  3. Adding USB camera to Voxl1
14 Posts 5 Posters 3.7k Views 3 Watching
  • ModeratorM Moderator
    @riteshsharma you can use the LTE board with no modem as a 2 port USB hub https://www.modalai.com/products/voxl-lte?variant=39300535681075
    R Offline
    R Offline
    riteshsharma
    @Moderator Thank you for your suggestion. I would like to know if two USB supported camera (Thermal and Hires) can use UVC configurations. In other words, Can I use UVC pipe to connect attached USB cameras together? If yes, Can you provide example of the configuration file.
    ModeratorM 1 Reply Last reply
    • R riteshsharma
      @riteshsharma we don't have an example of this, sorry. It seems like it would be feasible
      R 1 Reply Last reply
        R Offline
        R Offline
        riteshsharma
        wrote on last edited by riteshsharma
        @Moderator
        Thank you for your reply. It gives me hope that I can connect two camera together. However, I wonder how should I configure uvc for each of my camera. Each time I use voxl-uvc-server with one of the option popping up on my terminal (options are shown below), the configuration file at /etc/modalai/voxl-uvc-server.conf get replaced with new settings.
        Also, I tried changing configuration file manually but then only the first configuration shows up on voxl-portal.
        "pipe_name": "uvc_hires",
        "width": 1920,
        "height": 1080,
        "fps": 5,
            "pipe_name":    "uvc_boson",
            "width":        640,
            "height":       480,
            "fps":  30
        • R riteshsharma
          @Moderator
          "width": 1920,
          "height": 1080,
          "fps": 5,
              "width":        640,
              "height":       480,
              "fps":  30
          R Offline
          R Offline
          riteshsharma
          @Moderator I was able to start two camera (thermal camera and hires camera) connected through two USB using the command below.
          voxl-uvc-server -d -v 0c45 -p 636b -r 1920x1080 -f 5 -o uvc_hires (Hires Camera)
          voxl-uvc-server -d -v 09cb -p4007 -r 640x512 -f 30 -o uvc_boson (Thermal Camera)
          But I could not find a way to start both the camera together. Only one works at a time as the configuration file overrides. It can only accept one UVC configuration settings. I would appreciate if you could provide me a way to correctly set up configuration file for both the camera.
          I have already gone through documentation at https://docs.modalai.com/voxl-uvc-server/. It only mentions that we need to have different setup for each camera which in my case is evident from the two commands above.
          • R riteshsharma
            @riteshsharma Here's the source code to where the voxl-uvc-server is killing other processes: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/src/main.c?ref_type=heads#L302
            you should fork that repository and add a command line flag to disable that feature. We're happy to look at a merge request if you feel that feature is helpful
              R Offline
              R Offline
              riteshsharma
              #10
              @Moderator Can you please provide updated instruction to build voxl-uvc-server package so that I can deploy it to Voxl1? I followed the instruction on the link (https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server). It is giving me errors.
              voxl-emulator:~$  ./install_build_deps.sh apq8096 dev
              using apq8096 dev repo
              Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//Packages.gz.
              Updated source 'dev'.
              installing:
              libmodal-json
              libmodal-pipe
              voxl-libuvc
              Package libmodal-json (0.4.3) installed in root is up to date.
              Package libmodal-pipe (2.10.0) installed in root is up to date.
              Package voxl-libuvc (1.0.7) installed in root is up to date.
              Done installing dependencies
              voxl-emulator:~$ ./build.sh  apq8096
              CMake Error at /usr/share/cmake-3.3/Modules/CMakeDetermineSystem.cmake:104 (message):
                Could not find toolchain file:
                /opt/cross_toolchain/arm-gnueabi-4.9.toolchain.cmake
              Call Stack (most recent call first):
                CMakeLists.txt:2 (project)
              CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly.
              Missing variable is:
              CMAKE_C_COMPILER_ENV_VAR
              CMAKE_C_COMPILER
              CMake Error: Could not find cmake module file: /home/root/build/CMakeFiles/3.3.1/CMakeCCompiler.cmake
              CMAKE_CXX_COMPILER_ENV_VAR
              CMAKE_CXX_COMPILER
              CMake Error: Could not find cmake module file: /home/root/build/CMakeFiles/3.3.1/CMakeCXXCompiler.cmake
              CMake Error at CMakeLists.txt:2 (project):
                No CMAKE_C_COMPILER could be found.
                Tell CMake where to find the compiler by setting the CMake cache entry
                CMAKE_C_COMPILER to the full path to the compiler, or to the compiler name
                if it is in the PATH.
                No CMAKE_CXX_COMPILER could be found.
                CMAKE_CXX_COMPILER to the full path to the compiler, or to the compiler
                name if it is in the PATH.
              CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
              CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
              -- Configuring incomplete, errors occurred!
              make: *** No targets specified and no makefile found.  Stop.
              I also tried using voxl-cross. It was able to build the package correctly but gave me error while executing.
              voxl:~$ voxl-uvc-server
              voxl-uvc-server: error while loading shared libraries: libuvc.so.0: cannot open shared object file: No such file or directory
              • R riteshsharma
                installing:
                libmodal-json
                libmodal-pipe
                voxl-libuvc
                CMAKE_C_COMPILER
                CMAKE_CXX_COMPILER
                @riteshsharma,
                Can you please try to put the source code of voxl-uvc-server on VOXL1 and just build it on target?
                You will need to modify the build.sh file (https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/build.sh)
                to have an entry like below and execute using ./build.sh native
                native)
                		mkdir -p build
                		cd build
                		cmake -DBUILDSIZE=32 ../
                		make -j$(nproc)
                		cd ../
                  @riteshsharma,
                  native)
                  		mkdir -p build
                  		cd build
                  		make -j$(nproc)
                  		cd ../
                  R Offline
                  R Offline
                  riteshsharma
                  Thank you @Alex-Kushleyev . Finally I was able to modify the code to make it work for 2 USB cameras.
                  Alex KushleyevA Eric KatzfeyE 2 Replies Last reply
                  • R riteshsharma
                    @riteshsharma excellent!
                    • R riteshsharma
                      @riteshsharma Was there an error in our documentation that we need to fix? Did you make some changes that you think may be valuable to others and, if so, are you willing to share them?
