Unable to bind controller anymore to Starling V2
I'm not able anymore to bind the controller that comes with the Starling V2.
I've done multiple power cycles of the drone and controller, and ran the
voxl-elrs --unbindandvoxl-elrs --bindcommands and go through the binding process, which used to work to rebind the joystick, but I'm no longer able to.I then tried to reflash the receiver as per https://docs.modalai.com/voxl-elrs/#recovering-a-bricked-receiver, but still can't get the joystick to bind.
Any further suggestions to try?
@mario Have you tried using the button on the receiver itself in order to put it into binding mode?
@tom, one more question, we're trying to run /usr/share/modalai/voxl-elrs/tools/debug.py to try to see the logs, but the code doesn't seem to work.
For example, it looks for dev.port = '/dev/tty-slpi-7', but we can't find that file, so is this debug.py actually the right code to use?
Also, this error message is returned, even on a drone that is working correctly that binds to the controller.
ERROR: voxl_uart_read_bytes: Bus '17' is not initializedPS, regarding the original post, unbinding and flashing did work, we can see the LED changes, etc, and messages from the drone
@tom, in other words, aside from these docs https://docs.modalai.com/voxl-elrs/, where are these instructions that refer to using a button on the ELRS receiver to bind?
@mario Were you able to bind the controller to the drone? I think I have the same problem with my starling 2 drone. I assume you also have ORQA controller like me. Are you seeing constant green LED on drone when you turn it on?
@Jainik-Mehta I have a Commando controller, and yes, all the LEDs on the drone operate as expected
@mario There should be only physical button on the receiver itself, pressing and holding it for a couple seconds within 30 seconds of powering on should put it into bind mode
@tom, when that happens, does the LED do the "blink-blink-pause-blink-blink-pause..." sequence, i.e. the sequence listed here under "Binding mode enabled": https://www.expresslrs.org/quick-start/led-status/.
That's the same mode I get when I do
voxl-elrs --bind, so is there a difference between doing it via the command vs doing it by holding down that button? -
