  2. VOXL SDK and Software
  3. New SDK performance mode
voxl-sdk
7 Posts 4 Posters 2.1k Views 1 Watching
  • Jeffrey MaoJ Offline
    Jeffrey Mao
    Hi Modalai,
    For the new sdk 1.1.1 if we want to set the voxl2 to performance mode do we follow the same instruction here
    https://docs.modalai.com/thermal-and-performance/
    It seems that when we cat we have a diffferent string and trying to use the command to pipe the string performance does nothing
    • M Offline
      M Offline
      mrunaljsarvaiya
      Adding more information (I work with Jeffrey), we get an error
      [ Error writing lock file /sys/devices/system/cpu/cpu0/cpufreq/.scaling_governor.swp: Permission denied ]
      I can't seem to delete the .swp file either.
      ModeratorM 1 Reply Last reply
      • M mrunaljsarvaiya
        @mrunaljsarvaiya are you using VOXL 1 or VOXL 2? You're pointing to the VOXL 1 user guide.
        It may not be well documented, but voxl-cpu-monitor can set the scaling mode in its config file
        Jeffrey MaoJ 1 Reply Last reply
        • ModeratorM Moderator
          Jeffrey Mao
          @Moderator Hi We are using Voxl2.
          Do you have any documentation for voxl-cpu-monitor or where it is for Voxl2 any starting point would be helpful
          • Jeffrey MaoJ Jeffrey Mao
            @Jeffrey-Mao I would first run voxl-configure-cpu-monitor factory_enable to enable the service with default settings.
            Then, you can modify the config file at /etc/modalai/voxl-cpu-monitor.conf and change normal_cpu_mode to performance
              @tom The conf file also has some comments that describe other possible config options
                Jeffrey Mao
                Thanks it works like a charm now for the help
