  3. Flight Deck with Microhard Radio not connecting to QGC
microhard
13 Posts 3 Posters 2.9k Views 2 Watching
  • Daniel RyuD Offline
    Daniel RyuD Offline
    Daniel Ryu
    Following this guide here, I was able to connect one microhard radio from my PC to one wired to the flight deck. With VOXL shell, I was able to ping the PC's ip address. As per the guide, I updated the qgc_ip field in voxl-vision-px4.conf to my PC's ip address and reset the px4 service. However, QGC is still unable to find the drone. Any tips on what I am missing to have QGC find the drone?
    As a further note, when the Flight Deck is connected by wire to the PC (USB to QGC), my PC locates and connects to the drone.
    volx-vision-px4.conf
    Pinging computer IP:
    PC Microhard radio IP: 192.168.168.1
    VOXL Microhard radio IP: 192.168.168.2
    • tomT Offline
      wrote on last edited by tom
      Hi @Daniel-Ryu ,
      One thing I would recommend doing is setting up the voxl-vision-px4 service using voxl-configure-vision-px4. It's possible that voxl-vision-px4 is in a weird state and this can help reset it and flush out any issues.
      Another thing to check is to turn off all other networks on your PC side of things, i.e. WiFi and any other ethernet connections you may have connected. They can sometimes interfere with things depending on their settings.
      Let me know if this solution helps.
      Daniel RyuD 1 Reply Last reply
        Hi @Daniel-Ryu ,
        Daniel RyuD Offline
        Daniel RyuD Offline
        Daniel Ryu
        @tom ran voxl-configure-vision-px4 as per the instructions here and disabled all other networks. No change in situation. Since I can ping from the Flight Deck (using adb shell) to my laptop running QGC, I'm wondering whether the QGC connection service on the Flight Deck can even find the Microhard radio its connected to. Does this sound plausible? Let me know if there are any pictures/screenshots I can upload that would help diagnose this issue.
          This is pretty broadly used, so maybe some configuration has gotten wonky. Can you please share which version of software you are using? https://docs.modalai.com/voxl-utils/#voxl-version
            Daniel RyuD Offline
            Daniel Ryu
              Daniel RyuD Offline
              Daniel Ryu
              If it helps, when connected to the flight deck via wifi following the quickstart on m500, my laptop QGC can connect to the flight deck
              • tomT Offline
                Hi @Daniel-Ryu,
                Can you post the output from ifconfig on both your PC and VOXL when everything is powered on.
                • tomT Offline
                  And could I also see the status of voxl-vision-px4 using systemctl status -l voxl-vision-px4
                    Daniel RyuD Offline
                    Daniel Ryu
                    Screenshot from 2020-12-28 18-29-17.png Screenshot from 2020-12-28 18-29-45.png Screenshot from 2020-12-28 18-30-47.png
                      Daniel RyuD Offline
                      Daniel RyuD Offline
                      Daniel Ryu
                      @tom forgot to tag your name
                      • tomT Offline
                        Hi @Daniel-Ryu ,
                        From the screenshots you provided it looks as though your ground control station has the IP address of 192.168.168.108 while in voxl-vision-px4.conf you have it set to 192.168.168.109. It is possible that the IP address of your ground control station changed after a reboot and voxl-vision-px4 is still looking for the old IP.
                        To prevent this problem in the future you should be able to set a static IP for your wired connection on your Ubuntu ground station.
                          Daniel RyuD Offline
                          Daniel Ryu
                          @tom That was the problem! Thank you
                          • Daniel RyuD Daniel Ryu
                            @Daniel-Ryu Great to hear! I appreciate your patience with this.
