Custom Camera Configuration with M0173
How can I write custom-camera-config in /data/modalai with the M0173 board?
I understand that I can edit /etc/modalai/voxl-camera-server.conf after selecting a camera configuration close to my custom set up, but I would prefer to run a custom config file instead.
@swickliff can you help with the config you are trying to achieve? we can review and see if it's possible first
@swickliff This is how the voxl-camera-server.conf file is generated, using these higher level config files (the following are the M0173 configs):
These files live on target a
/usr/share/modalai/voxl-camera-server/standard_configs/platform_config_1/You can add a new custom config here and then setup the voxl-camera-server config file by running
voxl-configure-cameras XXwhereXXis the camera config number you've chosen -
