  3. Loss of wlan0 and potentially wwan0
13 Posts 2 Posters 2.3k Views 1 Watching
  • groupoG Offline
    groupoG Offline
    groupo
    wrote on last edited by groupo
    I have two Sentinel drones (SKU MRB-D0006-4-V1.2-C11-M24-T9-K3) and have this issue on both of them. Prior to inserting a SIM card and running voxl-configure-modem, I was able to access both of their softAPs. I was able able to put one of the drones on my own network, and switch back and forth between station and softAP mode (admittedly, I had not tried this on the other drone). My first drone's wifi stopped working after SIM insertion and configuring the modem, so I switched to the second drone and placed a SIM card in to try and connect to my network. This second drone's wifi stopped working too. I noticed that the wifi adapter does not even turn on anymore (no blue light). Voxl-wifi does not error out but I stepped thru the scripts enough to see wlan0 is undefined (assumingly because the adapter is not even on) and voxl-configure-modem gets stuck waiting for wwan0 to come up. I am not sure if the wwan0 bit has anything to do with the adapter.
    I saw some other posts on here with the wrong parts being shipped, but I do not believe that is my issue as it did work at one point. I followed the SIM insertion instructions I saw in a video from ModalAI, and was careful not to mess with any wiring. I am not sure if the wifi stopped upon insertion of the SIM, or after running vox;l-configure-modem, but I believe it is one of those two things that did it. I have since removed the SIM card, but the adapter still does not come online.
    I have thought about reflashing the device, perhaps I 'bricked' my wifi as some of the other posts I have seen stated. I came to the forums first before reflashing, as suggested.
    Below is voxl-version:
    voxl2:/$ voxl-version
    system-image: 1.7.6-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Wed Mar 20 19:48:52 UTC 2024 4.19.125
    hw platform: M0054
    mach.var: 1.0
    voxl-suite: 1.2.0
    Packages:
    Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.2/binary-arm64/
    Last Updated: 2023-03-02 12:58:54
    List:
    kernel-module-voxl-fsync-mod-4.19.125 1.0-r0
    kernel-module-voxl-gpio-mod-4.19.125 1.0-r0
    kernel-module-voxl-platform-mod-4.19.125 1.0-r0
    libfc-sensor 1.0.5
    libmodal-cv 0.4.0
    libmodal-exposure 0.1.0
    libmodal-journal 0.2.2
    libmodal-json 0.4.3
    libmodal-pipe 2.10.0
    libqrb5165-io 0.4.5
    libvoxl-cci-direct 0.2.1
    libvoxl-cutils 0.1.1
    modalai-slpi 1.1.12
    mv-voxl 0.1-r0
    qrb5165-bind 0.1-r0
    qrb5165-dfs-server 0.2.0
    qrb5165-imu-server 1.0.1
    qrb5165-rangefinder-server 0.1.1
    qrb5165-slpi-test-sig 01-r0
    qrb5165-system-tweaks 0.2.6
    qrb5165-tflite 2.8.0-2
    voxl-bind-spektrum 0.1.1
    voxl-camera-calibration 0.5.4
    voxl-camera-server 1.9.1
    voxl-ceres-solver 2:1.14.0-10
    voxl-configurator 0.5.6
    voxl-cpu-monitor 0.4.8
    voxl-docker-support 1.3.1
    voxl-elrs 0.1.3
    voxl-esc 1.4.0
    voxl-feature-tracker 0.3.2
    voxl-flow-server 0.3.3
    voxl-fsync-mod 1.0-r0
    voxl-gphoto2-server 0.0.10
    voxl-gpio-mod 1.0-r0
    voxl-jpeg-turbo 2.1.3-5
    voxl-lepton-server 1.2.0
    voxl-libgphoto2 0.0.4
    voxl-libuvc 1.0.7
    voxl-logger 0.4.0
    voxl-mavcam-manager 0.5.3
    voxl-mavlink 0.1.1
    voxl-mavlink-server 1.4.0
    voxl-modem 1.0.9
    voxl-mongoose 7.7.0-1
    voxl-mpa-to-ros 0.3.7
    voxl-mpa-tools 1.1.5
    voxl-neopixel-manager 0.0.3
    voxl-open-vins 0.4.4
    voxl-open-vins-server 0.2.18
    voxl-opencv 4.5.5-2
    voxl-platform-mod 1.0-r0
    voxl-portal 0.6.5
    voxl-px4 1.14.0-2.0.68
    voxl-px4-imu-server 0.1.2
    voxl-px4-params 0.3.8
    voxl-qvio-server 1.0.2
    voxl-remote-id 0.0.9
    voxl-streamer 0.7.4
    voxl-suite 1.2.0
    voxl-tag-detector 0.0.4
    voxl-tflite-server 0.3.2
    voxl-utils 1.3.9
    voxl-uvc-server 0.1.6
    voxl-vision-hub 1.7.4
    voxl2-system-image 1.7.6-r0
    voxl2-wlan 1.0-r0
    • groupoG Offline
      groupoG Offline
      groupo
      An update after some additional testing:
      I turned on one of the drones without the SIM this AM to find the WIFI adapter was coming online and working, just like the pre-SIM behavior. I tried taking the SIM out of the other drone, but that WIFI adapter still will not turn on. I poweroff -f the drone with working WIFI, put the sim in, and reboot. the WIFI adapter no longer turns on, and wlan0/wwan0 are both non-existent with the same behavior I discussed last week.
      further testing, I ran configure-modem on the SIMless drone, which had no impact on the wifi. It seems that putting the SIM card in is what is causing this behavior
      • groupoG groupo
        @groupo Can't say I've seen anything like that before. Can you confirm that the M0090 add-on board is fully seated onto the VOXL 2 with both connectors fully inserted
        groupoG 1 Reply Last reply
          groupoG Offline
          groupoG Offline
          groupo
          @tom This may be my issue, I still had the standoffs unscrewed so I could take the SIM card out easier. Which two connectors are you referring to? Will rescrew the standoffs in the meantime
          tomT groupoG 2 Replies Last reply
          • groupoG groupo
            @groupo The two board to board connectors, J2, and J4 as seen here: https://docs.modalai.com/5G-Modem-datasheet/#j2-voxl-2-board-to-board
            I would also ensure that the modem card is fully seated in the M0090 add-on as well
            • groupoG groupo
              groupoG Offline
              groupoG Offline
              groupo
              I tightened the standoffs back down and the wifi adapter came back on! Also, wwan0 is up for the modem now too. thanks @tom
              • groupoG groupo
                @groupo great to hear!
                  groupoG Offline
                  groupoG Offline
                  groupo
                  @tom I have a lot of modem-related trouble shooting I would like to do before coming here for actual help, but while I am going thru that, I'd like to broach our use case and see if you have any initial reservations about it. We are running a private LTE network. I know the APN and am calling voxl-config-modem accordingly, but am running into some qmi errors. While I am digging thru some of voxl-modem and voxl-modem-start to see if I can get a handle of what is going on, do you know if this use case is supported?
                  tomT 2 Replies Last reply
                  • groupoG groupo
                    @groupo The private network would have to be compatible with the flavor of modem hardware you're using but that is something other customers have done in the past so I don't see any issues with that plan
                    • groupoG groupo
                      @groupo Are you using a Quectel or Sierra modem?
                        groupoG Offline
                        groupoG Offline
                        groupo
                        @tom we are using the sierra, I noted in another post that it is the 9291 and I see only an option for the 9191, but one of the other devs (Alex?) had said that the 9191 option would be fine
                        groupoG tomT 2 Replies Last reply
                        • groupoG groupo
                          groupoG Offline
                          groupoG Offline
                          groupo
                          @tom I also will note, modem-flavor-wise, it is B3 LTE network (though, we are in America) which is supported in the datasheets
                          • groupoG groupo
                            @groupo Yeah that option in voxl-configure-modem is correct, I should update it in the future to make it more clear.
                            This is what gets run on boot with that option: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/blob/master/scripts/voxl-modem-start?ref_type=heads#L122
                            For that modem, voxl-modem just acts as a wrapper for qmicli: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/blob/master/scripts/voxl-modem-start?ref_type=heads#L147
                            and udhcpc: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/blob/master/scripts/voxl-modem-start?ref_type=heads#L160
                            Feel free to modify the script as needed to fit your application
