  2. Software Development
  3. How to install ipk package
9 Posts 3 Posters 2.4k Views 3 Watching
  • G Offline
    G Offline
    Gaurav Borade
    wrote on last edited by Gaurav Borade
    I am trying to install the voxl-streamer, for that, I am following the procedure given on this link (https://docs.modalai.com/voxl-streamer/)
    Here they used a path "/home/root/ipk" to install it, but in my voxl I cannot found the ipk package on root folder. I have the following in my "/home/root"
    Need help to install the ipk package
    • tomT Offline
      @Gaurav-Borade You don’t need to be in any specific directory to use opkg update
      G 1 Reply Last reply
      • Eric KatzfeyE Offline
        Just run the two commands in the /home/root directory if you do not have a /home/root/ipk directory. You can run the 2 commands from any directory, it does not have to be named /home/root/ipk
          G Offline
          G Offline
          Gaurav Borade
          @tom & @Eric-Katzfey thank you for help
          I tried but got following error
            Are you sure you are connected to the Internet? What happens when you try ping www.modalai.com? If that succeeds, what happens if you try ```
            wget http://voxl-packages.modalai.com/stable/Packages.gz
            • G Offline
              G Offline
              Gaurav Borade
              @Eric-Katzfey said in How to install ipk package:
              Hi Eric,
              From VOXL board I am not able to ping to "www.modalai.com", I also tried to ping google.com.
              However, I can able to ping to modalai from the host computer,
              • tomT Offline
                @Gaurav-Borade You’ll need to connect your VOXL to the internet in order to install the package. You can connect your VOXL to WiFi by using voxl-wifi station [SSID] [password] and then rebooting your VOXL.
                  G Offline
                  G Offline
                  Gaurav Borade
                  Hi @tom
                  I did it but still not able to connect to the internet 😐
                  • G Offline
                    G Offline
                    Gaurav Borade
                    finally Done
                    Thank so much you @tom & @Eric-Katzfey
                    Link Preview Image
                    Station mode not connecting to Internet
                    Hello, I have a m500 VOXL drone that I want to connect to the internet. I put the drone into station mode over adb according to https://docs.modalai.com/wifi...
                    favicon
                    ModalAI Forum (forum.modalai.com)
                    I have to disable the microhard ethernet for it.
