    VOXL2 vlan
    944
    • J
      jcai
      Hello, has 8021q vlan been tested on the VOXL2 before? I'm building the module for 1.8.02 for SDK 1.4 by enabling CONFIG_VLAN_8021Q, but it's causing some issues.
      Below is the output from lsmod before and after enabling the module:
      voxl2:/$ lsmod
      Module                  Size  Used by
      voxl_platform_mod      16384  0
      voxl_gpio_mod          16384  0
      voxl_fsync_mod         16384  0
      machine_dlkm          159744  0
      wcd938x_slave_dlkm     16384  0
      wcd938x_dlkm          110592  1 machine_dlkm
      wcd9xxx_dlkm           49152  1 wcd938x_dlkm
      mbhc_dlkm              45056  1 wcd938x_dlkm
      tx_macro_dlkm         106496  0
      rx_macro_dlkm         102400  0
      va_macro_dlkm          98304  0
      wsa_macro_dlkm         69632  1 machine_dlkm
      swr_ctrl_dlkm          57344  4 wsa_macro_dlkm,tx_macro_dlkm,rx_macro_dlkm,va_macro_dlkm
      bolero_cdc_dlkm        57344  5 machine_dlkm,wsa_macro_dlkm,tx_macro_dlkm,rx_macro_dlkm,va_macro_dlkm
      wsa881x_dlkm           45056  1 machine_dlkm
      wcd_core_dlkm          32768  7 wsa881x_dlkm,machine_dlkm,wsa_macro_dlkm,tx_macro_dlkm,rx_macro_dlkm,va_macro_dlkm,wcd938x_dlkm
      stub_dlkm              16384  0
      hdmi_dlkm              24576  0
      swr_dlkm               24576  4 wsa881x_dlkm,wcd938x_dlkm,swr_ctrl_dlkm,wcd938x_slave_dlkm
      pinctrl_lpi_dlkm       20480  0
      pinctrl_wcd_dlkm       16384  0
      usf_dlkm               57344  0
      native_dlkm           163840  0
      platform_dlkm        2195456  1 native_dlkm
      q6_dlkm               909312  9 bolero_cdc_dlkm,machine_dlkm,pinctrl_lpi_dlkm,usf_dlkm,va_macro_dlkm,swr_ctrl_dlkm,wcd9xxx_dlkm,native_dlkm,platform_dlkm
      adsp_loader_dlkm       16384  0
      apr_dlkm              229376  4 q6_dlkm,usf_dlkm,adsp_loader_dlkm,platform_dlkm
      snd_event_dlkm         16384  5 bolero_cdc_dlkm,machine_dlkm,q6_dlkm,pinctrl_lpi_dlkm,apr_dlkm
      q6_notifier_dlkm       16384  3 q6_dlkm,pinctrl_lpi_dlkm,apr_dlkm
      q6_pdr_dlkm            16384  1 q6_notifier_dlkm
      88XXau               2342912  0
      8821cu               2465792  0
      8188eu               1200128  0
      voxl2:/$ lsmod
      Module                  Size  Used by
      stub_dlkm              16384  0
      q6_notifier_dlkm       16384  0
      The cause of this can be found using dmesg, where an example line is shown below. A multitude of other modules are showing similar errors with other symbols like _dev_err
      [    4.764189] voxl_gpio_mod: disagrees about version of symbol device_create
      [    4.764192] voxl_gpio_mod: Unknown symbol device_create (err -22)
      However, running dmesg | grep VLAN gives:
      voxl2:/$ dmesg | grep VLAN
      [    1.954223] 8021q: 802.1Q VLAN Support v1.8
      [    5.013433] 8021q: adding VLAN 0 to HW filter on device bond0
      • tomT
        tom admin @jcai
        @jcai Are you seeing any negative effects from this other than the errors in dmesg? It may not be an issue if not
        • J
          jcai @tom
          @tom There's a couple, which I'm guessing have to do with all those modules not getting loaded anymore:
          • eth0 no longer shows up in ifconfig
          • voxl-configure-cameras returns cat: /sys/module/voxl_platform_mod/parameters/config: No such file or directory
          There may be more, but I haven't dug too deep into finding all the effects
            Alex Kushleyev ModalAI Team @jcai
            @jcai , you are probably modifying / building the kernel for an older SDK (while using newer SDK) or you have the kernel built for SDK 1.4.0 but actual installed SDK is older.
            You can see which versions / tags of kernel and meta-voxl2 / meta-voxl2-bsp repos are used in each SDK here: https://docs.modalai.com/voxl2-voxl2-mini-system-image/
            and follow instructions how to get the right tags as mentioned here : https://docs.modalai.com/voxl2-kernel-build-guide/#get-the-correct-tags
            Please double check that the installed SDK matches the version of the kernel that you are customizing.
            • J
              jcai @Alex Kushleyev
              @Alex-Kushleyev To be sure, I cleaned the workspace and rebuilt the docker image as well. I re-synced, ensuring that the tag for the repos is v1.8.02. My voxl is also on SDK 1.4
              Is this behaviour reproducible?
                @jcai , hmm.. I will need to check with our Kernel guru :).
                Will get back to you soon..
                • modaltbM
                  modaltb ModalAI Team
                  Hey @jcai ,
                  Are you building a "debug" or "perf" kernel?
                  There's a little slop I have with voxl-gpio-mod and voxl-platform-mod.... they're being built out of tree and shipping in the rootfs... which if you load a debug kernel, causes problems like above....
                  By default the build is 'perf':
                  https://gitlab.com/voxl-public/system-image-build/qrb5165-kernel-build-docker/-/blob/qrb5165-ubun1.0-14.1a/bin/qrb5165-build.sh?ref_type=heads#L13
                  If you are using 'perf' and still having issues please let me know.
                  I want to move these two modules IN TREE, then this can go away... we're planning on doing this in future (major) release.
                  • J
                    jcai @modaltb
                    @modaltb As far as I can tell, I'm building a perf kernel. These are my changes:
                    MODAL_REPO_BRANCH=v1.8.02 in bin/qrb5165-common.sh
                    I've added the following lines to ./lu.um.1.2.1/apps_proc/poky/meta-voxl2-bsp/recipes-kernel/linux-msm/files/fragments/m005x.cfg:
                    CONFIG_MACVLAN=y
                    CONFIG_VLAN_8021Q=y
                    And then building:
                    ./qrb5165-build.sh -m M0054
