  3. voxl2 mini 4in1 esc
voxl2 mini 4in1 esc
4 Posts 2 Posters 882 Views 1 Watching
  • tiralonghipolT Offline
    tiralonghipol
    Hi! I am trying to use the scripts in esc-tools to read the 4in1 esc for the voxl2mini
    and it seems like only 1 of the 4 escs is detected:
    voxl2-mini:/usr/share/modalai/voxl-esc-tools$ python3 voxl-esc-verify-params.py
    [GCC 8.4.0]
    Found voxl-esc tools bin version: 1.4
    VOXL Platform: M0104
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000
    ERROR: ESC ID 0 not found
    ERROR: ESC ID 1 not found
    ERROR: ESC ID 2 not found
    INFO: Params from ID 3 match ../voxl-esc-params/boards/esc_params_generic_m0129.xml
    ERROR: Some params are invalid or not the same!
           Number of ESCs expected     : 4
           Number of ESCs found        : 1
           Number of invalid params    : 0
           Number of matched params    : 1
    more info about the system:
    system-image: 1.7.1-M0104-14.1a-perf-nightly-20231025
    kernel:       #1 SMP PREEMPT Thu Oct 26 04:23:26 UTC 2023 4.19.125
    hw version:   M0104
    voxl-suite:   1.1.2
    current IP: wlan0: 192.168.5.158
    does anyone have any idea what is going on?
    • tiralonghipolT tiralonghipol
      [GCC 8.4.0]
      hw version:   M0104
      voxl-suite:   1.1.2
      @tiralonghipol
      Sorry about that!
      Please check the recovery procedure i just described in another thread (bottom) : https://forum.modalai.com/topic/2897/voxl-mini-4in1-esc-and-voxl-2/8
      tiralonghipolT 1 Reply Last reply
        @tiralonghipol
        Sorry about that!
        tiralonghipol
        wrote on last edited by tiralonghipol
        @Alex-Kushleyev thank you for the fast reply!
        I (apparenmtly) solved the issue after upgrading everything to latest version and uploading the correct params for m0129 v3 from my laptop
        interestingly the mini2 detects the complement of what my usb-uart cable detecs
        but yes thank you for the tools, otherwise I had no idea how to recover a bricked 4in1 lol
          @tiralonghipol , great to hear! if you have this issue again, you should be able to recover the ESC using the steps I described.
