  3. LTE - Modem Works But Cannot Ping
cellular
27 Posts 4 Posters 7.9k Views 4 Watching
  • tomT Offline
    @derrick0799 Is that the output after running voxl-modem-start.sh?
    • tomT Offline
      At that point, you should be seeing something similar to:
      wwan0     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
                inet addr:30.60.23.115  P-t-P:30.60.23.115  Mask:255.255.255.248
                UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
                RX packets:33 errors:0 dropped:0 overruns:0 frame:0
                TX packets:55 errors:0 dropped:0 overruns:0 carrier:0
                collisions:0 txqueuelen:1000
                RX bytes:3214 (3.1 KiB)  TX bytes:4672 (4.5 KiB)
      derrick0799D 2 Replies Last reply
        derrick0799D Offline
        derrick0799
        @tom I think my problem was that the wifi was connected when I ran the voxl-modem-start.sh
        Now that I am connect with adb everything started working when I re-ran voxl-modem-start.sh. It is pinging as it should.
          derrick0799
          @tom
          / # ifconfig
          docker0 Link encap:Ethernet HWaddr 02:42:77:DF:4E:80
          inet addr:172.17.0.1 Bcast:0.0.0.0 Mask:255.255.0.0
          inet6 addr: fe80::42:77ff:fedf:4e80/64 Scope:Link
          UP BROADCAST MULTICAST MTU:1500 Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B) TX bytes:140 (140.0 B)
          lo Link encap:Local Loopback
          inet addr:127.0.0.1 Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING MTU:65536 Metric:1
          RX packets:1472332 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1472332 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:155328799 (148.1 MiB) TX bytes:155328799 (148.1 MiB)
          inet addr:100.76.95.21 P-t-P:100.76.95.21 Mask:255.255.255.252
          RX packets:2 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2713 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:612 (612.0 B) TX bytes:1304344 (1.2 MiB)
          / # ping 8.8.8.8
          PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
          64 bytes from 8.8.8.8: icmp_req=1 ttl=113 time=34.3 ms
          64 bytes from 8.8.8.8: icmp_req=2 ttl=113 time=35.1 ms
          64 bytes from 8.8.8.8: icmp_req=3 ttl=113 time=34.0 ms
          64 bytes from 8.8.8.8: icmp_req=4 ttl=113 time=27.1 ms
          64 bytes from 8.8.8.8: icmp_req=5 ttl=113 time=31.1 ms
          64 bytes from 8.8.8.8: icmp_req=6 ttl=113 time=36.5 ms
          64 bytes from 8.8.8.8: icmp_req=7 ttl=113 time=24.0 ms
          Thanks @Tom
          • tomT Offline
            @derrick0799 Great to hear!
            • vmassagueV Offline
              vmassagueV Offline
              vmassague
              Problem solved for me too! I think it was also the wlan0 being up. Thanks a lot for the support @tom
              • vmassagueV vmassague
                @vmassague Awesome!
                • wilkinsafW wilkinsaf referenced this topic on
