  3. Take-Off and Land command each fly to xy=[0,0] location instead of on the spot
px4
6 Posts 3 Posters 2.6k Views 1 Watching
  • LaborzaubererTHIL Offline
    LaborzaubererTHI
    Dear developers,
    while connected to PX4 instance over MavSDK, using the python environment, we initiate the take-off and land command.
    But instead of the commands being executed on the spot, meaning where the drone is, the drones fly towards its xy=[0,0] location while executing the respectively command. So instead of flying vertical each time, they actually fly diagonal.
    More detailed description:
    Drone position at [1, 0, 0].
    Command takeoff.
    Offboard to setpoint [-2,0].
    Command land.
    April tag #0 is set to “unknown” and no other tag specified.
    Result:
    Took off and flew diagonal to location: NED = [0, 0, -1.5].
    Flew backwards to [-2,0,-1.5] as commanded in offboard mode.
    Land command led to a diagonal land flight at [0,0] location, where it initialy took off from.
    Expected:
    Take-off and land command would lead to vertical flight at the xy-location where it was when initiated.
    The flight can be seen here: https://www.youtube.com/watch?v=Trz97csbsz0
    Our example is very close to your example offboard_position_ned2.py found here:
    https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python/-/blob/master/offboard_position_ned2.py?ref_type=heads
    From testing PX4 within an gazebo environment, we did not expect such a behavior.
    Regards
    LabMag
    Drone: RB5
    System-image: 1.7.1-M0052-14.1a-perf-nightly-20231025
    Kernel: #1 SMP PREEMPT Thu Oct 26 05:24:02 UTC 2023 4.19.125
    hw version: M0052
    voxl-suite: 1.1.2
    wilkinsafW 1 Reply Last reply
    • LaborzaubererTHIL LaborzaubererTHI
      Dear developers,
      Command takeoff.
      Command land.
      Result:
      Expected:
      Regards
      LabMag
      Drone: RB5
      hw version: M0052
      voxl-suite: 1.1.2
      wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      @LaborzaubererTHI
      What coordinate frame are you using?
      LaborzaubererTHIL 1 Reply Last reply
      • wilkinsafW wilkinsaf
        @LaborzaubererTHI
        LaborzaubererTHI
        @wilkinsaf
        We are connected to the drone via MavSDK. We booted the drone at the [0,0] location. Carried it forwards to [1,0] and send the takeoff and land commands via MavSDK.
        Due to the fact that I think we are connected to PX4 I suspect we are using its coordinate system.
        Regards.
          @wilkinsaf
          Regards.
          LaborzaubererTHI
          @wilkinsaf
          @LaborzaubererTHI
          How would one go about using the different coordinate systems? All of our code is currently running on an external computer, not on the drone. [Question might need separate thread].
            @wilkinsaf
            @LaborzaubererTHI
            @LaborzaubererTHI Sounds like it may be similar to: https://forum.modalai.com/topic/2533/failsafe-landing-bug-in-px4-1-14/19?_=1713800679314
              LaborzaubererTHI
              @Eric-Katzfey said in Take-Off and Land command each fly to xy=[0,0] location instead of on the spot:
              Indeed it does.
