  3. voxl-px4 build error
px4-dev-kit
4 Posts 2 Posters 2.2k Views 1 Watching
  • R Offline
    R Offline
    ravi
    @Moderator
    I am trying to build voxl-px4 repo.
    https://gitlab.com/voxl-public/voxl-sdk/services/voxl-px4.git
    For build setup,
    I installed voxl-docker and voxl-cross as per - https://docs.modalai.com/voxl-docker-and-cross-installation/
    I referred for px4 docker build image, https://gitlab.com/voxl-public/rb5-flight/rb5-flight-px4-build-docker.
    according to readme.
    I tried to install hexagon SDK 4.1.0.4, using QPM3.
    But getting a post script error, every time, I tried with Ubuntu 20.04 and 22.04 also.
    Qualcomm(R) Hexagon™ SDK 4.x
    Version 4.1.0.4 for Linux
    Tool Name: HexagonSDK4.x
    Install Summary
    Install failed
    [Info] : Config File Present
    [Info] : Step 1 of 7: Checking environment
    [Info] : Step 2 of 7: Checking previous version
    [Info] : Step 3 of 7: Checking dependencies
    [Info] : Step 4 of 7: Preparing system
    [Info] : Step 5 of 7: Extracting files
    [Info] : Step 6 of 7: Configuring system
    [Error] : Post-install step failed.
    Please reach out to the owner of Hexagon SDK 4.x for more assistance.
    [Error] Install failed for Qualcomm(R) Hexagon™ SDK 4.x and version 4.1.0.4
    But as per thread - https://forum.modalai.com/topic/3079/hexagonsdk4-1-0-4-installation-fails-due-to-erro-on-license-verification?_=1738850535021
    I ignored the error and tar it and placed it in rb5-flight-px4-build-docker
    and ran setup.sh and build.sh.
    it generated the docker image rb5-flight-px4-build-docker
    So. currently this much images I have:
    ravi@ravipc:~/Desktop/modalai/build_setup/voxl-docker-cross$ voxl-docker -l
    REPOSITORY                    TAG       IMAGE ID       CREATED         SIZE
    rb5-flight-px4-build-docker   latest    54ba544d5242   5 minutes ago   8.09GB
    rb5-flight-px4-build-docker   v1.5      54ba544d5242   5 minutes ago   8.09GB
    base-px4-build-docker         v1.4      3095b633bdc3   21 months ago   2.03GB
    voxl-cross                    V2.5      63eb2f07ad21   2 years ago     1.55GB
    voxl-cross                    latest    63eb2f07ad21   2 years ago     1.55GB
    Then I tried to build and got error in building voxl-px4 - https://gitlab.com/voxl-public/voxl-sdk/services/voxl-px4
    its log is attached.
    root@bf9bfdd9f0e3:/usr/local/workspace# ./build.sh
    *** Starting build ***
    Setting up the Hexagon SDK environment locally
    HEXAGON_SDK_ROOT is : /home/4.1.0.4
    Setting up the QAIC binary for the platform
    make: Entering directory '/home/4.1.0.4/ipc/fastrpc/qaic'
    make: 'bin/qaic' is up to date.
    make: Leaving directory '/home/4.1.0.4/ipc/fastrpc/qaic'
    Could not find Androd ndk at /home/4.1.0.4/tools/android-ndk-r19c
    Please refer to /home/4.1.0.4/docs/tools/setup.html for installing the missed components
    *** Starting dependencies build ***
    -- The C compiler identification is GNU 7.5.0
    -- The CXX compiler identification is GNU 9.4.0
    -- Check for working C compiler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-gcc
    -- Check for working C compiler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-gcc -- works
    -- Check for working CXX compiler: /usr/bin/c++
    -- Check for working CXX compiler: /usr/bin/c++ -- works
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /usr/local/workspace/px4-firmware/boards/modalai/voxl2/libfc-sensor-api/build
    Scanning dependencies of target fc_sensor
    [ 50%] Building C object CMakeFiles/fc_sensor.dir/src/fc_sensor_stub.c.o
    [100%] Linking C shared library libfc_sensor.so
    [100%] Built target fc_sensor
    *** End of dependencies build ***
    *** Starting apps processor build ***
    -- PX4 version: v1.14.0-2.0.94-dev (1.14.0)
    -- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.10", minimum required is "3")
    -- PX4 config file: /usr/local/workspace/px4-firmware/boards/modalai/voxl2/default.px4board
    -- PLATFORM posix
    -- LINUX_TARGET y
    -- TOOLCHAIN aarch64-linux-gnu
    -- ROMFSROOT px4fmu_common
    -- ROOTFSDIR /data/px4
    -- PX4 config: modalai_voxl2_default
    -- PX4 platform: posix
    -- PX4 lockstep: disabled
    -- The CXX compiler identification is GNU 7.5.0
    -- The ASM compiler identification is GNU
    -- Found assembler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-gcc
    -- Check for working CXX compiler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-g++
    -- Check for working CXX compiler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-g++ -- works
    -- cmake build type: RelWithDebInfo
    -- ccache enabled (export CCACHE_DISABLE=1 to disable)
    -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/drivers/linux_pwm_out/module.yaml for VOXL2
    -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/drivers/pca9685_pwm_out/module.yaml for VOXL2
    -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/drivers/pwm_out/module.yaml for VOXL2
    -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/modules/simulation/pwm_out_sim/module_hil.yaml for VOXL2
    -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/modules/simulation/pwm_out_sim/module_sim.yaml for VOXL2
    -- ROMFS: ROMFS/px4fmu_common
    Architecture:  amd64
    ==> CPACK_INSTALL_PREFIX = @DEB_INSTALL_PREFIX@
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /usr/local/workspace/px4-firmware/build/modalai_voxl2_default
    [0/562] git submodule src/modules/microdds_client/Micro-XRCE-DDS-Client
    [2/562] git submodule src/drivers/gps/devices
    [4/562] git submodule src/modules/mavlink/mavlink
    [259/562] Performing configure step for 'libmicroxrceddsclient_project'
    -- libmicroxrceddsclient_project configure command succeeded.  See also /usr/local/workspace/px4-firmware/build/modalai_voxl2_default/src/modules/microdds_client/src/libmicroxrceddsclient_project-stamp/libmicroxrceddsclient_project-configure-*.log
    [416/562] Performing build step for 'libmicroxrceddsclient_project'
    -- libmicroxrceddsclient_project build command succeeded.  See also /usr/local/workspace/px4-firmware/build/modalai_voxl2_default/src/modules/microdds_client/src/libmicroxrceddsclient_project-stamp/libmicroxrceddsclient_project-build-*.log
    [425/562] Performing install step for 'libmicroxrceddsclient_project'
    -- libmicroxrceddsclient_project install command succeeded.  See also /usr/local/workspace/px4-firmware/build/modalai_voxl2_default/src/modules/microdds_client/src/libmicroxrceddsclient_project-stamp/libmicroxrceddsclient_project-install-*.log
    [562/562] Linking CXX executable bin/px4
    /* Auto Magically Generated file */
    /* Do not edit! */
    #pragma once
    #define PX4_GIT_VERSION_STR "5e6a8c257371b6c45e55662daac5fe9fbd08040b"
    #define PX4_GIT_VERSION_BINARY 0x5e6a8c257371b6c4
    #define PX4_GIT_TAG_STR "v1.14.0-2.0.94-dev-dirty"
    #define PX4_GIT_BRANCH_NAME ""
    #define PX4_GIT_OEM_VERSION_STR  ""
    #define PX4_GIT_TAG_OR_BRANCH_NAME "v1.14.0-2.0.94-dev-dirty" // special variable: git tag, release or master branch
    #define MAVLINK_LIB_GIT_VERSION_STR  "3ee5382d0c96134b0e1c250d8c2d54bfed0166fa"
    #define MAVLINK_LIB_GIT_VERSION_BINARY 0x3ee5382d0c96134b
    #define NUTTX_GIT_VERSION_STR  "3f77354c0dc88793a47ff3b57595195ab45f7ba9"
    #define NUTTX_GIT_VERSION_BINARY 0x3f77354c0dc88793
    #define NUTTX_GIT_TAG_STR  "v11.0.0"
    *** End of apps processor build ***
    *** Starting qurt slpi build ***
    -- PX4 config file: /usr/local/workspace/px4-firmware/boards/modalai/voxl2-slpi/default.px4board
    -- PLATFORM qurt
    -- TOOLCHAIN qurt
    -- PX4 config: modalai_voxl2-slpi_default
    -- PX4 platform: qurt
    -- The CXX compiler identification is Clang 10.0.0
    -- The C compiler identification is Clang 10.0.0
    -- The ASM compiler identification is unknown
    -- Found assembler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang
    -- Check for working CXX compiler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang++
    -- Check for working CXX compiler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang++ -- broken
    CMake Error at /usr/share/cmake-3.16/Modules/CMakeTestCXXCompiler.cmake:53 (message):
      The C++ compiler
        "/home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang++"
      is not able to compile a simple test program.
      It fails with the following output:
        Change Dir: /usr/local/workspace/px4-firmware/build/modalai_voxl2-slpi_default/CMakeFiles/CMakeTmp
        Run Build Command(s):/usr/bin/ninja cmTC_7ce90 && [1/2] Building CXX object CMakeFiles/cmTC_7ce90.dir/testCXXCompiler.cxx.o
        [2/2] Linking CXX executable cmTC_7ce90
        FAILED: cmTC_7ce90
        : && /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang++  -Wno-inconsistent-missing-override -DCONFIG_WCHAR_BUILTIN -D__CUSTOM_FILE_IO__ -mv66 -G0 -O3   -Wno-inconsistent-missing-override -DCONFIG_WCHAR_BUILTIN -D__CUSTOM_FILE_IO__ -mv66 -G0 -O3  -Wno-inconsistent-missing-override -DCONFIG_WCHAR_BUILTIN -D__CUSTOM_FILE_IO__ -mv66 -G0 -O3 -Wno-inconsistent-missing-override -DCONFIG_WCHAR_BUILTIN -D__CUSTOM_FILE_IO__ -mv66 -G0 -O3  -mv66 -mG0lib -G0 -fpic -shared -Wl,-Bsymbolic -Wl,--wrap=malloc -Wl,--wrap=calloc -Wl,--wrap=free -Wl,--wrap=realloc -Wl,--wrap=memalign -Wl,--wrap=__stack_chk_fail -Wl,/home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/target/hexagon/lib/v66/G0/pic/libc++.a -lc -mv66 -mG0lib -G0 -fpic -shared -Wl,-Bsymbolic -Wl,--wrap=malloc -Wl,--wrap=calloc -Wl,--wrap=free -Wl,--wrap=realloc -Wl,--wrap=memalign -Wl,--wrap=__stack_chk_fail -Wl,/home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/target/hexagon/lib/v66/G0/pic/libc++.a -lc CMakeFiles/cmTC_7ce90.dir/testCXXCompiler.cxx.o  -o cmTC_7ce90   && :
        hexagon-clang++: error: unable to execute command: Executable "hexagon-link" doesn't exist!
        hexagon-clang++: error: hexagon-link command failed with exit code 1 (use -v to see invocation)
        ninja: build stopped: subcommand failed.
      CMake will not be able to correctly generate this project.
      CMakeLists.txt:219 (project)
    -- Configuring incomplete, errors occurred!
    See also "/usr/local/workspace/px4-firmware/build/modalai_voxl2-slpi_default/CMakeFiles/CMakeOutput.log".
    See also "/usr/local/workspace/px4-firmware/build/modalai_voxl2-slpi_default/CMakeFiles/CMakeError.log".
    Error: /usr/local/workspace/px4-firmware/build/modalai_voxl2-slpi_default is not a directory
    make: *** [Makefile:232: modalai_voxl2-slpi] Error 1
    cat: build/modalai_voxl2-slpi_default/src/lib/version/build_git_version.h: No such file or directory
    *** End of qurt slpi build ***
    User ID is 1000
    Group ID is 1000
    *** End of build ***
    Can you provide a solution? what am I missing and how to resolve the issue?
    • R ravi
      @Moderator
      For build setup,
      Install Summary
      Install failed
      -- Configuring done
      -- Generating done
      -- PLATFORM posix
      -- LINUX_TARGET y
      Architecture:  amd64
      -- Configuring done
      -- Generating done
      /* Do not edit! */
      #pragma once
      -- PLATFORM qurt
      -- TOOLCHAIN qurt
        The C++ compiler
          FAILED: cmTC_7ce90
      User ID is 1000
      Group ID is 1000
      @ravi said in voxl-px4 build error:
      Can you, in the Docker, provide the output of ls -l /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin? It says hexagon-link cannot be found. In my Docker I see: lrwxrwxrwx 1 root root 7 Oct 4 2021 hexagon-link -> ld.qcld
      R 1 Reply Last reply
        R Offline
        R Offline
        ravi
        @Eric-Katzfey
        please find the ls output
        root@798402fd070f:/usr/local/workspace# ls -l /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin
        total 1163652
        -rwxrwxrwx 1 1000 1000     51542 Feb 11 15:59 YAMLMapParser.py
        lrwxrwxrwx 1 1000 1000         8 Feb 11 16:00 clang -> clang-10
        -rwxrwxrwx 1 1000 1000 101061712 Feb 11 16:00 clang-10
        -rwxrwxrwx 1 1000 1000   2700800 Feb 11 16:00 clang-apply-replacements
        -rwxrwxrwx 1 1000 1000  31329968 Feb 11 16:01 clang-change-namespace
        -rwxrwxrwx 1 1000 1000  63259784 Feb 11 16:01 clang-check
        -rwxrwxrwx 1 1000 1000  29689544 Feb 11 16:00 clang-extdef-mapping
        -rwxrwxrwx 1 1000 1000  30458768 Feb 11 16:01 clang-include-fixer
        -rwxrwxrwx 1 1000 1000   4687208 Feb 11 16:00 clang-offload-bundler
        -rwxrwxrwx 1 1000 1000  32786688 Feb 11 16:02 clang-query
        -rwxrwxrwx 1 1000 1000  30623376 Feb 11 16:00 find-all-symbols
        -rwxrwxrwx 1 1000 1000    300632 Feb 11 16:01 hexagon-addr2line
        -rwxrwxrwx 1 1000 1000    652176 Feb 11 16:00 hexagon-analyzer-backend
        lrwxrwxrwx 1 1000 1000         7 Feb 11 16:00 hexagon-ar -> llvm-ar
        lrwxrwxrwx 1 1000 1000        12 Feb 11 16:00 hexagon-c++filt -> llvm-cxxfilt
        lrwxrwxrwx 1 1000 1000         8 Feb 11 16:00 hexagon-clang -> clang-10
        -rwxrwxrwx 1 1000 1000 101061712 Feb 11 15:59 hexagon-clang++
        -rwxrwxrwx 1 1000 1000   2700800 Feb 11 16:00 hexagon-clang-apply-replacements
        -rwxrwxrwx 1 1000 1000 101061712 Feb 11 16:01 hexagon-clang-cl
        -rwxrwxrwx 1 1000 1000 101061712 Feb 11 16:01 hexagon-clang-cpp
        -rwxrwxrwx 1 1000 1000  30459272 Feb 11 16:00 hexagon-clang-doc
        -rwxrwxrwx 1 1000 1000   2650104 Feb 11 16:00 hexagon-clang-format
        -rwxrwxrwx 1 1000 1000  39048544 Feb 11 16:00 hexagon-clang-import-test
        -rwxrwxrwx 1 1000 1000  30458768 Feb 11 16:01 hexagon-clang-include-fixer
        -rwxrwxrwx 1 1000 1000  31477312 Feb 11 16:01 hexagon-clang-refactor
        -rwxrwxrwx 1 1000 1000  30226616 Feb 11 16:00 hexagon-clang-rename
        -rwxrwxrwx 1 1000 1000  30479008 Feb 11 16:01 hexagon-clang-reorder-fields
        -rwxrwxrwx 1 1000 1000  29713472 Feb 11 16:00 hexagon-clang-scan-deps
        -rwxrwxrwx 1 1000 1000  49359608 Feb 11 16:00 hexagon-clang-tidy
        -rwxrwxrwx 1 1000 1000  42697872 Feb 11 16:00 hexagon-clangd
        -rwxrwxrwx 1 1000 1000    798360 Feb 11 16:00 hexagon-coverage
        lrwxrwxrwx 1 1000 1000        20 Feb 11 16:00 hexagon-elfcopy -> hexagon-llvm-objcopy
        -rwxrwxrwx 1 1000 1000    375680 Feb 11 16:01 hexagon-elfcopy-deprecated
        -rwxrwxrwx 1 1000 1000     16832 Feb 11 16:00 hexagon-gmon-dump
        -rwxrwxrwx 1 1000 1000     21480 Feb 11 16:00 hexagon-gmon-merge
        -rwxrwxrwx 1 1000 1000    235496 Feb 11 15:59 hexagon-gprof
        lrwxrwxrwx 1 1000 1000         7 Feb 11 16:00 hexagon-link -> ld.qcld
        -rwxrwxrwx 1 1000 1000  47836752 Feb 11 16:00 hexagon-llc
        -rwxrwxrwx 1 1000 1000    369752 Feb 11 16:01 hexagon-lldb
        -rwxrwxrwx 1 1000 1000   2546696 Feb 11 16:00 hexagon-lldb-mi
        -rwxrwxrwx 1 1000 1000   6610408 Feb 11 16:00 hexagon-llvm-addr2src
        -rwxrwxrwx 1 1000 1000   6530168 Feb 11 16:01 hexagon-llvm-addr2struct
        -rwxrwxrwx 1 1000 1000    259000 Feb 11 16:00 hexagon-llvm-config
        -rwxrwxrwx 1 1000 1000   3519928 Feb 11 16:00 hexagon-llvm-dis
        -rwxrwxrwx 1 1000 1000   6528480 Feb 11 16:00 hexagon-llvm-dwarfdump
        -rwxrwxrwx 1 1000 1000   3206256 Feb 11 16:00 hexagon-llvm-mc
        -rwxrwxrwx 1 1000 1000   5502416 Feb 11 16:00 hexagon-llvm-objcopy
        -rwxrwxrwx 1 1000 1000   7676128 Feb 11 16:00 hexagon-llvm-objdump
        -rwxrwxrwx 1 1000 1000   2807152 Feb 11 15:59 hexagon-llvm-profdata
        lrwxrwxrwx 1 1000 1000        12 Feb 11 16:00 hexagon-llvm-readelf -> llvm-readobj
        -rwxrwxrwx 1 1000 1000    332136 Feb 11 16:00 hexagon-llvm-strings
        -rwxrwxrwx 1 1000 1000  29882872 Feb 11 16:00 hexagon-modularize
        lrwxrwxrwx 1 1000 1000         7 Feb 11 16:00 hexagon-nm -> llvm-nm
        -rwxrwxrwx 1 1000 1000     24264 Feb 11 16:00 hexagon-profiler
        lrwxrwxrwx 1 1000 1000         7 Feb 11 16:00 hexagon-ranlib -> llvm-ar
        -rwxrwxrwx 1 1000 1000   7587760 Feb 11 16:01 hexagon-readelf
        -rwxrwxrwx 1 1000 1000    263528 Feb 11 16:00 hexagon-sim
        lrwxrwxrwx 1 1000 1000         9 Feb 11 16:00 hexagon-size -> llvm-size
        lrwxrwxrwx 1 1000 1000        20 Feb 11 15:59 hexagon-strings -> hexagon-llvm-strings
        -rwxrwxrwx 1 1000 1000    171080 Feb 11 16:01 hexagon-strings-deprecated
        lrwxrwxrwx 1 1000 1000        20 Feb 11 16:00 hexagon-strip -> hexagon-llvm-objcopy
        -rwxrwxrwx 1 1000 1000    375680 Feb 11 16:00 hexagon-strip-deprecated
        -rwxrwxrwx 1 1000 1000      9974 Feb 11 16:00 hmaptool
        -rw-rw-rw- 1 1000 1000  46687200 Feb 11 16:00 ld.qcld
        -rwxrwxrwx 1 1000 1000   6238888 Feb 11 16:00 llvm-ar
        -rwxrwxrwx 1 1000 1000    485096 Feb 11 16:00 llvm-cxxfilt
        lrwxrwxrwx 1 1000 1000         7 Feb 11 16:00 llvm-lib -> llvm-ar
        -rwxrwxrwx 1 1000 1000   6578800 Feb 11 16:00 llvm-nm
        lrwxrwxrwx 1 1000 1000         7 Feb 11 16:00 llvm-ranlib -> llvm-ar
        -rwxrwxrwx 1 1000 1000   7587760 Feb 11 16:00 llvm-readobj
        -rwxrwxrwx 1 1000 1000   4737296 Feb 11 16:01 llvm-size
        -rwxrwxrwx 1 1000 1000   5557112 Feb 11 16:00 llvm-symbolizer
        -rwxrwxrwx 1 1000 1000  29882872 Feb 11 16:01 modularize
        -rwxrwxrwx 1 1000 1000     39600 Feb 11 16:02 post-process
        -rwxrwxrwx 1 1000 1000     56761 Feb 11 16:01 scan-build
        -rwxrwxrwx 1 1000 1000      4702 Feb 11 16:00 scan-view
        • R ravi
          @Eric-Katzfey
          total 1163652
          R Offline
          R Offline
          ravi
          Hi @Eric-Katzfey
          yes, i can see
          and also
          So it seems " ld.qcld'" is not executable.
          then I made it executable using.
          "chmod +x /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/ld.qcld"
          Then, it seems the voxl-PX4 build is working.
          Thank you for the help.
          root@798402fd070f:/usr/local/workspace# ./build.sh
          -- Configuring done
          -- Generating done
          -- PLATFORM posix
          -- LINUX_TARGET y
          Architecture:  amd64
          -- Configuring done
          -- Generating done
          [6/562] git submodule src/modules/mavlink/mavlink
          [64/562] Performing configure step for 'libmicroxrceddsclient_project'
          [555/562] Performing build step for 'libmicroxrceddsclient_project'
          [556/562] Performing install step for 'libmicroxrceddsclient_project'
          /* Do not edit! */
          #pragma once
          -- PLATFORM qurt
          -- TOOLCHAIN qurt
          -- Check for working CXX compiler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang++ -- works
          -- Detecting CXX compiler ABI info - failed
          -- Check for working C compiler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang
          -- Check for working C compiler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang -- works
          -- Detecting C compiler ABI info - failed
          -- Warning: Did not find file Compiler/-ASM
          -- Mavlink include directory: /usr/local/workspace/px4-firmware/../build/modalai_voxl2_default/mavlink/standard
          -- Mavlink include directory: /usr/local/workspace/px4-firmware/../build/modalai_voxl2_default/mavlink/common
          Architecture:  amd64
          -- Configuring done
          -- Generating done
          -- Build files have been written to: /usr/local/workspace/px4-firmware/build/modalai_voxl2-slpi_default
          [0/724] git submodule src/drivers/gps/devices
          [724/724] Linking CXX shared library platforms/qurt/libpx4.so
          /* Do not edit! */
          #pragma once
          User ID is 1000
          Group ID is 1000
