  2. VOXL Dev Drones
  3. VOXL m500 Reference Drone
  4. Controller not recognized in QGC
13 Posts 3 Posters 4.0k Views 1 Watching
  • Evan DE Offline
    Evan DE Offline
    Evan D
    I'm having trouble getting my Spektrum DX6e controller connected to QGroundControl. I have connected it and calibrated it before, but now when I try to do this i get the message "Radio Not Ready Please turn on the transmitter." The Spektrum Bind button works and the radio is on and connected when I get this message. I have made sure to reboot the drone after binding the controller.
    Not sure if this is the problem, but I was messing around with the px4 parameters and ended up resetting them, then uploading them from here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/tree/master/params/v1.14/platforms
    I tried to use both the M500_FCV1.params and the M500_FCV2.params, but neither of these fixed my controller problem. Which of these is correct?
    I'm working with a brand new M500, so everything should be up to date.
    Thanks in advance for your help!
    Evan DE 1 Reply Last reply
    • Evan DE Evan D
      Evan DE Offline
      Evan DE Offline
      Evan D
      Just wanted to follow up because I still cannot get the controller to work.
      In QGroundControl I selected "Reset all to firmwares defaults", uploaded the M500_FCV1.params, and re-calibrated the sensors. Should the drone be ready to fly at this point or do I need to upload some of the helper parameters?
      ModeratorM 1 Reply Last reply
      • Evan DE Evan D
        @Evan-D The drone is flown for 15 minutes prior to flight. If it shipped with a Spektrum receiver, it would have flown with a Spektrum transmitter prior to shipment. you should not need to change any settings, just bind and fly
        Can you look at the PX4 log and see if there is indication to why RC isn't coming through?
        • ModeratorM Moderator
          Evan DE Offline
          Evan DE Offline
          Evan D
          @Moderator Thanks for your reply. I'm very new to this so I appreciate your patience.
          The log file just shows that no RC messages are getting through, even though I have binded the transmitter to the receiver and am moving the joysticks. But I haven't calibrated the controller so this may be expected.
          Here's the log file from simply turning on the drone and controller and moving the joysticks: https://logs.px4.io/plot_app?log=8cc328d8-5b81-426e-b04c-72698a4ed8f4
          What else can I try to troubleshoot? Is there anything in the log files that stands out?
          • Evan DE Evan D
            @Evan-D Can you post the results of journalctl -b -u voxl-px4? That command should show the startup log for px4.
              Evan DE Offline
              Evan DE Offline
              Evan D
              @Eric-Katzfey Thanks for your reply.
              That command returns -- No entries --, i think because I'm on a VOXL flight (m500) so there isn't a voxl-px4 service. Is there a way to view the px4 startup log on voxl?
              Also, I ran voxl-configure-mpa to reset the services, but the status log for voxl-mavlink-server shows that the mavlink buffer is full, as shown below. I don't understand why this would be happening when all the services should be in the default state, but maybe this is causing my problem of QGroundControl not recognizing the controller?
              7eb60947-e822-4aed-950b-a0f811b1f1de-image.png jou
              Output of journalctl -b -u voxl-vision-hub :
              -- Logs begin at Thu 1970-01-01 00:00:04 UTC, end at Thu 2024-03-21 14:17:14 UTC. --
              Jan 01 00:00:08 apq8096 systemd[1]: Started voxl-vision-hub.
              Jan 01 00:00:08 apq8096 voxl-vision-hub[2366]: WARNING: voxl-mavlink-server does not appear to be running
              Jan 01 00:00:08 apq8096 voxl-vision-hub[2366]: make sure it is enabled: systemctl enable voxl-mavlink-server
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: loading our own config file
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: =================================================================
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Parameters as loaded from config file:
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: config_file_version:        1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: MAVROS / MAVSDK
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_localhost_mavlink_udp    0
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: localhost_udp_port_number:  14551
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: VIO
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_vio:                     1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: vio_pipe:                   qvio
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: secondary_vio_pipe:         ov
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_reset_vio_if_initialized_inverted: 1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: vio_warmup_s:               3.000000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: send_odom_while_failed:     1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: APQ8096-ONLY FEATURES
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_set_clock_from_gps:      1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_force_onboard_mav1_mode: 1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_reset_px4_on_error:      1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: MISC FEATURES
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: horizon_cal_tolerance:      0.500000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: OFFBOARD MODE
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: offboard_mode:              figure_eight
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: follow_tag_id:              0
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: figure_eight_move_home:     1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: robot_radius:               0.300000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: collision_sampling_dt:      0.100000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: max_lookahead_distance:     1.000000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: FIXED FRAME RELOCALIZATION
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_tag_fixed_frame:         0
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: fixed_frame_filter_len:     5
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_transform_mavlink_pos_setpoints_from_fixed_frame:0
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: COLLISION PREVENTION (VOA)
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_voa:                     1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_upper_bound_m:          -0.150000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_lower_bound_m:          0.150000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_memory_s:               1.000000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_max_pc_per_fusion:      100
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_min_dist_m:         0.250000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_max_dist_m:         20.000000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_under_trim_m:       1.000000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_threshold:          3
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_slices:             36
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_bin_depth_m:        0.150000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_send_rate_hz:           20.000000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_input #0
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: enabled:            1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: type:               point_cloud
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: input_pipe:         dfs_point_cloud
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: frame:              stereo_l
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: max_depth:          8.000000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: min_depth:          0.300000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: cell_size:          0.080000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: threshold:          4
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: x_fov_deg:          68.000000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: y_fov_deg:          56.000000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: conf_cutoff:        0
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_input #1
              Jan 01 00:00:07 apq8096 systemd[1]: Starting voxl-mavlink-server...
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: conf_cutoff:        125
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_input #4
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: type:               rangefinder
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: input_pipe:         rangefinders
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: frame:              body
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: loading extrinsics config file
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: loading horizon cal file
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting geometry module
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting autopilot monitor
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting mavlink IO
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Waiting to connect to voxl-mavlink-server
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting fixed pose input
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting vio manager
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting tag manager
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting voa manager
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting horizon cal module
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting offboard figure eight
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Init complete
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Connected to VIO pipe: qvio
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Geometry module updating to use imu: imu0 for VIO
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: new T imu wrt body:
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 0.0200   0.0140  -0.0080
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: new R imu to body:
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 1.0000  -0.0000   0.0000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 0.0000   1.0000  -0.0000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 0.0000   0.0000   1.0000
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: done updating transforms to use imu: imu0
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Connected to voxl-mavlink-server
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Detected Autopilot Mavlink SYSID 1
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: requesting autopilot_version
              Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Detected autopilot version: 1.14.0
              Mar 21 14:18:09 apq8096 voxl-vision-hub[2366]: WARNING: Autopilot Mavlink Disconnected
              Mar 21 14:18:11 apq8096 voxl-vision-hub[2366]: WARNING: Autopilot Mavlink Disconnected
              Mar 21 14:19:08 apq8096 voxl-vision-hub[2366]: WARNING: Autopilot Mavlink Disconnected
              Thanks so much for any help.
              • Evan DE Evan D
                @Evan-D Ah, sorry, I didn't realize this was an M500 (voxl + flight core).
                • Evan DE Evan D
                  @Evan-D But you are connected to QGC? You see other data there, just not the RC data? There are QGC screens that will allow you to interact with PX4 on the flihgt controller. The mavlink console allows you to enter commands to PX4. If this is working you can use the dmesg command to see all of the startup messages. Also, for RC, you will want to use listener input_rc to look at the RC data in the input_rc topic that is being published by the flight controller.
                    Evan DE Offline
                    Evan DE Offline
                    Evan D
                    @Eric-Katzfey Yes, I'm connected to QGC and I can see the camera feed and other data. The spektrum bind command works, so the receiver lights up with a solid led when I turn on the transmitter, but for some reason the data from the receiver isn't making it to QGC. Here's the output to those commands after I have connected the rc transmitter:
                    nsh> listener input_rc
                    never published
                    nsh> dmesg
                    HW arch: MODALAI_FC_V1
                    HW type: V1001000
                    HW version: 0x001
                    HW revision: 0x000
                    PX4 git-hash: b02a6b4ae93d12fa399673bf442c45087cee0759
                    PX4 version: 1.14.0 0 (17694720)
                    Vendor version: 2.0.63 0 (33570560)
                    OS: NuttX
                    OS version: Release 11.0.0 (184549631)
                    OS git-hash: 3f77354c0dc88793a47ff3b57595195ab45f7ba9
                    Build datetime: Dec 11 2023 20:04:02
                    Build uri: localhost
                    Build variant: default
                    Toolchain: GNU GCC, 9.3.1 20200408 (release)
                    PX4GUID: 000200000000203334354d3350140031002c
                    MCU: STM32F76xxx, rev. Z
                    INFO  [param] selected parameter default file /fs/mtd_params
                    INFO  [param] importing from '/fs/mtd_params'
                    INFO  [parameters] BSON document size 2043 bytes, decoded 2043 bytes (INT32:23, FLOAT:68)
                    INFO  [param] selected parameter backup file /fs/microsd/parameters_backup.bson
                    Board architecture defaults: /etc/init.d/rc.board_arch_defaults
                    Board defaults: /etc/init.d/rc.board_defaults
                    Loading airframe: /etc/init.d/airframes/4001_quad_x
                    INFO  [dataman] data manager file '/fs/microsd/dataman' size is 62560 bytes
                    Board sensors: /etc/init.d/rc.board_sensors
                    ERROR [voxl_esc] Invalid parameter VOXL_ESC_FUNCX.  Only supports motors 1-4.  Please verify parameters.
                    ERROR [voxl_esc] Invalid parameter VOXL_ESC_MOTORX.  Please verify parameters.
                    ERROR [voxl_esc] Task start failed (-1)
                    voxlpm #0 on I2C bus 3 (external) address 0x44
                    WARN  [SPI_I2C] Already running on bus 3
                    WARN  [SPI_I2C] voxlpm: no instance started (no device on bus?)
                    icm20602 #0 on SPI bus 1 rotation 12
                    icm42688p #0 on SPI bus 2 rotation 12
                    ERROR [SPI_I2C] bmi088: no instance started (no device on bus?)
                    bmp388 #0 on I2C bus 4 (external) address 0x76
                    qmc5883l #0 on I2C bus 1 (external) address 0xD
                    ekf2 [812:237]
                    Starting Main GPS on /dev/ttyS0
                    Starting MAVLink on /dev/ttyS6
                    INFO  [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS6 @ 57600B
                    Starting MAVLink on /dev/ttyS4
                    INFO  [mavlink] mode: Onboard, data rate: 46080 B/s on /dev/ttyS4 @ 921600B
                    INFO  [logger] logger started (mode=all)
                    INFO  [uavcan] Node ID 1, bitrate 1000000
                    NuttShell (NSH) NuttX-11.0.0
                    nsh> INFO  [gps] baudrate set to 9600
                    INFO  [gps] Sending initial CFG_VALSET. Attempt: 1
                    INFO  [gps] Got ack to initial CFG_VALSET!
                    INFO  [gps] u-blox firmware version: SPG 5.10
                    INFO  [gps] u-blox protocol version: 34.10
                    INFO  [gps] u-blox module: MAX-M10S
                    WARN  [health_and_arming_checks] Preflight Fail: Yaw estimate error
                    WARN  [health_and_arming_checks] Preflight Fail: Strong magnetic interference
                    INFO  [mavlink] Starting mavlink shell
                    • Evan DE Evan D
                      never published
                      nsh> dmesg
                      HW type: V1001000
                      HW version: 0x001
                      HW revision: 0x000
                      OS: NuttX
                      ekf2 [812:237]
                      @Evan-D If input_rc has never been published it means that the rc driver hasn't connected to the receiver. What is the setting of your RC_INPUT_PROTO parameter? It should be -1
                        Evan DE Offline
                        Evan DE Offline
                        Evan D
                        wrote on last edited by Evan D
                        #11
                        @Eric-Katzfey
                        RC_INPUT_PROTO is set to -1, and RC_PORT_CONFIG is set to 0, so i'm not sure why the rc driver isn't connecting to the receiver.
                        Would it be worthwhile to try to reinstall px4?
                        Thanks so much for your help.
                        • Evan DE Evan D
                          @Eric-Katzfey
                          @Evan-D Definitely worth a try. Something has obviously changed in a way to prevent the driver from working and a fresh install may clear that out.
                            Evan DE Offline
                            Evan DE Offline
                            Evan D
                            @Eric-Katzfey Reinstalling px4 solved my problem, thanks for your help!
