  3. Unable to communicate with add-on board
13 Posts 4 Posters 2.5k Views 2 Watching
  • R Offline
    R Offline
    rogerli
    Hello, I encountered some issues with my VOXL2. Initially, it showed a red light when powered on. After disconnecting all connections and powering it on again, the light turned green. However, I couldn't connect via adb. Later, after leaving it for some time, I was suddenly able to connect via adb. At this point, I noticed some strange behavior with the LEDs. Firstly, D1 had a yellow light, and then DS2 would turn off about five seconds after powering on.
    Regarding functionality, I used voxl-inspect-server to check, and all the opened servers appeared to be working fine. However, I found that there was only power but no communication between VOXL2 and the Microhard add-on board (the Microhard could pair with my computer). When I checked with ifconfig, I noticed that VOXL2 did not display usb0 or eth0. Even when using a WiFi dongle, wlo0 was not displayed.
    What is the current status of VOXL2? What steps should I take to ensure that VOXL2 functions properly?
    VinnyV 1 Reply Last reply
    • R rogerli
      VinnyV Offline
      VinnyV Offline
      Vinny
      Hi @rogerli
      A red light at DS1 when powering ON implies your power supply input to VOXL 2 is not in spec.
      https://docs.modalai.com/voxl2-leds/
      Can you please post a pic of your setup and we can go from there. No point doing any further steps until we know you have a good power module.
      Vinny
      R 1 Reply Last reply
      • VinnyV Vinny
        Hi @rogerli
        Vinny
        R Offline
        R Offline
        rogerli
        @Vinny Here are my current settings and the power module can run normally.
        Additionally, I previously had an external flight controller connected to J18, a Microhard add-on board connected to J3, and a stereo camera connected to J6.
        • R rogerli
          VinnyV Offline
          VinnyV Offline
          Vinny
          Hi @rogerli
          Thanks for the pic. OK good. That is all normal, and your MCBL-00001-1 is from newer stock that is much more reliable than older MCBL-00001's a few years ago.
          Now, regarding the specific plug-in board with Microhard, I wonder if you had an issue we are aware of as reported from previous forum users and we capture that here:
          https://docs.modalai.com/expansion-design-guide/#j3j5-expansion
          So, when you install the Microhard, be sure the bottom of the MH board is not touching J5. If it does, that can make the system and then LEDs go wonky from shorting out stuff and prevent you from seeing the devices with lsusb.
          If you can get past all of that then someone from SW will have to chime in to help you further.
          I just jump in when I see potential HW related topics 🙂
          • VinnyV Vinny
            Hi @rogerli
            R Offline
            R Offline
            rogerli
            @Vinny
            I placed insulating tape between the VOXL2 and the MH add-on board to ensure they don't make direct contact, but it still didn't resolve the communication issue. D1 still lights up and DS2 turns off, and I still can't find the IP address of the MH.
            Only D1 and DS1 light up
            bc018c94-5d53-413b-88e1-304e5872783a-Screenshot from 2024-05-09 18-29-19.png
            8f0423b1-8231-4130-a799-9a02e77ae768-Screenshot from 2024-05-09 18-29-45.png
            • R rogerli
              @Vinny
              VinnyV Offline
              VinnyV Offline
              Vinny
              Thanks @rogerli , at least now we have confidence this is not HW related. Those indicators are acting normally now.
              At this point, I'm going to defer to our expert @tom who can help guide you further now that we are looking more likely at SW issues.
              Vinny
              • VinnyV Vinny
                Vinny
                R Offline
                R Offline
                rogerli
                @Vinny Thank you for your response. So it's normal that DS2 doesn't light up? Also, do I need to reflash the SDK or unbrick the VOXL2?
                VinnyV tomT 2 Replies Last reply
                • R rogerli
                  VinnyV Offline
                  VinnyV Offline
                  Vinny
                  Hi @rogerli
                  That is fine. DS2 is user controlled as per that web link above.
                  It normally flashes at first then goes quiet until commanded by SW.
                  • R rogerli
                    tomT Online
                    tomT Online
                    @rogerli The microhard network interface (either usb0 or eth0) should at least enumerate without any custom sw configuration.
                    What SDK version are you using? (voxl-version)
                    • R Offline
                      R Offline
                      rogerli
                      @Vinny I have another VOXL2 where only DS1 and DS2 lights up constantly, but D1 doesn't light up. Is this normal? (There was a slight deformation near the power interface due to a previous fall.)
                      @tom The SDK version of the VOXL2 that I'm using is 1.1.3.
                      VinnyV A 2 Replies Last reply
                      • R rogerli
                        VinnyV Offline
                        VinnyV Offline
                        Vinny
                        @rogerli said in Unable to communicate with add-on board:
                        No. D1 means most of the system power is good. If it is OFF, your hardware has gone bad from that crash.
                        • VinnyV Vinny
                          R Offline
                          R Offline
                          rogerli
                          @Vinny said in Unable to communicate with add-on board:
                          Thank you for your response. I wanted to inquire about the situation because the VOXL2 that had been dropped is functioning normally except for unstable MH/WIFI communication.
                          • R rogerli
                            anghung
                            I initially bought two VOXL2 boards, both version 1.1.2. One was deformed due to a crash, but the other still works well. Later, I purchased two more VOXL2 boards, which arrived with version 1.1.3. One of them was completely non-functional, and the other also had communication issues. Due to time constraints, we urgently ordered two more VOXL2 boards. Should we downgrade the SDK to 1.1.2 for safety? Currently, as we are in the pre-mass production stage and sending products for inspection, we cannot afford sudden failures of critical components.
