    How to install ipk package
    Software Development
    1948
    • G
      Gaurav Borade
      I am trying to install the voxl-streamer, for that, I am following the procedure given on this link (https://docs.modalai.com/voxl-streamer/)
      Here they used a path "/home/root/ipk" to install it, but in my voxl I cannot found the ipk package on root folder. I have the following in my "/home/root"
      Need help to install the ipk package
        tom admin
        @Gaurav-Borade You don’t need to be in any specific directory to use opkg update
        G 1 Reply Last reply Reply Quote 1
          Eric Katzfey ModalAI Team
          Just run the two commands in the /home/root directory if you do not have a /home/root/ipk directory. You can run the 2 commands from any directory, it does not have to be named /home/root/ipk
          • G
            Gaurav Borade @tom
            @tom & @Eric-Katzfey thank you for help
            I tried but got following error
              Are you sure you are connected to the Internet? What happens when you try ping www.modalai.com? If that succeeds, what happens if you try ```
              wget http://voxl-packages.modalai.com/stable/Packages.gz
              • G
                Gaurav Borade
                @Eric-Katzfey said in How to install ipk package:
                Hi Eric,
                From VOXL board I am not able to ping to "www.modalai.com", I also tried to ping google.com.
                However, I can able to ping to modalai from the host computer,
                  tom admin
                  @Gaurav-Borade You’ll need to connect your VOXL to the internet in order to install the package. You can connect your VOXL to WiFi by using voxl-wifi station [SSID] [password] and then rebooting your VOXL.
                  • G
                    Gaurav Borade @tom
                    Hi @tom
                    I did it but still not able to connect to the internet 😐
                    • G
                      Gaurav Borade
                      finally Done
                      Thank so much you @tom & @Eric-Katzfey
                      https://forum.modalai.com/topic/280/station-mode-not-connecting-to-internet?_=1624012254214
                      I have to disable the microhard ethernet for it.
