configuration but the install.sh script never progresses? It's been ~ 30 minutes.
        Running in Interactive mode.
        Flashing the following System Image:
                Build Name: 1.8.02-M0054-14.1a-perf
                Build Date: 2024-11-11
                Platform: M0054
                System Image Version: 1.8.02
        Installing the following version of voxl-suite:
                voxl-suite Version: 1.4.1
        Would you like to continue with SDK install?
        1) Yes
        2) No
        #? 1
        [INFO] adb installed
        [INFO] fastboot installed
        ----  Starting System Image Flash ----
        ----./flash-system-image.sh  ----
        Detected OS: Linux
        or press [Enter] to continue with current config: 1
        Installer Version: 1.0
        Board Version:     M0054-1 (var00.0)
        Please power off your VOXL, connect via USB,
        then power on VOXL. We will keep searching for
        an ADB or Fastboot device over USB
        [INFO] Found ADB device
        [INFO] Rebooting to fastboot
        [INFO] Found fastboot device
        [WARNING] This system image flash is intended only for the following
                  platform: VOXL2 (m0054)
                  Make sure that the device that will be flashed is correct.
                  Flashing a device with an incorrect system image will lead
                  the device to be stuck in fastboot.
        Would you like to continue with the VOXL2 (m0054) system image flash?
        1) Yes
        2) No
        #? 1
        KnightHawk06K 1 Reply Last reply
                  Platform: M0054
          1) Yes
          2) No
          #? 1
          Detected OS: Linux
          1) Yes
          2) No
          #? 1
          KnightHawk06
          @KnightHawk06 I had to update the fastboot permissions and reboot the device.
          sudo gedit /etc/udev/rules.d/51-modalai.rules
          SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="d00d", MODE="0660", GROUP="plugdev", SYMLINK+="android_fastboot"
            Detected OS: Linux
            KnightHawk06
            @tom Is there a configuration for ov7251 stereo and IMX678 (MDK-M0061-2-06)? I don't see any config for the IMX678?
            https://www.modalai.com/products/mdk-m0061-2?variant=44563858850096
            01 - ov7251 tracking ov7251 stereo
            02 - ov7251 tracking
            03 - ov7251 tracking ov7251 stereo imx214 hires
            04 - ov7251 tracking imx214 hires
            05 - pmd-tof ov7251 tracking
            06 - D0005 Starling pmd-tof imx214 hires ov7251 tracking
            08 - imx214
            09 - pmd-tof
            10 - ov7251 stereo
            11 - D0006 Sentinel
            12 - ov9782 stereo
            13 - ov9782 stereo imx214 hires
            14 - ov9782 stereo pmd-tof ov7251 tracking (copy)
            15 - D0008 dual 9782 tracking
            16 - pmd-tof ov7251 dual tracking imx214 hires
            17 - D0010 pmd-tof imx412 hires ov7251 tracking ov9782 stereo
            18 - D0008 triple ov9782
            19 - D0005 without tof imx214 hires ov7251 tracking
            20 - D0011 imx412 hires ar0144 tracking
            21 - old C6
            23 - D0010 without stereo
            24 - pmd-tof LIOW2 (new TOF)
            25 - dual ar0144
            31 - D0013 Prototype M0135 dual ar0144
            32 - D0008 triple ov9782 rotated
             q - Quit The Wizard
