  3. voxl-vision-px4 not showing up
7 Posts 4 Posters 1.3k Views 3 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    I upgraded from voxl-suite 0.9.5 to 1.1.2 on the Seeker.
    Then I suddenly cannot connect to QGroundControl.
    I checked my services and did not see any px4 there.
    Then I checked my version and noticed that px4 was no longer there.
    There is no location for me to enter the Seeker's IP in order to communicate with QGroundControl.
    voxl:~$ voxl-version
    system-image: 4.0.0
    kernel:       #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
    hw version:   VOXL
    voxl-suite:   1.1.2
    Packages:
    Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-1.1/binary-arm64/
    Last Updated: Never
    List:
    	apq8096-dfs-server          0.3.1
    	apq8096-imu-server          1.1.0
    	apq8096-libpng              1.6.38-1
    	apq8096-rangefinder-server  0.1.3
    	apq8096-system-tweaks       0.2.3
    	apq8096-tflite              2.8.3-1
    	libapq8096-io               0.6.0
    	libmodal-cv                 0.4.0
    	libmodal-exposure           0.1.0
    	libmodal-journal            0.2.2
    	libmodal-json               0.4.3
    	libmodal-pipe               2.9.2
    	libvoxl-cci-direct          0.2.1
    	libvoxl-cutils              0.1.1
    	voxl-camera-calibration     0.5.3
    	voxl-camera-server          1.8.9
    	voxl-configurator           0.4.8
    	voxl-cpu-monitor            0.4.7
    	voxl-docker-support         1.3.0
    	voxl-jpeg-turbo             2.1.3-5
    	voxl-lepton-server          1.2.0
    	voxl-logger                 0.3.5
    	voxl-mavcam-manager         0.5.3
    	voxl-mavlink                0.1.1
    	voxl-mavlink-server         1.3.2
    	voxl-modem                  1.0.8
    	voxl-mongoose               7.7.0-1
    	voxl-mpa-to-ros             0.3.7
    	voxl-mpa-tools              1.1.3
    	voxl-opencv                 4.5.5-2
    	voxl-portal                 0.6.3
    	voxl-qvio-server            1.0.0
    	voxl-streamer               0.7.4
    	voxl-suite                  1.1.2
    	voxl-system-image           4.0-r0
    	voxl-tag-detector           0.0.4
    	voxl-tflite-server          0.3.1
    	voxl-utils                  1.3.3
    	voxl-uvc-server             0.1.6
    	voxl-vision-hub             1.7.3
    	voxl-vpn                    0.0.6
    voxl:~$ voxl-inspect-services
    Scanning services...
     docker-daemon            | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  |   Running   |    12.7%
     voxl-cpu-monitor         |  Enabled  |   Running   |     2.1%
     voxl-dfs-server          |  Enabled  |   Running   |     2.1%
     voxl-imu-server          |  Enabled  |   Running   |     0.0%
     voxl-mavcam-manager      | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     2.1%
     voxl-portal              |  Enabled  |   Running   |     0.0%
     voxl-qvio-server         |  Enabled  |   Running   |     6.3%
     voxl-streamer            | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  |   Running   |     0.0%
    I have downgraded to previous versions (voxl SDK 1.1.1 and SDK 1.1.0) but neither had px4 in them.
    I am only able to get platform 0.9.5 to work (contains px4).
    Am I missing something or should I manually push px4 into the Seeker?
    If so, what folder should I push it into?
    Should it be the .ipk or the master px4 folder?
    KrisK 1 Reply Last reply
    • KrisK Kris
      system-image: 4.0.0
      hw version:   VOXL
      voxl-suite:   1.1.2
      Packages:
      Last Updated: Never
      List:
      	libapq8096-io               0.6.0
      	libmodal-cv                 0.4.0
      	libmodal-json               0.4.3
      	libmodal-pipe               2.9.2
      	voxl-logger                 0.3.5
      	voxl-mavlink                0.1.1
      	voxl-modem                  1.0.8
      	voxl-opencv                 4.5.5-2
      	voxl-portal                 0.6.3
      	voxl-streamer               0.7.4
      	voxl-suite                  1.1.2
      	voxl-utils                  1.3.3
      	voxl-vpn                    0.0.6
      KrisK Offline
      KrisK Offline
      Kris
      voxl:~$ cat /etc/opkg/opkg.conf
      ## This file has been automatically generated.
      ## Please use voxl-configure-opkg to modify it.
      dest root /
      option lists_dir /var/lib/opkg/lists
      arch all 1
      arch arm64 7
      src/gz modalai http://voxl-packages.modalai.com/dists/apq8096/sdk-1.1/binary-arm64/
      voxl:~$ opkg info voxl-vision-px4
      voxl:~$ opkg info voxl-qvio-server
      Package: voxl-qvio-server
      Version: 1.0.0
      Depends: libmodal-pipe (>= 2.7.2), libmodal-json (>= 0.4.0), voxl-mpa-tools (>= 0.7.0)
      Status: install ok installed
      Architecture: arm64
      Installed-Time: 1709167790
      • KrisK Kris
        dest root /
        arch all 1
        arch arm64 7
        Version: 1.0.0
        Architecture: arm64
        KrisK Offline
        KrisK Offline
        Kris
        wrote on last edited by Kris
        I was able to connect to QGroundControl on SDK 1.1.2 using these application settings on QGroundControl v4.2.4
        However I did not feel like px4 was communicating with QGroundControl.
        In voxl-vision-hub.conf
        I enabled VIO and VOA.
        I was able to fly the Seeker in Position mode, but VOA was not working.
        I was not able to connect voxl mpa to ros using the command
        despite having the correct IP for my Seeker and Host PC setup in the my_ros_env.sh
        I was getting this error message;
        voxl:~$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
        ... logging to /home/root/.ros/log/7ec53908-d6c2-11ee-b3ea-18473db1c389/roslaunch-apq8096-3584.log
        Checking log directory for disk usage. This may take awhile.
        Press Ctrl-C to interrupt
        Unable to contact my own server at [http://192.168.8.1:56009/].
        This usually means that the network is not configured properly.
        A common cause is that the machine cannot ping itself.  Please check
        for errors by running:
        	ping 192.168.8.1
        For more tips, please see
        	http://www.ros.org/wiki/ROS/NetworkSetup
        The traceback for the exception was written to the log file
        I am not sure why ROS is trying to connect to 192.168.8.1 when I have my
        export ROS_MASTER_IP=192.168.105.180 (Seeker IP)
        and my
        export ROS_IP=192.168.105.189 (Host PC IP)
        How am I supposed to tell the Seeker what my host pc IP is if there is no option to do so in voxl-vision-hub.conf and there is no px4/voxl-vision-px4.conf
        ModeratorM tomT 2 Replies Last reply
        • KrisK Kris
          	ping 192.168.8.1
          and my
          @Kris Please refer to this document that describes mavlink routing in VOXL SDK https://docs.modalai.com/mavlink/
          • KrisK Kris
            	ping 192.168.8.1
            and my
            @Kris The gcs_ip option was moved to /etc/modalai/voxl-mavlink-server.conf
              KrisK Offline
              KrisK Offline
              Kris
              @tom
              Thank you for your response
              It was a great answer.
              So, whenever I inspect the services on the Seeker with SDK 1.1.2, is it normal not to see voxl-px4 and voxl-px4-imu-server services?
              Should'nt px4 services automatically download if I install the 1.1.2 SDK?
              • KrisK Kris
                @tom
                @Kris On seeker PX4 runs on flight core, a separate board, not on voxl. So no, you shouldn't see voxl-px4 running on voxl. And voxl-px4-imu-server is a service specific to RB5 platforms so it isn't applicable to seeker.
