    Camera config for M00015 stereo camera only
    • KnightHawk06K
      KnightHawk06
      Hello, how can I configure for just the M00015 stereo camera? I don't see that as an option and I tried creating a custom config but I get an error on that too.
      https://docs.modalai.com/voxl2-camera-configs/#c-10-front-stereo-only-ov7251
      voxl2:~$ voxl-configure-cameras
      Available camera config IDs are as follows:
      26 - M0173 Starling 2 IMX412 + dual AR0144
      27 - M0173 Starling 2 PMD IMX412 triple AR0144
      28 - M0173 Starling 2 Max dual IMX412 + dual AR0144
      29 - M0173 Starling 2 Max PMD + dual IMX412 + dual AR0144
      30 - M0173 Starling 2 Prototype dual PMD + dual IMX412 + dual AR0144
      36 - M0173 Stalker V5+ IMX412 + dual AR0144
      37 - M0173 Stalker V5+ IMX412 + dual AR0144 + Boson
      46 - M0173 Stalker V5+ IMX664 + dual AR0144
      47 - M0173 Stalker V5+ IMX664 + dual AR0144 + Boson
      C - use user-defined custom camera config in
      (/data/modalai/custom_camera_config.txt)
      q - Quit The Wizard
      selection: C
      Selecting custom camera config
      Camera Configuration: custom
      /data/modalai/custom_camera_config.txt: line 54: syntax error: unexpected end of file
      voxl2:~$ voxl-version
      kernel: #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
      hw platform: M0054
      mach.var: 1.0.1
      voxl-suite: 1.4.3
      Packages:
      Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
      Last Updated: 2025-04-17 20:21:35
      List:
      kernel-module-voxl-fsync-mod-4.19.125 1.0-r0
      kernel-module-voxl-gpio-mod-4.19.125 1.0-r0
      kernel-module-voxl-platform-mod-4.19.125 1.0-r0
      libfc-sensor 1.0.7
      libmodal-cv 0.5.16
      libmodal-exposure 0.1.3
      libmodal-journal 0.2.3
      libmodal-json 0.4.3
      libmodal-pipe 2.10.6
      libqrb5165-io 0.4.9
      libvoxl-cci-direct 0.2.5
      libvoxl-cutils 0.1.1
      modalai-slpi 1.1.19
      mv-voxl 0.1-r0
      qrb5165-bind 0.1-r0
      qrb5165-dfs-server 0.2.0
      qrb5165-imu-server 1.1.3
      qrb5165-rangefinder-server 0.1.5
      qrb5165-slpi-test-sig 01-r0
      qrb5165-system-tweaks 0.3.5
      qrb5165-tflite 2.8.0-2
      voxl-bind-spektrum 0.1.1
      voxl-camera-calibration 0.5.9
      voxl-camera-server 2.1.2
      voxl-ceres-solver 2:1.14.0-10
      voxl-configurator 1.0.0
      voxl-cpu-monitor 0.5.3
      voxl-cross-template 0.0.1
      voxl-docker-support 1.3.1
      voxl-elrs 0.4.2
      voxl-esc 1.5.1
      voxl-feature-tracker 0.5.2
      voxl-flow-server 0.3.6
      voxl-fsync-mod 1.0-r0
      voxl-gphoto2-server 0.0.10
      voxl-gpio-mod 1.0-r0
      voxl-io-server 0.0.5
      voxl-jpeg-turbo 2.1.3-5
      voxl-lepton-server 1.3.3
      voxl-lepton-tracker 0.0.4
      voxl-libgphoto2 0.0.4
      voxl-libuvc 1.0.7
      voxl-logger 0.5.0
      voxl-mavcam-manager 0.5.8
      voxl-mavlink 0.1.4
      voxl-mavlink-server 1.4.5
      voxl-modem 1.1.5
      voxl-mongoose 7.7.0-1
      voxl-mpa-to-ros 0.3.9
      voxl-mpa-tools 1.3.7
      voxl-open-vins 0.4.17
      voxl-open-vins-server 0.3.0
      voxl-opencv 4.5.5-2
      voxl-osd 0.1.3
      voxl-platform-mod 1.0-r0
      voxl-portal 0.7.9
      voxl-px4 1.14.0-2.0.98
      voxl-px4-imu-server 0.1.2
      voxl-px4-params 0.6.7
      voxl-qvio-server 1.1.1
      voxl-remote-id 0.0.9
      voxl-reset-slpi 0.0.1
      voxl-state-estimator 0.0.4
      voxl-streamer 0.7.5
      voxl-suite 1.4.3
      voxl-tag-detector 0.0.4
      voxl-tflite-server 0.3.9
      voxl-utils 1.4.6
      voxl-uvc-server 0.1.7
      voxl-vision-hub 1.8.20
      voxl-vtx 1.2.2
      voxl2-io 0.0.3
      voxl2-system-image 1.8.02-r0
      voxl2-wlan 1.0-r0
      "version": 1.0,
      "cameras": [
      "name": "stereo_left",
      "enabled": true,
      "type": "ov7251",
      "camera_id": 1,
      "format": "RAW8",
      "width": 640,
      "height": 480,
      "frame_rate": 30,
      "preview_width": 320,
      "preview_height": 240,
      "preview_frame_rate": 30,
      "preview_format": "RAW8",
      "is_stereo": true,
      "independent_exposure": false,
      "ae_desired_msv": 35,
      "ae_filter_alpha": 0.8,
      "ae_ignore_fraction": 0.2,
      "ae_slope": 0.05,
      "ae_exposure_period": 4,
      "ae_gain_period": 4
      "name": "stereo_right",
      "enabled": true,
      "type": "ov7251",
      "camera_id": 2,
      "format": "RAW8",
      "width": 640,
      "height": 480,
      "frame_rate": 30,
      "is_stereo": true,
      "ae_slope": 0.05,
      "ae_gain_period": 4
      "hal3_buffer_manager_size": 16,
      "max_hal3_request_inflight": 8,
      "smarter_buffer_allocation": false,
      "mipi_clock_speed_khz": 384000
        tom admin @KnightHawk06
        @KnightHawk06 With VOXL 2 different kernels enable different camera configurations. You'll want to flash the kernel that supports camera configs 1-25,
        I recommend downloading the latest SDK from downloads.modalai.com, running ./install.sh and when asked the following:
        Detected OS: Linux
        Detected: M0054-1 (QRB5165M)
        Detected: Config 1 w/ M0173 Breakout Board (Starling 2 Max, Starling 2, FPV V5)
        In order to support all of VOXL's camera configurations, specific drones require differing kernel images.
        Please select your drone hardware to proceed with flashing the appropriate kernel image.
        PLEASE SELECT WHICH KERNEL TO FLASH
        1. M0054-1 -> QRB5165M, Starling (D0005), Sentinel (D0006), FPV V4 (D0008), D0010, PX4 Dev Kit (D0011)
        2. M0054-1 -> QRB5165M w/ M0173 Camera Breakout Board, Starling 2 Max (D0012), Starling 2 (D0014), FPV V5 (D0008)
        Select your choice from the options above
        or press [Enter] to continue with current config:
        Choose option 1 for M0054-1 -> QRB5165M, Starling (D0005), Sentinel (D0006), FPV V4 (D0008), D0010, PX4 Dev Kit (D0011)
        KnightHawk06K 2 Replies Last reply Reply Quote 0
        • KnightHawk06K
          KnightHawk06 @tom
          @tom I'm trying to flash the same version of firmware that is on the board now but with the different camera configuration but the install.sh script never progresses? It's been ~ 30 minutes.
          Running in Interactive mode.
          Flashing the following System Image:
                  Build Name: 1.8.02-M0054-14.1a-perf
                  Build Date: 2024-11-11
                  Platform: M0054
                  System Image Version: 1.8.02
          Installing the following version of voxl-suite:
                  voxl-suite Version: 1.4.1
          Would you like to continue with SDK install?
          1) Yes
          2) No
          #? 1
          [INFO] adb installed
          [INFO] fastboot installed
          ----  Starting System Image Flash ----
          ----./flash-system-image.sh  ----
          Detected OS: Linux
          or press [Enter] to continue with current config: 1
          Installer Version: 1.0
          Board Version:     M0054-1 (var00.0)
          Please power off your VOXL, connect via USB,
          then power on VOXL. We will keep searching for
          an ADB or Fastboot device over USB
          [INFO] Found ADB device
          [INFO] Rebooting to fastboot
          [INFO] Found fastboot device
          [WARNING] This system image flash is intended only for the following
                    platform: VOXL2 (m0054)
                    Make sure that the device that will be flashed is correct.
                    Flashing a device with an incorrect system image will lead
                    the device to be stuck in fastboot.
          Would you like to continue with the VOXL2 (m0054) system image flash?
          1) Yes
          2) No
          #? 1
          KnightHawk06K 1 Reply Last reply Reply Quote 0
          • KnightHawk06K
            KnightHawk06 @KnightHawk06
            @KnightHawk06 I had to update the fastboot permissions and reboot the device.
            sudo gedit /etc/udev/rules.d/51-modalai.rules
            SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="d00d", MODE="0660", GROUP="plugdev", SYMLINK+="android_fastboot"
            • KnightHawk06K
              KnightHawk06 @tom
              @tom Is there a configuration for ov7251 stereo and IMX678 (MDK-M0061-2-06)? I don't see any config for the IMX678?
              https://www.modalai.com/products/mdk-m0061-2?variant=44563858850096
              01 - ov7251 tracking ov7251 stereo
              02 - ov7251 tracking
              03 - ov7251 tracking ov7251 stereo imx214 hires
              04 - ov7251 tracking imx214 hires
              05 - pmd-tof ov7251 tracking
              06 - D0005 Starling pmd-tof imx214 hires ov7251 tracking
              08 - imx214
              09 - pmd-tof
              10 - ov7251 stereo
              11 - D0006 Sentinel
              12 - ov9782 stereo
              13 - ov9782 stereo imx214 hires
              14 - ov9782 stereo pmd-tof ov7251 tracking (copy)
              15 - D0008 dual 9782 tracking
              16 - pmd-tof ov7251 dual tracking imx214 hires
              17 - D0010 pmd-tof imx412 hires ov7251 tracking ov9782 stereo
              18 - D0008 triple ov9782
              19 - D0005 without tof imx214 hires ov7251 tracking
              20 - D0011 imx412 hires ar0144 tracking
              21 - old C6
              23 - D0010 without stereo
              24 - pmd-tof LIOW2 (new TOF)
              25 - dual ar0144
              31 - D0013 Prototype M0135 dual ar0144
              32 - D0008 triple ov9782 rotated
               q - Quit The Wizard
