    Stereo Cameras are highly inaccurate
    1259
    • Daniel RyuD
      Daniel Ryu
      I calibrated my stereo cameras twice according to these instructions. https://docs.modalai.com/calibrate-cameras/#calibrate-stereo-cameras. However, the output I receive from running
      voxl-vision-px4 -s
      is very inaccurate. How can I improve the stereo camera's object detection accuracy? I used a 4x11 acircles board with 59.5 mm distance separating each circle.
      Testing environment
      First calibration results
      Second calibration results
      voxl-vision-px4.conf
      • Daniel RyuD
        Daniel Ryu
        Clarifying notes:
        Same problem seen on another m500 drone.
        Calibration card used has a spacing of 98.8 mm between the center of each circles (acircles card). 4x11
        • Daniel RyuD
          Daniel Ryu
          • Chad SweetC
            Chad Sweet ModalAI Team
            you need to get the calibration target professionally printed. All of those inaccuracies in what you have put together are going to create issues with calibration. Any office printing place can print a card like that from PDF on stiff backing. I don't think what you have is going to work that well
            Daniel RyuD 2 Replies Last reply Reply Quote 0
            • Daniel RyuD
              Daniel Ryu @Chad Sweet
              @Chad-Sweet I'll try again with a card professionally printed card and get back to you
              • Daniel RyuD
                @Chad-Sweet Here are the results with the pictured calibration board we used (spacing 117.5 mm center to center). As you can see, we still have a detection at 0 degrees at 0.2 meters, when there should be nothing at all.
                • Daniel RyuD
                  Daniel Ryu
                  Note: Every other angle appears to be somewhat accurate, everything except the measurements at 0 degrees
                  • J
                    jaredjohansen
                    An update on our efforts in this regard.
                    We have now attempted to calibrate 4 different VOXLs. In one case, we calibrated the VOXL board twice (with similar results).
                    We have tried with three different circles grids (two of which were professionally printed).
                    In all cases, at the zero degree angle, there is an obstacle constantly detected at 0.2 meters. We do not know why this is. We presume this is a problem. Is it? If not, why?
                    In three of the four cases, the detections at all other angles are inaccurate. In these three cases, in general, they "sense" when an obstacle is within their bin range, but this is not always the cause: sometimes miss detecting obstacles. In the three cases where the detection are inaccurate, they can be off by several meters. We expect that autonomous navigation that relies on the output of these bins would cause problems. Do you have any additional guidance on how to get this working more accurately?
                    • Chad SweetC
                      This looks like it could be a bug, we're looking into it. In the meantime you can just comment out using the center bin
                      • Chad SweetC
                        A potential fix for this has been pushed to the dev branch
                        change
                        Daniel RyuD 1 Reply Last reply Reply Quote 0
                        • Daniel RyuD
                          @Chad-Sweet The fix in the dev branch successfully populates the 0th degree bin for obstacle detection. We are now able to run VOA mostly successfully, with one observable bug with the voxl-camera-server/voxl-dfs-server. Please see this post for details: https://forum.modalai.com/topic/450/intermittent-crashing-of-voxl-camera-server-during-voa-testing?_=1631837674205
