  3. Recording and Receiving Videos
8 Posts 4 Posters 1.5k Views 1 Watching
  • WineVirusW Offline
    WineVirusW Offline
    WineVirus
    I'm working on recording videos and taking snapshots (VOXL SDK 1.1.1. ). I'm following the steps outlined in the MAVCam Manager Doc, and using QGC to take the photos and videos. The snapshots are automatically transferred directly onto my laptop in the photos folder within the QGC folder by just clicking the shutter button (no pulling required).
    However, I'm having issues accessing the videos. The doc says that videos are saved locally to the VOXL disc. ls -la /data/videos and ls -la /data/snapshots returns that old files exist, but the new recordings/photos aren't there (recorded 4/29/24). Also, pulling returns two empty folders.
    Here's the output of ls -la /data and voxl-inspect-services, in case it's helpful.
    ModeratorM Eric KatzfeyE 2 Replies Last reply
    • WineVirusW WineVirus
      wrote on last edited by tom
      @WineVirus try running
      systemctl start voxl-mavcam-manager
      make sure it's running, then try again with QGC
        @WineVirus If you issue the command date on VOXL 2 what do you get? If you aren't connected to the Internet then VOXL 2 cannot update it's time and date and so uses an old value. Maybe those h265 videos and jpeg snapshot are the current ones. Can you adb pull each file individually? e.g. adb pull /data/video/video_2023-03-02_13:16:02.h265 etc.
        WineVirusW 1 Reply Last reply
          WineVirusW Offline
          WineVirusW Offline
          WineVirus
          @Eric-Katzfey date gives me 3/2/23. I'm using SoftAP, so I guess it makes sense that files that I've pushed while on WiFi have the correct date, but the videos are using the default date.
          I tried the above suggested by @Moderator and it worked, adding the new video to the folder.
          Pulling the direct file name ./adb pull /data/video/video_2023-03-02_13:16:02.h265 gives me an error; pulling just /data/video gives me the same error. Could it be a corrupted file?
          Updated ls -la /data/video output
          ModeratorM 1 Reply Last reply
            @WineVirus Windows doesn't allow semicolons in file names. It's likely that's the issue. Try renaming that video file to video1.h265 or something simple
            ModeratorM WineVirusW 2 Replies Last reply
            • ModeratorM Moderator
              wrote on last edited by Moderator
              @Moderator ./adb shell mv /data/video/video_2023-03-02_13:16:02.h265 /data/video/video1.h265
                WineVirusW Offline
                WineVirusW Offline
                WineVirus
                @Moderator Ah, yep. That fixed it. Thanks for the help!
                L 1 Reply Last reply
                  L Offline
                  L Offline
                  linus777
                  wrote on last edited by linus777
                  @WineVirus
                  @Moderator What part do I need to modify to automatically save it to the QGC area?
