    Controller not recognized in QGC
    VOXL m500 Reference Drone
    1227
    • Evan DE
      Evan D
      I'm having trouble getting my Spektrum DX6e controller connected to QGroundControl. I have connected it and calibrated it before, but now when I try to do this i get the message "Radio Not Ready Please turn on the transmitter." The Spektrum Bind button works and the radio is on and connected when I get this message. I have made sure to reboot the drone after binding the controller.
      Not sure if this is the problem, but I was messing around with the px4 parameters and ended up resetting them, then uploading them from here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/tree/master/params/v1.14/platforms
      I tried to use both the M500_FCV1.params and the M500_FCV2.params, but neither of these fixed my controller problem. Which of these is correct?
      I'm working with a brand new M500, so everything should be up to date.
      Thanks in advance for your help!
      Evan DE 1 Reply Last reply Reply Quote 0
      • Evan DE
        Evan D @Evan D
        Just wanted to follow up because I still cannot get the controller to work.
        In QGroundControl I selected "Reset all to firmwares defaults", uploaded the M500_FCV1.params, and re-calibrated the sensors. Should the drone be ready to fly at this point or do I need to upload some of the helper parameters?
        • ModeratorM
          Moderator ModalAI Team @Evan D
          @Evan-D The drone is flown for 15 minutes prior to flight. If it shipped with a Spektrum receiver, it would have flown with a Spektrum transmitter prior to shipment. you should not need to change any settings, just bind and fly
          Can you look at the PX4 log and see if there is indication to why RC isn't coming through?
          • Evan DE
            Evan D @Moderator
            @Moderator Thanks for your reply. I'm very new to this so I appreciate your patience.
            The log file just shows that no RC messages are getting through, even though I have binded the transmitter to the receiver and am moving the joysticks. But I haven't calibrated the controller so this may be expected.
            Here's the log file from simply turning on the drone and controller and moving the joysticks: https://logs.px4.io/plot_app?log=8cc328d8-5b81-426e-b04c-72698a4ed8f4
            What else can I try to troubleshoot? Is there anything in the log files that stands out?
              Eric Katzfey ModalAI Team @Evan D
              @Evan-D Can you post the results of journalctl -b -u voxl-px4? That command should show the startup log for px4.
              • Evan DE
                Evan D @Eric Katzfey
                @Eric-Katzfey Thanks for your reply.
                That command returns -- No entries --, i think because I'm on a VOXL flight (m500) so there isn't a voxl-px4 service. Is there a way to view the px4 startup log on voxl?
                Also, I ran voxl-configure-mpa to reset the services, but the status log for voxl-mavlink-server shows that the mavlink buffer is full, as shown below. I don't understand why this would be happening when all the services should be in the default state, but maybe this is causing my problem of QGroundControl not recognizing the controller?
                7eb60947-e822-4aed-950b-a0f811b1f1de-image.png jou
                Output of journalctl -b -u voxl-vision-hub :
                -- Logs begin at Thu 1970-01-01 00:00:04 UTC, end at Thu 2024-03-21 14:17:14 UTC. --
                Jan 01 00:00:08 apq8096 systemd[1]: Started voxl-vision-hub.
                Jan 01 00:00:08 apq8096 voxl-vision-hub[2366]: WARNING: voxl-mavlink-server does not appear to be running
                Jan 01 00:00:08 apq8096 voxl-vision-hub[2366]: make sure it is enabled: systemctl enable voxl-mavlink-server
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: loading our own config file
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: =================================================================
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Parameters as loaded from config file:
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: config_file_version:        1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: MAVROS / MAVSDK
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_localhost_mavlink_udp    0
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: localhost_udp_port_number:  14551
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: VIO
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_vio:                     1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: vio_pipe:                   qvio
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: secondary_vio_pipe:         ov
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_reset_vio_if_initialized_inverted: 1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: vio_warmup_s:               3.000000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: send_odom_while_failed:     1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: APQ8096-ONLY FEATURES
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_set_clock_from_gps:      1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_force_onboard_mav1_mode: 1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_reset_px4_on_error:      1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: MISC FEATURES
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: horizon_cal_tolerance:      0.500000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: OFFBOARD MODE
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: offboard_mode:              figure_eight
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: follow_tag_id:              0
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: figure_eight_move_home:     1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: robot_radius:               0.300000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: collision_sampling_dt:      0.100000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: max_lookahead_distance:     1.000000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: FIXED FRAME RELOCALIZATION
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_tag_fixed_frame:         0
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: fixed_frame_filter_len:     5
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_transform_mavlink_pos_setpoints_from_fixed_frame:0
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: COLLISION PREVENTION (VOA)
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_voa:                     1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_upper_bound_m:          -0.150000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_lower_bound_m:          0.150000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_memory_s:               1.000000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_max_pc_per_fusion:      100
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_min_dist_m:         0.250000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_max_dist_m:         20.000000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_under_trim_m:       1.000000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_threshold:          3
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_slices:             36
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_bin_depth_m:        0.150000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_send_rate_hz:           20.000000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_input #0
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: enabled:            1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: type:               point_cloud
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: input_pipe:         dfs_point_cloud
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: frame:              stereo_l
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: max_depth:          8.000000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: min_depth:          0.300000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: cell_size:          0.080000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: threshold:          4
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: x_fov_deg:          68.000000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: y_fov_deg:          56.000000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: conf_cutoff:        0
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_input #1
                Jan 01 00:00:07 apq8096 systemd[1]: Starting voxl-mavlink-server...
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: conf_cutoff:        125
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_input #4
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: type:               rangefinder
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: input_pipe:         rangefinders
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: frame:              body
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: loading extrinsics config file
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: loading horizon cal file
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting geometry module
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting autopilot monitor
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting mavlink IO
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Waiting to connect to voxl-mavlink-server
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting fixed pose input
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting vio manager
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting tag manager
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting voa manager
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting horizon cal module
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting offboard figure eight
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Init complete
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Connected to VIO pipe: qvio
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Geometry module updating to use imu: imu0 for VIO
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: new T imu wrt body:
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 0.0200   0.0140  -0.0080
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: new R imu to body:
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 1.0000  -0.0000   0.0000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 0.0000   1.0000  -0.0000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 0.0000   0.0000   1.0000
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: done updating transforms to use imu: imu0
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Connected to voxl-mavlink-server
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Detected Autopilot Mavlink SYSID 1
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: requesting autopilot_version
                Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Detected autopilot version: 1.14.0
                Mar 21 14:18:09 apq8096 voxl-vision-hub[2366]: WARNING: Autopilot Mavlink Disconnected
                Mar 21 14:18:11 apq8096 voxl-vision-hub[2366]: WARNING: Autopilot Mavlink Disconnected
                Mar 21 14:19:08 apq8096 voxl-vision-hub[2366]: WARNING: Autopilot Mavlink Disconnected
                Thanks so much for any help.
                  @Evan-D Ah, sorry, I didn't realize this was an M500 (voxl + flight core).
                    @Evan-D But you are connected to QGC? You see other data there, just not the RC data? There are QGC screens that will allow you to interact with PX4 on the flihgt controller. The mavlink console allows you to enter commands to PX4. If this is working you can use the dmesg command to see all of the startup messages. Also, for RC, you will want to use listener input_rc to look at the RC data in the input_rc topic that is being published by the flight controller.
                    • Evan DE
                      @Eric-Katzfey Yes, I'm connected to QGC and I can see the camera feed and other data. The spektrum bind command works, so the receiver lights up with a solid led when I turn on the transmitter, but for some reason the data from the receiver isn't making it to QGC. Here's the output to those commands after I have connected the rc transmitter:
                      nsh> listener input_rc
                      never published
                      nsh> dmesg
                      HW arch: MODALAI_FC_V1
                      HW type: V1001000
                      HW version: 0x001
                      HW revision: 0x000
                      PX4 git-hash: b02a6b4ae93d12fa399673bf442c45087cee0759
                      PX4 version: 1.14.0 0 (17694720)
                      Vendor version: 2.0.63 0 (33570560)
                      OS: NuttX
                      OS version: Release 11.0.0 (184549631)
                      OS git-hash: 3f77354c0dc88793a47ff3b57595195ab45f7ba9
                      Build datetime: Dec 11 2023 20:04:02
                      Build uri: localhost
                      Build variant: default
                      Toolchain: GNU GCC, 9.3.1 20200408 (release)
                      PX4GUID: 000200000000203334354d3350140031002c
                      MCU: STM32F76xxx, rev. Z
                      INFO  [param] selected parameter default file /fs/mtd_params
                      INFO  [param] importing from '/fs/mtd_params'
                      INFO  [parameters] BSON document size 2043 bytes, decoded 2043 bytes (INT32:23, FLOAT:68)
                      INFO  [param] selected parameter backup file /fs/microsd/parameters_backup.bson
                      Board architecture defaults: /etc/init.d/rc.board_arch_defaults
                      Board defaults: /etc/init.d/rc.board_defaults
                      Loading airframe: /etc/init.d/airframes/4001_quad_x
                      INFO  [dataman] data manager file '/fs/microsd/dataman' size is 62560 bytes
                      Board sensors: /etc/init.d/rc.board_sensors
                      ERROR [voxl_esc] Invalid parameter VOXL_ESC_FUNCX.  Only supports motors 1-4.  Please verify parameters.
                      ERROR [voxl_esc] Invalid parameter VOXL_ESC_MOTORX.  Please verify parameters.
                      ERROR [voxl_esc] Task start failed (-1)
                      voxlpm #0 on I2C bus 3 (external) address 0x44
                      WARN  [SPI_I2C] Already running on bus 3
                      WARN  [SPI_I2C] voxlpm: no instance started (no device on bus?)
                      icm20602 #0 on SPI bus 1 rotation 12
                      icm42688p #0 on SPI bus 2 rotation 12
                      ERROR [SPI_I2C] bmi088: no instance started (no device on bus?)
                      bmp388 #0 on I2C bus 4 (external) address 0x76
                      qmc5883l #0 on I2C bus 1 (external) address 0xD
                      ekf2 [812:237]
                      Starting Main GPS on /dev/ttyS0
                      Starting MAVLink on /dev/ttyS6
                      INFO  [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS6 @ 57600B
                      Starting MAVLink on /dev/ttyS4
                      INFO  [mavlink] mode: Onboard, data rate: 46080 B/s on /dev/ttyS4 @ 921600B
                      INFO  [uavcan] Node ID 1, bitrate 1000000
                      NuttShell (NSH) NuttX-11.0.0
                      nsh> INFO  [gps] baudrate set to 9600
                      INFO  [gps] Sending initial CFG_VALSET. Attempt: 1
                      INFO  [gps] Got ack to initial CFG_VALSET!
                      INFO  [gps] u-blox firmware version: SPG 5.10
                      INFO  [gps] u-blox protocol version: 34.10
                      INFO  [gps] u-blox module: MAX-M10S
                      WARN  [health_and_arming_checks] Preflight Fail: Yaw estimate error
                      WARN  [health_and_arming_checks] Preflight Fail: Strong magnetic interference
                      INFO  [mavlink] Starting mavlink shell
                        @Evan-D If input_rc has never been published it means that the rc driver hasn't connected to the receiver. What is the setting of your RC_INPUT_PROTO parameter? It should be -1
                        • Evan DE
                          RC_INPUT_PROTO is set to -1, and RC_PORT_CONFIG is set to 0, so i'm not sure why the rc driver isn't connecting to the receiver.
                          Would it be worthwhile to try to reinstall px4?
                          Thanks so much for your help.
                            @Evan-D Definitely worth a try. Something has obviously changed in a way to prevent the driver from working and a fresh install may clear that out.
                            • Evan DE
                              @Eric-Katzfey Reinstalling px4 solved my problem, thanks for your help!
