  3. USB3.0 port is not working.
3 Posts 2 Posters 845 Views
  • I Offline
    I Offline
    iksk
    Hi support team.
    I used to VOXL 2 Ethernet and USB Hub Add-on, but USB3.0 port at pre-mounted connectors is not working. USB3.0 port at 10-pin JST connector is working.
    I have another same board, this one is all ok.
    How can I get it to work?
    Can I exchange it for another one?
    ModeratorM 1 Reply Last reply
    • I iksk
      Hi support team.
      @iksk Which connector is USB3.0 port at pre-mounted connectors ?
      you can fill out the form at https://modalai.com/rma if you want to try to exchange
      I 1 Reply Last reply
      • ModeratorM Moderator
        I Offline
        I Offline
        iksk
        @Moderator Thank you for reply. This connecter is not working.
        I connect usb3-camera device into this connecter, but not recognized.
        I checked to using bellow commands
        • lsusb: did not add new device.
        • dmesg: did not output new kernel messages(info. warn error etc.).
        When using Cable USB3 10-pin JST, usb3-camera device is recognized and working. So I think hub IC and peripheral circuit are working.
