  3. GPS and VL53L1 not working
px4-dev-kit
3 Posts 3 Posters 1.5k Views 2 Watching
  • J Offline
    jefersonsilva
    I recently purchased the PX4 Autonomy Developer Kit and have noticed that neither the GPS nor the distance sensor is functioning properly. I’ve conducted some outdoor flights on a sunny day with no external interference, but the GPS did not connect to any satellites. I haven’t made any modifications to the kit that could cause a malfunction. Below is the output from my terminal.
    Could anyone assist me with this issue?
    ########################################VL53L1##########################################################
    voxl2:/etc/modalai$ voxl-configure-rangefinders 1_downward_on_m0141
    creating new config file for 1 downward TOF without multiplexer
    DONE
    enabling voxl-rangefinder-server systemd service
    Done configuring voxl-rangefinder-server
    voxl2:/etc/modalai$ voxl-configure-rangefinders 1_on_m0141
    creating new config file for 1 TOF without multiplexer
    DONE
    voxl2:/etc/modalai$ voxl-rangefinder-server
    i2c_bus: 1
    has_nonmux_sensor: 1
    n_mux_sensors: 0
    n_enabled_sensors: 1
    vl53l1x_timing_budget_ms: 50
    id_for_mavlink: -1
    #0:
    enabled: 1
    sensor_id: 0
    type: TOF_VL53L1X
    fov_deg: 27.000
    range_max_m: 3.000
    location_wrt_body: -0.025 0.020 0.008
    direction_wrt_body: 0.000 0.000 1.000
    is_on_mux: 0
    i2c_mux_address: 0x70
    i2c_mux_port: 0
    initializing i2c bus 1
    initializing non-multiplexed tof sensor id 0
    ERROR: in voxl_i2c_reg16_read_bytes, failed to write to bus
    ERROR in vl53l1x_check_whoami, failed to read whoami register
    ERROR in vl53l1x_init, failed to verify whoami
    Error initializing sensor 0
    exiting
    #########################################GPS######################################################
    voxl2:/$ px4-listener vehicle_gps_position
    TOPIC: vehicle_gps_position
    timestamp: 80789290 (892.490662 seconds ago)
    timestamp_sample: 0
    time_utc_usec: 0
    device_id: 11272245 (Type: 0xAC, SERIAL:6 (0x00))
    lat: 0
    lon: 0
    alt: -17000
    alt_ellipsoid: 0
    s_variance_m_s: 999.00006
    c_variance_rad: 3.14159
    eph: 4294967.50000
    epv: 3750866.50000
    hdop: 99.99000
    vdop: 99.99000
    noise_per_ms: 87
    jamming_indicator: 19
    vel_m_s: 0.00000
    vel_n_m_s: 0.00000
    vel_e_m_s: 0.00000
    vel_d_m_s: 0.00000
    cog_rad: 0.00000
    timestamp_time_relative: 0
    heading: nan
    heading_offset: 0.00000
    heading_accuracy: 0.00000
    rtcm_injection_rate: 0.00000
    automatic_gain_control: 0
    fix_type: 0
    jamming_state: 0
    spoofing_state: 1
    vel_ned_valid: False
    satellites_used: 0
    tomT Eric KatzfeyE 2 Replies Last reply
    • J jefersonsilva
      DONE
      DONE
      i2c_bus: 1
      n_mux_sensors: 0
      id_for_mavlink: -1
      #0:
      enabled: 1
      sensor_id: 0
      type: TOF_VL53L1X
      fov_deg: 27.000
      range_max_m: 3.000
      is_on_mux: 0
      i2c_mux_port: 0
      exiting
      timestamp_sample: 0
      time_utc_usec: 0
      lat: 0
      lon: 0
      alt: -17000
      alt_ellipsoid: 0
      eph: 4294967.50000
      epv: 3750866.50000
      hdop: 99.99000
      vdop: 99.99000
      noise_per_ms: 87
      vel_m_s: 0.00000
      vel_n_m_s: 0.00000
      vel_e_m_s: 0.00000
      vel_d_m_s: 0.00000
      cog_rad: 0.00000
      heading: nan
      fix_type: 0
      jamming_state: 0
      spoofing_state: 1
      satellites_used: 0
      tomT Online
      tomT Online
      @jefersonsilva What does /etc/modalai/voxl-px4.conf look like?
      • J jefersonsilva
        DONE
        DONE
        i2c_bus: 1
        n_mux_sensors: 0
        id_for_mavlink: -1
        #0:
        enabled: 1
        sensor_id: 0
        type: TOF_VL53L1X
        fov_deg: 27.000
        range_max_m: 3.000
        is_on_mux: 0
        i2c_mux_port: 0
        exiting
        timestamp_sample: 0
        time_utc_usec: 0
        lat: 0
        lon: 0
        alt: -17000
        alt_ellipsoid: 0
        eph: 4294967.50000
        epv: 3750866.50000
        hdop: 99.99000
        vdop: 99.99000
        noise_per_ms: 87
        vel_m_s: 0.00000
        vel_n_m_s: 0.00000
        vel_e_m_s: 0.00000
        vel_d_m_s: 0.00000
        cog_rad: 0.00000
        heading: nan
        fix_type: 0
        jamming_state: 0
        spoofing_state: 1
        satellites_used: 0
        Eric KatzfeyE Online
        @jefersonsilva If you let it sit for a long time does it eventually find satellites and get a fix?
