  3. Custom Camera Configuration with M0173
4 Posts 3 Posters 764 Views 1 Watching
  • S Offline
    S Offline
    swickliff
    How can I write custom-camera-config in /data/modalai with the M0173 board?
    I understand that I can edit /etc/modalai/voxl-camera-server.conf after selecting a camera configuration close to my custom set up, but I would prefer to run a custom config file instead.
    ModeratorM tomT 2 Replies Last reply
    • S swickliff
      @swickliff can you help with the config you are trying to achieve? we can review and see if it's possible first
      • S swickliff
        @swickliff This is how the voxl-camera-server.conf file is generated, using these higher level config files (the following are the M0173 configs):
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/tree/master/misc_files/usr/share/modalai/voxl-camera-server/standard_configs/platform_config_1?ref_type=heads
        These files live on target a /usr/share/modalai/voxl-camera-server/standard_configs/platform_config_1/
        You can add a new custom config here and then setup the voxl-camera-server config file by running voxl-configure-cameras XX where XX is the camera config number you've chosen
        S 1 Reply Last reply
          S Offline
          S Offline
          swickliff
          @tom Thank you!
          I am adding an imx214 on J8L.
