    New SDK performance mode
    VOXL SDK
    • Jeffrey MaoJ
      Jeffrey Mao
      Hi Modalai,
      For the new sdk 1.1.1 if we want to set the voxl2 to performance mode do we follow the same instruction here
      https://docs.modalai.com/thermal-and-performance/
      It seems that when we cat we have a diffferent string and trying to use the command to pipe the string performance does nothing
      • M
        mrunaljsarvaiya
        Adding more information (I work with Jeffrey), we get an error
        [ Error writing lock file /sys/devices/system/cpu/cpu0/cpufreq/.scaling_governor.swp: Permission denied ]
        I can't seem to delete the .swp file either.
        • ModeratorM
          Moderator ModalAI Team @mrunaljsarvaiya
          @mrunaljsarvaiya are you using VOXL 1 or VOXL 2? You're pointing to the VOXL 1 user guide.
          It may not be well documented, but voxl-cpu-monitor can set the scaling mode in its config file
          Jeffrey MaoJ 1 Reply Last reply Reply Quote 0
          • Jeffrey MaoJ
            Jeffrey Mao @Moderator
            @Moderator Hi We are using Voxl2.
            Do you have any documentation for voxl-cpu-monitor or where it is for Voxl2 any starting point would be helpful
            • tomT
              tom admin @Jeffrey Mao
              @Jeffrey-Mao I would first run voxl-configure-cpu-monitor factory_enable to enable the service with default settings.
              Then, you can modify the config file at /etc/modalai/voxl-cpu-monitor.conf and change normal_cpu_mode to performance
              • tomT
                tom admin @tom
                @tom The conf file also has some comments that describe other possible config options
                • Jeffrey MaoJ
                  Jeffrey Mao
                  Thanks it works like a charm now for the help
