    USB3.0 port is not working.
    • I
      iksk
      Hi support team.
      I used to VOXL 2 Ethernet and USB Hub Add-on, but USB3.0 port at pre-mounted connectors is not working. USB3.0 port at 10-pin JST connector is working.
      I have another same board, this one is all ok.
      How can I get it to work?
      Can I exchange it for another one?
      • ModeratorM
        Moderator ModalAI Team @iksk
        @iksk Which connector is USB3.0 port at pre-mounted connectors ?
        you can fill out the form at https://modalai.com/rma if you want to try to exchange
        I 1 Reply Last reply Reply Quote 0
        • I
          iksk @Moderator
          @Moderator Thank you for reply. This connecter is not working.
          I connect usb3-camera device into this connecter, but not recognized.
          I checked to using bellow commands
          • lsusb: did not add new device.
          • dmesg: did not output new kernel messages(info. warn error etc.).
          When using Cable USB3 10-pin JST, usb3-camera device is recognized and working. So I think hub IC and peripheral circuit are working.
