  2. VOXL Dev Drones
  3. Starling & Starling 2
  4. Unable to bind controller anymore to Starling V2
11 Posts 3 Posters 1.4k Views 1 Watching
  • M Offline
    M Offline
    mario
    I'm not able anymore to bind the controller that comes with the Starling V2.
    I've done multiple power cycles of the drone and controller, and ran the voxl-elrs --unbind and voxl-elrs --bind commands and go through the binding process, which used to work to rebind the joystick, but I'm no longer able to.
    I then tried to reflash the receiver as per https://docs.modalai.com/voxl-elrs/#recovering-a-bricked-receiver, but still can't get the joystick to bind.
    Any further suggestions to try?
    • M mario
      @mario Have you tried using the button on the receiver itself in order to put it into binding mode?
      M 4 Replies Last reply
        M Offline
        M Offline
        mario
        @tom, can you elaborate which button on the ELRS receiver you are talking about? You mean the power on/off cycling button? Is there a way to press it such that it binds to the controller?
          M Offline
          M Offline
          mario
          @tom, in other words, aside from these docs https://docs.modalai.com/voxl-elrs/, where are these instructions that refer to using a button on the ELRS receiver to bind?
          Jainik MehtaJ 1 Reply Last reply
            M Offline
            M Offline
            mario
            @tom, one more question, we're trying to run /usr/share/modalai/voxl-elrs/tools/debug.py to try to see the logs, but the code doesn't seem to work.
            For example, it looks for dev.port = '/dev/tty-slpi-7', but we can't find that file, so is this debug.py actually the right code to use?
            Also, this error message is returned, even on a drone that is working correctly that binds to the controller.
            ERROR: voxl_uart_read_bytes: Bus '17' is not initialized
            PS, regarding the original post, unbinding and flashing did work, we can see the LED changes, etc, and messages from the drone
            • M mario
              Jainik MehtaJ Offline
              Jainik Mehta
              @mario Were you able to bind the controller to the drone? I think I have the same problem with my starling 2 drone. I assume you also have ORQA controller like me. Are you seeing constant green LED on drone when you turn it on?
              M 1 Reply Last reply
              • Jainik MehtaJ Jainik Mehta
                M Offline
                M Offline
                mario
                @Jainik-Mehta I have a Commando controller, and yes, all the LEDs on the drone operate as expected
                  M Offline
                  M Offline
                  mario
                  @tom, just checking to see if you had any further thoughts on this.
                  • M mario
                    @mario There should be only physical button on the receiver itself, pressing and holding it for a couple seconds within 30 seconds of powering on should put it into bind mode
                      M Offline
                      M Offline
                      mario
                      @tom, when that happens, does the LED do the "blink-blink-pause-blink-blink-pause..." sequence, i.e. the sequence listed here under "Binding mode enabled": https://www.expresslrs.org/quick-start/led-status/.
                      That's the same mode I get when I do voxl-elrs --bind, so is there a difference between doing it via the command vs doing it by holding down that button?
                      • M mario
                        @mario Should be the same, if you're seeing that LED pattern then binding mode has started correctly
