  2. VOXL SDK and Software
  3. voxl_mpa_to_ros2 camera_interface timestamp
ros
11 Posts 4 Posters 2.4k Views 2 Watching
  • S Offline
    S Offline
    smilon
    Heya,
    I just found out something that's causing me issues with my TF's in ROS2. Shouldn't the timestamp of the ROS2 msgs be constructed from both nanosecs and secs?
    In the camera_interface.cpp only the nanosecs field is populated causing the timestamp to be incompatible with any ROS2 time conventions.
    This however is not the case in the imu_interface.cpp which works as intended.
    Thought I would point it out!
    • S smilon
      Heya,
      @smilon ,
      I believe you are correct! Thank you. We will double check this and fix.
      S 1 Reply Last reply
        @smilon ,
        S Offline
        S Offline
        smilon
        @Alex-Kushleyev Great! Please ping me here whenever you have this updated because current workaround is kinda ugly :S. Thanks a lot!
        Alex KushleyevA Eric KatzfeyE 2 Replies Last reply
        • S smilon
          @smilon , we have a merge request that is being tested - https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2/-/merge_requests/8/diffs?commit_id=a128608d0ad1e4c417edc7013f9bbbf9665b754b#diff-content-bbec15f81097cb24d4e021ae03a1c7aa01ff13d6
          Can you please take a look and help confirm this is what you are expecting?
          Thank you 🙂
          • S smilon
            @smilon You can find an updated package here: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mpa-to-ros2_0.0.2-202402291159_arm64.deb. This should work fine with SDK 1.1.2.
            • S Offline
              S Offline
              smilon
              Dear @Alex-Kushleyev, @Eric-Katzfey this did the trick! Thanks for the quick fix!! Everything works as expected now.
              • S smilon
                @smilon, great! thank you for bringing this issue to our attention in the first place.
                • jacob yaacubovJ Offline
                  jacob yaacubov
                  Hi guys sorry for getting this thread up again,
                  i am experiencing same issue with my cameras and qvio ros2 topics
                  time stamp rests after few seconds , time stamp of seconds stays at zero
                  sec 0  STUCK AT ZERO
                  nsec 3300161870  REACHING TO 3 BILLION (3 SECONDS)
                  frame_id "tracking"
                  height 480
                  width 640
                  encoding "mono8"
                  is_bigendian 0
                  step 640
                  any fixes that match SDK 1.1.3 ?
                  • jacob yaacubovJ jacob yaacubov
                    sec 0  STUCK AT ZERO
                    frame_id "tracking"
                    height 480
                    width 640
                    encoding "mono8"
                    is_bigendian 0
                    step 640
                    @jacob-yaacubov Are you able to use the deb provided above with the fix? i'll check when it will officially be in SDK
                    jacob yaacubovJ 1 Reply Last reply
                      jacob yaacubov
                      @Alex-Kushleyev i have used the dev branch in the voxl-mpa_to_ros2
                      and this branch has a fix , built it from source
                        @jacob-yaacubov , FYI, this fix will be in 1.2.0 release which is in testing now
