  2. VOXL Accessories
  3. Cellular Modems
  4. LTE - Modem Works But Cannot Ping
Scheduled Pinned Locked Moved Cellular Modems
27 Posts 4 Posters 7.2k Views 4 Watching
  • derrick0799D Offline
    derrick0799
    Looks like everything initialized correctly but I am unable to gain access to the internet. I cannot ping a site. Am I missing something?
    yocto:~$ systemctl status -l voxl-modem
    ● voxl-modem.service - Modem Initialization
    Loaded: loaded (/etc/systemd/system/voxl-modem.service; enabled; vendor preset: enabled)
    Active: inactive (dead) since Thu 1970-01-01 00:03:37 UTC; 43s ago
    Process: 3914 ExecStart=/usr/bin/voxl-modem-start.sh (code=exited, status=0/SUCCESS)
    Process: 3913 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
    Main PID: 3914 (code=exited, status=0/SUCCESS)
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: ]
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: Successfully registered with the network
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: Starting network
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: Checking connection status
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: Connection is up
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: Using the DHCP client to get an IP address
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: udhcpc (v1.23.2) started
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: Sending discover...
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: Sending select for 100.82.158.240...
    Jan 01 00:03:37 apq8096 voxl-modem-start.sh[3914]: Lease of 100.82.158.240 obtained, lease time 7200
    • vmassagueV Offline
      vmassagueV Offline
      vmassague
      I am getting the exact same issue, with the same log output.
      adb shell systemctl status -l voxl-modem
         Active: inactive (dead) since Thu 1970-01-01 00:00:57 UTC; 2s ago
        Process: 3178 ExecStart=/usr/bin/voxl-modem-start.sh (code=exited, status=0/SUCCESS)
        Process: 2312 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
       Main PID: 3178 (code=exited, status=0/SUCCESS)
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: ]
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: Successfully registered with the network
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: Starting network
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: Checking connection status
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: Connection is up
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: Using the DHCP client to get an IP address
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: udhcpc (v1.23.2) started
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: Sending discover...
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: Sending select for 10.107.157.92...
      Jan 01 00:00:57 apq8096 voxl-modem-start.sh[3178]: Lease of 10.107.157.92 obtained, lease time 7200
      I validated that the SIM works and has data with a cellphone.
      I am using an m500 with LTE v2 modem for Europe.
        derrick0799
        Ok. I wasn’t sure if I was missing a step in setting this up. I too have verified that the SIM card works and receives data in a different device. I have the V2-Modem, WP7610 Sierra Wireless. I am also connecting to the Verizon “vzwinternet” APN if this detail would further help understand my issue.
          This type of issue is typically related to APN mismatch with the carrier's specific APN. For "vzwinternet" the carrier is Verizon
          Double checking folks see this doc as well https://docs.modalai.com/lte-v2-modem-manual/
            vmassagueV Offline
            vmassague
            In my case, I double-checked with the cellphone to have the same APN since I am using a custom one, but still no success. I tried with two different modules and VOXL boards.
            FYI, I am connecting the LTE antennas one in Antenna (main) and the other to Antenna (diversity)
            • derrick0799D derrick0799
              @derrick0799 Are you using the LTE V2 Add-on or Stand Alone?
              derrick0799D 1 Reply Last reply
              • tomT Offline
                wrote on last edited by tom
                @vmassague Are you using the LTE V2 Add-on or Stand Alone? And you're using the Sierra 7607 modem correct?
                vmassagueV 1 Reply Last reply
                  derrick0799
                  @tom, I am using the add-on
                    vmassagueV Offline
                    vmassagueV Offline
                    vmassague
                    @tom I'm using the Add-on also and I'm using the Sierra 7607
                      @derrick0799 Can you disable the voxl-modem service from running with systemctl disable voxl-modem and reboot your voxl.
                      Then run voxl-modem-start.sh manually so I can see the full output?
                      derrick0799D 2 Replies Last reply
                      • vmassagueV vmassague
                        @vmassague Can you disable the voxl-modem service from running with systemctl disable voxl-modem and reboot your voxl.
                          derrick0799
                          @tom, sure. It will be later this evening before I am able to do so.
                            @derrick0799 @vmassague Another thing for both of you to check is to see if the APN is indeed set correctly, you can do this with the following command:
                            / # echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                            AT+CGDCONT?
                            +CGDCONT: 1,"IP","h2g2","0.0.0.0",0,0,0,0
                            +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
                            +CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1
                            In this case, my APN is h2g2 for GoogleFi
                              derrick0799
                              @tom I ran 'systemctl disable voxl-modem' and reboot voxl then...
                              yocto:~$ voxl-modem-start.sh
                              VOXL detected...
                              Initializing v2 modem...
                              Waiting for ttyUSB2...
                              ttyUSB2
                              Initalizing cellular connection...
                              Configuring GPIO to pull modem out of reset
                              Waiting for the diag serial port(/dev/ttyUSB0) to activate
                              checking for serial port: /dev/ttyUSB0
                              /dev/ttyUSB0 is available
                              Verifying existence of QMI port(/dev/cdc-wdm0)
                              checking for serial port: /dev/cdc-wdm0
                              /dev/cdc-wdm0 is available
                              Unstick QMI countdown: 10
                              Unstick QMI countdown: 9
                              Unstick QMI countdown: 8
                              Unstick QMI countdown: 7
                              Unstick QMI countdown: 6
                              "12253379280"
                              Checking for system registration
                              Attempt: 1
                              "registration": "registered",
                              "plmn_mcc": 311,
                              "plmn_mnc": 480,
                              "plmn_description": "Verizon ",
                              "roaming": false
                              response: [{
                              "plmn_mcc": 311,
                              "plmn_mnc": 480,
                              "roaming": false
                              Starting network
                              "No effect"
                              Connection is up
                              Sending discover...
                              Sending select for 100.68.239.240...
                              Lease of 100.68.239.240 obtained, lease time 7200
                                AT+CGDCONT?
                                derrick0799
                                @tom said in LTE - Modem Works But Cannot Ping:
                                yocto:~$ echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                                AT+CGDCONT?
                                +CGDCONT: 1,"IP","vzwinternet","0.0.0.0",0,0,0,0
                                OK
                                • tomT Offline
                                  @derrick0799 Do you have WiFi connected? If so, try disabling it with ifconfig wlan0 down and seeing if you can then ping.
                                  Also, can I see the output of route -n?
                                  Same for you @vmassague something to try.
                                    AT+CGDCONT?
                                    OK
                                    @derrick0799 Looks like APN is setting correctly so that's good
                                      derrick0799
                                      @tom after disabling wlan0,
                                      / # ping 8.8.8.8
                                      connect: Network is unreachable
                                      / # route -n
                                      Kernel IP routing table
                                      Destination Gateway Genmask Flags Metric Ref Use Iface
                                      172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
                                      • tomT Offline
                                        @derrick0799 What does ifconfig show?
                                          derrick0799
                                          @tom
                                          / # ifconfig
                                          docker0 Link encap:Ethernet HWaddr 02:42:77:DF:4E:80
                                          inet addr:172.17.0.1 Bcast:0.0.0.0 Mask:255.255.0.0
                                          inet6 addr: fe80::42:77ff:fedf:4e80/64 Scope:Link
                                          UP BROADCAST MULTICAST MTU:1500 Metric:1
                                          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
                                          TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
                                          collisions:0 txqueuelen:0
                                          RX bytes:0 (0.0 B) TX bytes:140 (140.0 B)
                                          lo Link encap:Local Loopback
                                          inet addr:127.0.0.1 Mask:255.0.0.0
                                          inet6 addr: ::1/128 Scope:Host
                                          UP LOOPBACK RUNNING MTU:65536 Metric:1
                                          RX packets:609376 errors:0 dropped:0 overruns:0 frame:0
                                          TX packets:609376 errors:0 dropped:0 overruns:0 carrier:0
                                          RX bytes:65142775 (62.1 MiB) TX bytes:65142775 (62.1 MiB)
