  2. VOXL Compute & Autopilot
  3. VOXL 2 Mini
  4. VOXL2-mini USB3.0 port HW issue!
Scheduled Pinned Locked Moved VOXL 2 Mini
8 Posts 3 Posters 1.3k Views 1 Watching
  • J Offline
    Jskim
    1. We conducted a comparative test on the VOXL2-mini USB3 port HW issue as follows.
    1)Test equipment
    • VOXL2+5GModem (USB3 port) and VOXL2-mini (USB3 port)
    • Arducam 13MP IMX258 OIS Motorized Focus USB 3.0 Camera Module
    2)Test results
    In conclusion, after removing the VOXL2-mini USB3.0 cable, the same problem appears as a result of testing. (Only 1280x720@10fps is supported.)
    a. VOXL2+5GModem (USB3 port)
    b. VOXL2-mini (USB3 port)
    2. Question
    1. When will the board with the VOXL2-mini AC Capacity problem solved be released?
      (We need to use the USB3 port. We need to purchase 3 units right now, but we are unable to purchase them due to the AC Cap issue.)
    2. After purchasing VOXL2-mini, is it possible to replace the product if an improved version comes out?
    ModeratorM VinnyV 2 Replies Last reply
    • J Jskim
      1)Test equipment
      2)Test results
      2. Question
      @Jskim Do you need VOXL 2 Mini? VOXL 2 is designed for expansion of peripherals, VOXL 2 Mini is designed to be as small as possible. We do not plan to change VOXL 2 Mini.
      • J Jskim
        1)Test equipment
        2)Test results
        2. Question
        VinnyV Offline
        VinnyV Offline
        Vinny
        Hi @Jskim
        Sorry for all the confusion here with the USB3 port issue on V2 Mini.
        I am conducting some tests this week to ensure we can communicate clear and correct instructions how to remedy this on your side.
        Please give me a few more days. We know it may be a blocker for you for some use cases and resolutions, so I am making it a priority.
        Stay Tuned.
        J 2 Replies Last reply
        • VinnyV Vinny
          Hi @Jskim
          Stay Tuned.
          Jskim
          @Vinny
          I hope you find a solution.
          We are already using V2 for VTOL drones, and are planning to use V2-mini for other large-scale projects.
          Thank you,
          • VinnyV Vinny
            Hi @Jskim
            Stay Tuned.
            Jskim
            @Vinny
            Please let us know the results of your USB3.0 port test.
            VinnyV 1 Reply Last reply
            • J Jskim
              @Vinny
              VinnyV Offline
              VinnyV Offline
              Vinny
              @Jskim yes I plan to test a solution early this week.
              J 1 Reply Last reply
              • VinnyV Vinny
                Jskim
                @Vinny
                Thank you so much.
                • J Jskim
                  @Vinny
                  Thank you so much.
                  VinnyV Offline
                  VinnyV Offline
                  Vinny
                  Hi @Jskim
                  We are happy to report our testing was successful.
                  I have documented the process where you can modify MCBL-00022-2 and add the series caps for your self to unblock your USB 3 speeds:
                  Link Preview Image
                  Cable User Guides
                  favicon
                  Hope this helps!!
                  Let us know how your testing progresses.
