  3. Adding USB camera to Voxl1
14 Posts 5 Posters 4.0k Views 3 Watching
  • R Offline
    R Offline
    riteshsharma
    I am trying to find a way to add two USB camera to Voxl1, The reason for doing so is that the MIPI cable length for connecting Hires Camera is too short for my project. The only usb connector provided on the voxl1 is being used by FLIR BOSON (Thermal) Camera and there is no way to add another USB Hires Camera. Can you please provide some insight into this?
    ModeratorM 1 Reply Last reply
    • R riteshsharma
      @riteshsharma you can use the LTE board with no modem as a 2 port USB hub https://www.modalai.com/products/voxl-lte?variant=39300535681075
      R 2 Replies Last reply
      • ModeratorM Moderator
        R Offline
        R Offline
        riteshsharma
        @Moderator
        Can we use MIPI repeater to extend the length of the cable? Do you have some suggestion what kind of MIPI repeater will be compatible with the existing pin connection on Voxl1-Deck?
        VinnyV 1 Reply Last reply
        • R riteshsharma
          @Moderator
          VinnyV Offline
          VinnyV Offline
          Vinny
          Hi @riteshsharma
          We've had one customer successfully use this part from TI, but we have not made any hardware internally.
          So, we'd recommend trying that solution from TI such as: https://www.ti.com/product/SN65DPHY440SS
            R Offline
            R Offline
            riteshsharma
            @Moderator Thank you for your suggestion. I would like to know if two USB supported camera (Thermal and Hires) can use UVC configurations. In other words, Can I use UVC pipe to connect attached USB cameras together? If yes, Can you provide example of the configuration file.
            • R riteshsharma
              @riteshsharma we don't have an example of this, sorry. It seems like it would be feasible
              R 1 Reply Last reply
                R Offline
                R Offline
                riteshsharma
                wrote on last edited by riteshsharma
                @Moderator
                Thank you for your reply. It gives me hope that I can connect two camera together. However, I wonder how should I configure uvc for each of my camera. Each time I use voxl-uvc-server with one of the option popping up on my terminal (options are shown below), the configuration file at /etc/modalai/voxl-uvc-server.conf get replaced with new settings.
                Also, I tried changing configuration file manually but then only the first configuration shows up on voxl-portal.
                "pipe_name": "uvc_hires",
                "width": 1920,
                "height": 1080,
                "fps": 5,
                    "pipe_name":    "uvc_boson",
                    "width":        640,
                    "height":       480,
                    "fps":  30
                • R riteshsharma
                  @Moderator
                  "width": 1920,
                  "height": 1080,
                  "fps": 5,
                      "width":        640,
                      "height":       480,
                      "fps":  30
                  R Offline
                  R Offline
                  riteshsharma
                  @Moderator I was able to start two camera (thermal camera and hires camera) connected through two USB using the command below.
                  voxl-uvc-server -d -v 0c45 -p 636b -r 1920x1080 -f 5 -o uvc_hires (Hires Camera)
                  voxl-uvc-server -d -v 09cb -p4007 -r 640x512 -f 30 -o uvc_boson (Thermal Camera)
                  But I could not find a way to start both the camera together. Only one works at a time as the configuration file overrides. It can only accept one UVC configuration settings. I would appreciate if you could provide me a way to correctly set up configuration file for both the camera.
                  I have already gone through documentation at https://docs.modalai.com/voxl-uvc-server/. It only mentions that we need to have different setup for each camera which in my case is evident from the two commands above.
                  • R riteshsharma
                    @riteshsharma Here's the source code to where the voxl-uvc-server is killing other processes: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/src/main.c?ref_type=heads#L302
                    you should fork that repository and add a command line flag to disable that feature. We're happy to look at a merge request if you feel that feature is helpful
                      R Offline
                      R Offline
                      riteshsharma
                      #10
                      @Moderator Can you please provide updated instruction to build voxl-uvc-server package so that I can deploy it to Voxl1? I followed the instruction on the link (https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server). It is giving me errors.
                      voxl-emulator:~$  ./install_build_deps.sh apq8096 dev
                      using apq8096 dev repo
                      Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//Packages.gz.
                      Updated source 'dev'.
                      installing:
                      libmodal-json
                      libmodal-pipe
                      voxl-libuvc
                      Package libmodal-json (0.4.3) installed in root is up to date.
                      Package libmodal-pipe (2.10.0) installed in root is up to date.
                      Package voxl-libuvc (1.0.7) installed in root is up to date.
                      Done installing dependencies
                      voxl-emulator:~$ ./build.sh  apq8096
                      CMake Error at /usr/share/cmake-3.3/Modules/CMakeDetermineSystem.cmake:104 (message):
                        Could not find toolchain file:
                        /opt/cross_toolchain/arm-gnueabi-4.9.toolchain.cmake
                        CMakeLists.txt:2 (project)
                      CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly.
                      Missing variable is:
                      CMAKE_C_COMPILER_ENV_VAR
                      CMAKE_C_COMPILER
                      CMake Error: Could not find cmake module file: /home/root/build/CMakeFiles/3.3.1/CMakeCCompiler.cmake
                      CMAKE_CXX_COMPILER_ENV_VAR
                      CMAKE_CXX_COMPILER
                      CMake Error: Could not find cmake module file: /home/root/build/CMakeFiles/3.3.1/CMakeCXXCompiler.cmake
                      CMake Error at CMakeLists.txt:2 (project):
                        No CMAKE_C_COMPILER could be found.
                        Tell CMake where to find the compiler by setting the CMake cache entry
                        CMAKE_C_COMPILER to the full path to the compiler, or to the compiler name
                        if it is in the PATH.
                        No CMAKE_CXX_COMPILER could be found.
                        CMAKE_CXX_COMPILER to the full path to the compiler, or to the compiler
                        name if it is in the PATH.
                      CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
                      CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
                      -- Configuring incomplete, errors occurred!
                      make: *** No targets specified and no makefile found.  Stop.
                      I also tried using voxl-cross. It was able to build the package correctly but gave me error while executing.
                      voxl:~$ voxl-uvc-server
                      voxl-uvc-server: error while loading shared libraries: libuvc.so.0: cannot open shared object file: No such file or directory
                      • R riteshsharma
                        installing:
                        libmodal-json
                        libmodal-pipe
                        voxl-libuvc
                        CMAKE_C_COMPILER
                        CMAKE_CXX_COMPILER
                        @riteshsharma,
                        Can you please try to put the source code of voxl-uvc-server on VOXL1 and just build it on target?
                        You will need to modify the build.sh file (https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/build.sh)
                        to have an entry like below and execute using ./build.sh native
                        native)
                        		mkdir -p build
                        		cd build
                        		cmake -DBUILDSIZE=32 ../
                        		make -j$(nproc)
                        		cd ../
                          @riteshsharma,
                          native)
                          		mkdir -p build
                          		cd build
                          		make -j$(nproc)
                          		cd ../
                          R Offline
                          R Offline
                          riteshsharma
                          @Alex-Kushleyev
                          Thank you @Alex-Kushleyev . Finally I was able to modify the code to make it work for 2 USB cameras.
                          Alex KushleyevA Eric KatzfeyE 2 Replies Last reply
                          • R riteshsharma
                            @Alex-Kushleyev
                            @riteshsharma excellent!
                            • R riteshsharma
                              @Alex-Kushleyev
                              @riteshsharma Was there an error in our documentation that we need to fix? Did you make some changes that you think may be valuable to others and, if so, are you willing to share them?
